Official Tamiya TT-01 Thread
Old 04-19-2009, 07:21 PM
  #5226
SIRCC
SIRCC's Avatar
Default RE: Official Tamiya TT-01 Thread
if you got to practice alot it wouldn't be a problem, the tt-01 can practically handle it with a few of aluninum parts in it for added weight,
you part of groovydrift? where you race at?
Old 04-19-2009, 09:00 PM
  #5227
Jem93
yay, a fellow drifter
Old 04-20-2009, 07:10 AM
  #5228
xxSLiMxx
xxSLiMxx's Avatar
ORIGINAL: SpeedstaBrad
Hi, been reading through some of the posts and seen some sexy cars and i am now very tempted to pick up a Ezrun 9t brushless system for £50 off ebay Please tell me if it is worth it and my tt-01 is nearly stock at the moment just with aluminium driveshaft, bearing set and aluminium bumper plate. S would it handle the power of the brushless 9t system? Thanks
Thats what im running in my TT01 right now, its an awsome set up both for raceing and drifting. You should be fine with it, just make sure you gear it right.
Old 04-20-2009, 10:21 AM
  #5229
SpeedstaBrad
Ok, from what you said Slim it sounds like you should know And £50 is an okay price? It sounds good but its not exactly the best known make...and i can keep the stock gears right? Thanks for all the help guys, also the car is for bashing and drifting. I will try and get some pics up soon when i have my new bodyshell.
Old 04-20-2009, 10:41 AM
  #5230
xxSLiMxx
xxSLiMxx's Avatar
Im not sure what that works out to be canadian, but i only payed $80.00 for the ESC/Motor 9T combo. Your right its not really a "known" brand but it dose awsome in a TT01. Iv been useing mine for about a year now and never had a problem. Stock gearing will work good, you can even go a little higher and keep the temps in the safe zone.
Old 04-20-2009, 10:49 AM
  #5231
SpeedstaBrad
Thanks mate, that really helps. And i love the look of your car, when i scrolled back through the forums i saw that and your real life Civic. I will probably order it now so it should arrive in about 10 days from hong kong. £50 = $89 CANADIAN DOLLARS. So mine will cost a little more but thats fine.
Old 04-20-2009, 10:50 AM
  #5232
xxSLiMxx
xxSLiMxx's Avatar
Good luck dude, Make sure to get some pictures of yours posted up!!
Old 04-21-2009, 08:18 AM
  #5233
Allan Aguilar
Allan Aguilar's Avatar
I am searching for a motor mount mod for the Tamiya TT-01. I have a full range of Tamiya pinion gears in my tool box and instead of me purchasing some new set of pinion for this kit, I'd rather use my current spares.
Now my question is, is there any motor mount where you can use virtually all Tamiya specific pinions from 19T and over without the need to change spur gears. Are there any available mods for this ?
I am raising this question as I have a Yokomo MR4TC and I can use different 48 pitch pinion gears from 19T and over.
Any help will be appreciated.
Old 04-22-2009, 12:33 AM
  #5234
dfiantii
dfiantii's Avatar
There is no way to mod the TT-01 and use 48 pitch gears in the stock form. You would HAVE to get the 3Racing chasis upgrade, which I did. I am actually using 64 pitch gears 65 spur 39 pinion.
Old 04-22-2009, 12:52 AM
  #5235
dfiantii
dfiantii's Avatar
Old 04-30-2009, 10:07 AM
  #5236
studysession
studysession's Avatar
xxSLiMxx -
Do you have a link to where one can get that Civic body? I like it.
Old 04-30-2009, 10:12 AM
  #5237
xxSLiMxx
xxSLiMxx's Avatar
ORIGINAL: studysession
xxSLiMxx -
I got mine from ebay. They are very hard to get tho. It took me about 4 moths to find one and i payed an arm/leg for mine. Tamiya makes them well they did up untill 1994. Try searching "Tamiya EG Civic Body" or something along thos lines! Good luck in your search.
Old 04-30-2009, 10:16 AM
  #5238
studysession
Thanks -
Old 04-30-2009, 10:23 PM
  #5239
Bob076
Hi guys, just started upgrading my TT-01d and was after some advice. I see that GPM make alloy arms for the tt-01 and adjustable for the tt-01d, is the adjustment needed for drifting or would the fixed ones be good enough? My concern was mabye the adjustable ones will get sloppy and create the same probs as the stock ones...
Any advice will be appreciated.
Cheers
Old 04-30-2009, 11:01 PM
  #5240
xxSLiMxx
xxSLiMxx's Avatar
ORIGINAL: Bob076
Cheers
IMO fixed ones will do just fine. Altho some guys like to beable to adjust the camber for a bit better steering, but its nothing that a few hours of pratice cant fix.
Old 04-30-2009, 11:24 PM
  #5241
azntastic
hey all, I need some help. Im new 2 all this and I recently bought a TT01d XB mazda Rx-7, can any1 tell me what hop ups or stuff i shuld get? and also were to get good lexan bods for my car with the headlight taillights stuff which i can use my tlu with. any tips for me would b greatly aprreciated. Thanks
Old 05-01-2009, 01:39 AM
  #5242
AusDrifter18
ill suggest a few things to get the ball rolling...
ALLOY DRIVE SHAFT... BEARINGS SET... DIFFERENT SHOCKS... CARBON FIBRE TOP DECK
body-wise just look around on ebay try different searches like 1 10 body... 1 10 shell... rc whatever... also
http://www.genkidoridori.com/
sell some pretty good stuff and apparently are very good with shipping and stuff
Old 05-01-2009, 06:27 AM
  #5243
Bob076
Thanks for the advise on the arms xxSLIMxx, will order the standard arms. 1 more question for now, I also want to order a good steering set. I was looking at the GPM set but not sure if it comes with bearings or bushes. Is this a good set and do I need to order bearings seperate, if so what size and where do I get them from.
Cheers
Old 05-01-2009, 06:45 AM
  #5244
xxSLiMxx
xxSLiMxx's Avatar
ORIGINAL: Bob076
Cheers
They do come with the bearing set.
Old 05-04-2009, 10:49 AM
  #5245
SpeedstaBrad
Man, im back and im still waiting on that ezrun 9t brushless to come through the door :/ Hopefully will be here this week one day, slim i need the gpm motor mount for brushless don't i? Thanks
Old 05-04-2009, 10:51 AM
  #5246
xxSLiMxx
xxSLiMxx's Avatar
Nope, the stock plastic one will work. With the GPM one tho its has heatsink fins to cool it down and it wont warp if it gets too hot. Its a good upgrade to have.
Old 05-04-2009, 10:56 AM
  #5247
SpeedstaBrad
Ok, i have ordered a cheap one from hong kong anyway. But i am not gonna wait for that to arrive before i install brushless now. I've decided on turning Mr Brushless into a drifter. Because i already have my racer.
Old 05-04-2009, 11:00 AM
  #5248
xxSLiMxx
xxSLiMxx's Avatar
Brushless is awsome for drifting...add some hpi drift tires and you'll have some fun!! Get some pics posted once you get it all installed.
Old 05-04-2009, 11:09 AM
  #5249
SpeedstaBrad
Will do, i am gonna use some hidden agenda drift tyres as i have two sets, journey and teknika, look them up on youtube if you don't know them. Never used them before but they sound good. Thanks for all the help and pictures will come, can't say when but shouldn't be to long.
Old 05-04-2009, 11:28 AM
  #5250
SIRCC
SIRCC's Avatar
HEY, Slim are you coming to the states anytime soon. Got a tamiya / hpi tournament coming up. the details are in the works, could use your help.
