Old 01-13-2014, 07:41 PM
  #26026
Jim Branaum
Here is a question I want opinions on.
I picked up a Pete-n-Paul today that needs a radio and an engine (after I fix the rudder I stepped on ). The radio is fairly simple, but the "specified" engine is a .35. Now that bird is not older than the hills, but I cannot remember when the last time I even SAW a new .35 for RC.
Here is the question. Do you think my Saito .30 would be enough power? I am pretty sure I used to turn a 9x6 around 9000 when it was on my H.O.B. AT-6. Since that bird is really broken bad (trees are never easy on balsa at speed) I am thinking about moving the engine.
Old 01-14-2014, 01:46 AM
  #26027
Rudolph Hart
Rudolph Hart's Avatar
Can you post a picture jim or do you mean the pete n poke?
I have a saito 30 in a PHEONIX RAINBOW about 65" wingspan and fairly light.The 30 will go vertical on that.You should be using a 10x6 on it and from memory on the bench i was getting over 10000,it was ripping the prop tips.For such a little engine it's performance is amazing.
Old 01-14-2014, 05:48 AM
  #26028
Hobbsy
Hobbsy's Avatar
Pete, could he mean this Pietenpol?
Old 01-14-2014, 06:10 AM
  #26029
Rudolph Hart
Could be,if it's a 46 size and they ar'nt seriously draggy the 30 should be a good choice.
Old 01-14-2014, 07:04 AM
  #26030
Jim Branaum
hmm...going to have to check the plans again for the correct name because I am confused. Yesterday was a long and hard day, and I am supposed to be retired.
The box says ".35 RC" for engine, but it does look vaguely like what Hobbsy posted except 2 seat. It belonged to a friend who moved on to softer runways last summer.
Old 01-14-2014, 09:04 AM
  #26031
blw
blw's Avatar
Evolution made a 36 two stroke that is supposed to be a good engine. I have one that I got in a deal but haven't run it yet. Evolution changed the lineup to include a 40 and discontinued the 36. If it were for myself I would prefer a 4 stroke.
Old 01-14-2014, 09:25 AM
  #26032
Hobbsy
Hobbsy's Avatar
Jim, that one is called the Pietenpol Camper, I don't know the model of the two holer.
I just ran my Saito .30 for a good 45 minutes with two different props. With an audience of about 300, the fans span the entire 35 acre field. I couldn't get the whole field in the viewer./
Saito .30, "A" designation on the right lug.
Fuel==WildCat 15% with 18% 80/20 blend.
Plug==Taipan 4C
Exhaust==Stock
Prop==Graupner 10x5.5
Valve lash==@ .0039"
Rpm==10,245
Idle as in picture.
With a Bolly 10.5x5 the rpm was 10,035. No picture, the camera memory is full. (Corrected prop size)
Name:	Saito 30 rpm 007 (Small).jpg
ID:	1957640   Click image for larger version
Name:	Saito 30 rpm 011 (Small).jpg
ID:	1957641   Click image for larger version
Name:	Saito 30 rpm 001 (Small).jpg
ID:	1957642   Click image for larger version
Name:	Saito 30 rpm 005 (Small).jpg
ID:	1957643   Click image for larger version
Name:	Saito 30 rpm 003 (Small).jpg
Old 01-14-2014, 09:37 AM
  #26033
hsukaria
I would agree. Both the Pietenpol and the Pete 'n' Poke are prime candidates for 4-stroke engines.
Old 01-14-2014, 12:39 PM
  #26034
blw
blw's Avatar
I forgot this is the Saito thread when I mentioned a two stroke for the mystery plane.
Dave. you meant the Bolly prop is a 10.5x5 didn't you?
Jim Branaum is club member # 815
Old 01-14-2014, 01:29 PM
  #26035
Jim Branaum
OH NOOOOESS... the changing number bug caught me!
Really?
Old 01-14-2014, 02:25 PM
  #26036
Hobbsy
Hobbsy's Avatar
Thanks Barry, I'll have to gaze upon that Bolly and see.
OK, Barry, you have it exactly right, also, I have four of the 10.5x5's and one 10.5x6. If I can find an 11.5x6 I'll try it on my old FA .40.
In additon to using an Australian glow plug and an Australian prop, I was wearing my Kangaroo hide boots.
Old 01-14-2014, 02:50 PM
  #26037
hsukaria
Hobbsy, it's a little warmer down there in Australia right now!!!
I am waiting for a warm-up to break-in my new Saito 91S. I might ask you for your break-in procedure or in which previous post it is located.
Old 01-14-2014, 03:38 PM
  #26038
Hobbsy
Hobbsy's Avatar
Red face
H-Man, its pretty easy
10 minutes at 4,000 rpm with throttle at 1/4 to 1/3
10 minutes at 5,000
10 minutes at 6,000, probably need to top off the tank about here
10 minutes at 7,000 with brief runs to full throttle
Set LS needle as low as possible with HS at full peak. Go fly
You will note that during each 10 minute run that the rpm will slowly increase, I just let it go, the 5,000 rpm run will show the greatest gain. You know I'm going to get busted for this. I consider it a compliment
PS, if it is too wet and smoky on any 10 minute period, just lean it a couple of clicks to make it smooth but still rich.
Old 01-14-2014, 05:07 PM
  #26039
the pope
I am waitithat's celcious cr a warm-up to break-in my new Saito 91S. I might ask you for your break-ihot water serure or in whither eprevious post it is located.
Hi there husky yes it is a wee bit warmer down here, today we're looking at 45° and tomorrow 46° and thats c not f . Yikes , the son being a plumber was up on a roof all day installing solar hotwater service . Poor bugger .Cheers the pope
Old 01-14-2014, 05:32 PM
  #26040
hsukaria
Solar water heaters would be silly in Michigan..
Old 01-14-2014, 05:33 PM
  #26041
hsukaria
Thanks Hobbsy
Old 01-15-2014, 12:29 AM
  #26042
Rudolph Hart
Plug==Taipan 4C
Exhaust==Stock
Rpm==10,245
Idle as in picture.
Dave that hot weather the pope mentions was over here last weekend 44/45C,you coulda slowroasted a duck on the tin roof here.Your fans look like what we call 'mounties' here,if you shoot and cook one you'll need a chainsaw to carve it.Please use castrol r in the saw.
Those figures you got with the 30 seem pretty good.I was running an os f plug with a 10x6 mas series 2 q tip and 20% nitro 15% syn/castor.From memory i got 10600 steady.
Jim did you find out what .35 aeroplane you have?
Old 01-15-2014, 05:38 AM
  #26043
Hobbsy
Hobbsy's Avatar
You're welcome HS
Our weather here has been crazy, last week we had 55f one day and 5f the next morning. Pete, I always throw about one ounce of castor into the chain saw gallon when I mix it. An ole dirt biker wouldn't leave home without it.
PS, the idle on the .30 was 2,200 when the Bolly was mounted. It's hard to get it below 3,000 with a wood prop.
Old 01-15-2014, 07:32 AM
  #26044
acdii
10 minutes at 5,000
Is there a cool down period like that used for magnums?
Old 01-15-2014, 07:56 AM
  #26045
Jim Branaum
Yes, the box says it is a 65 inch three channel Peitenpol by HoB and need a .19 to .35 engine.
Since I really do enjoy playing games with 3 channel birds (it really gets the 'big' guys when I can do things they insist I cannot) it will be 2nd or 3rd down on the repair list. First is the AJ Slick Edge...
Old 01-15-2014, 08:53 AM
  #26046
blw
blw's Avatar
Really?
Jim, I had a note to myself to give you a number. I found where you were originally #806, so nevermind. Who was the other guy who needed a number?
Dave, you have a good system for breaking in a Saito and there's always more than one way to skin a cat. I've always done mine the same way except for wide open runs beginning on the second tank (second 10 minute run) and maybe varying the base rpms some up or down.
Old 01-15-2014, 09:54 AM
  #26047
acdii
Me. Got a 100 Golden Knight. I dont recall seeing one for me yet.
Old 01-15-2014, 10:50 AM
  #26048
Hobbsy
Hobbsy's Avatar
ACD, there is noting in the construction of a Saito that would benefit from heating and cooling cycles.. Saito does not suggest one so I never did it.
Barry. I stick to my method because it's easy to keep track of and when I'm done I can forget about it.
I just ran my old FA .40 for about an hour.
FA .40
Fuel===WildCat 15% with 18 % 80/20 blend
Plug===Enya black A-3
Exhaust=TurboHeader, I don't have a stock exhaust for it other than for a .50
Prop===Bolly 11.5x5
RPM===10,660
Idle 2,150, when idle at best, midrange was wet, when midrange was clean, no idle below 2,400.
Name:	Saito .40s 002 (Small).jpg
Old 01-15-2014, 03:36 PM
  #26049
blw
blw's Avatar
Dave, I've had 2 Saitos that put this break in process to the test in my mind. One is a 125 that I thought would never break in, but it finally smoothed out after I had a lot of doubts about the thing. A real late bloomer. The other is one of the first batches of 82's. It was so smooth I think it was ready to fly after 10 minutes.
Old 01-15-2014, 04:01 PM
  #26050
johnboy151a
My Feedback: (68)
johnboy151a's Avatar
BLW, how much time on your 125 until you were happy with it?
John
