Old 07-09-2023, 10:09 AM
  #54076
1200SportsterRider
1200SportsterRider's Avatar
Originally Posted by Glowgeek
Those 30's run happily at those giddy-up speeds. Peak HP is likely found at somewhere over 12K.
I go by this to an extent.
Crankshaft Threads 1/4 x 28 Cylinder Type AAC Engine (Only) Weight 8.96 oz Muffler Type 2-piece Bore 20.0 mm (0.78 in) Crankshaft Type Ball Bearing Power Type Glow Stroke 16.0 mm (0.63 in) Displacement .30 cu. in. (4.92 cc) Mounting Dimensions 88 x 45 x 93 mm RPM Range 2000 - 12000,
Total Weight 9.28 oz,
Benchmark Prop 10x6 APC @ 9800
Old 07-09-2023, 10:59 AM
  #54077
Jesse Open
Jesse Open's Avatar
It's what they do in the air that really counts
Setting up a 20 year old, scratch built from scratch plans, 62" Mr Mulligan with a brand, spanking new, old stock Enya 80. Break in will be in the air, as usual.
Old 07-09-2023, 01:38 PM
  #54078
the Wasp
hey guys, about the poor 19y.o. woman police officer in training that die here in Vt. she was hit just about 1 mile (as a car drives) from my house. a lot of people hear are upset about this. my wife and I included. I have heard people say "things happen for a reason". well, if that is true, I just hope some people will look good at themselves as they think about her and hopefully change their lives for the better.
here's a "God Bless" for the girl that wanted to help Vermont to be a nicer place to live.
Jim
brickwoodward (08-05-2023)
Old 07-09-2023, 01:48 PM
  #54079
Glowgeek
Nice plane, Gary. What size is the cowl? I may have a dummy radial for it.
Old 07-09-2023, 03:01 PM
  #54080
Glowgeek
Suggested RPM range 2k-12K......all good. I don't own an FA-30 but have owned several 56's and 62's. I propped them for 11k-11.5k on the ground......they still run great.
Old 07-09-2023, 10:01 PM
  #54081
the Wasp
here you go,,,
Saito FA-30S New in Box - RC Groups
Jim
Old 07-10-2023, 02:08 PM
  #54082
Jesse Open
Jesse Open's Avatar
Thanks Lonnie,
The opening is a nominal 147 mm.
Old 07-10-2023, 03:16 PM
  #54083
Glowgeek
Originally Posted by Jesse Open
Thanks Lonnie,
I'll check but don't think I have anything near that small, sorry.
Update: Nope, smallest I have is 9" in diameter.
Old 07-10-2023, 05:45 PM
  #54084
Jesse Open
Jesse Open's Avatar
Thanks for looking.
A bit on the small side.
....Mr Mulligan, that is....
Old 07-11-2023, 08:33 AM
  #54085
1200SportsterRider
Saito FA 30-s, second run
Prop=====Bolly Clubman 9.5 x 7
Fuel=====Wildcat 2/4 10% with 18% full synthetic
Plug=====Glo-Devil 4c special for Saito and Enya
Exhaust==Stock
Fuel Tank=Roto Flow 10 oz.
Max rpm sustained for 5 minutes=10,240 rpm
Idle 2,000 rpm
Old 07-11-2023, 09:57 AM
  #54086
Glowgeek
Good numbers again, Dave. Frankly I'm a bit surprised that it only lost 1K peak rpm. Down around 10K the 30 is well short of its peak HP rpm, steep loss of power in that area.
With that 9.5x7 prop and approx 800 rpm of prop unloading in the air your LT-25 calculated speed is a smidge over 63 mph.
Old 07-11-2023, 12:09 PM
  #54087
1200SportsterRider
Right in the ballpark me thinks, Thanks
Old 07-12-2023, 06:10 AM
  #54088
Jesse Open
Jesse Open's Avatar
Exhaust==Stock
Idle 2,000 rpm
A bit more power than my old,1979 open rocker!
IIRC it turned 11,400 RPM with an 9 x 5 back then on 10% nitro.
Old 07-12-2023, 09:55 AM
  #54089
Jesse Open
Jesse Open's Avatar
Pulled down the old (ancient) Goldberg 63 this morning. According to the log book, last flown 9-15-2022. Last year it was prepped for the season on May 05. At that time, the valves were set at my preferred .0015", cold clearances. Also the valve covers were given a dollop of Bel-air waterproof, synthetic grease. I also replaced the fibre washers that I always use under the rocker cover screw heads.
Timer on transmitter shows that the engine was run above idle for over 28 hours.
Upon today's check, the .0015" feeler slipped in but an added .001" would not. Not bad.
Last year I also began fitting annealed copper washers between the exhaust locking nuts and the head and muffler joints.
The sometimes oil creep under the rocker screws is gone and the fibre washers have a locking action as well. Any top end leakage is virtually gone.
So far the sealed, USA made MRC front bearing is holding back at least most oil.
The vent re-breather on the velocity stack is doing a good job at keeping things clean below the belt.
Won't be making any valve adustments this year, and the oil blend will also remain the same.
Just replace the fibre washers, two dolops of grease in the rockers. Bolt em back on.
Off to the field and pick up where I left off last September.
Ugly but effective
Squeaky clean. Copper can't hurt!
Lonnie, Prop Shop had this. From an old Top Flite kit. Needs paint, trimming and mounting.
Old 07-12-2023, 10:31 AM
  #54090
1200SportsterRider
I checked some of the torque curves at Model Engine test, Saito torque grafts are mostly flat, a larger prop doesn't effect them much.
I just ran the FA 30--s with a Graupner G-Sonic 10 x 7
Same everything except the prop.
For a 10 x 7, i gets up there almost instantly.
Graupner G-S0nic 10 x 7 at full song
Old 07-12-2023, 10:44 AM
  #54091
Jesse Open
Jesse Open's Avatar
Forgot to mention.
The engine in my posting above is a Saito FA-50GK that was purchased around 1999.
I will haul two tachs to the field later this week and grab some RPM readings from the "Test Stand with Wings"
14% Klotz / 14% Nitromethane
Saitos sure are sweet. Especially being able to run so many hours between valve adjustments.
Well broken-in Saito .45 Mk2 Idling nicely. Tach is a Fromeco TNC. One of the very last to be made.
Old 07-12-2023, 10:50 AM
  #54092
1200SportsterRider
Forgot to mention.
I ran that entire 10 oz tank through today, nearly all above 6,000 rpm with no change in rocker lash,.you are so right.
Old 07-12-2023, 10:56 AM
  #54093
Jesse Open
Jesse Open's Avatar
LOL, Of course
The one above that was nearly 30 hours of in the air, flight time.
Approximately 5-1/4 gallons of home-brewed fuel. (By quick guesstimation)
Old 07-12-2023, 07:07 PM
  #54094
the Wasp
Gary, it's funny you brought up Rockers, I had to order some today. I had said "it's about time I run that FA91". and I mounted it to the test stand and went to adjust the rockers. I adjusted one but it was loose when I removed the Feeler. I knew I needed new rockers. LOL I hope they look better than Horizon's pic when I get them.
Jim
Old 07-13-2023, 02:16 AM
  #54095
Glowgeek
Jim
Exhaust or Intake rocker? What was worn? I'm curious because I've never seen one worn enough to worry about.
Old 07-13-2023, 02:24 AM
  #54096
Glowgeek
Yeah! That's going to look the part!
Old 07-13-2023, 03:08 AM
  #54097
Jesse Open
Jesse Open's Avatar
Hope so. I will get a few flights in first. Do the fitting after the flying season.
Jim, Got a rutted rocker? Like Lonnie, very surprised to hear that. Also wonder what the valve stem tip looked like?
Maybe a bad piece of steel or skipped heat-treatment.
Haha, maybe my posting about packed rocker covers wasn't totally wasted on everyone
Aren't those rockers around $30 now?
Yikes!
Ever considered dressing it on an oilstone?
.....Or is it too far gone?
Old 07-13-2023, 04:27 PM
  #54098
Glowgeek
I have seen more than a few mushroomed valve stems. Yes, easy enough to true with a stone and oftentimes a necessary evil before removing the valve. Bottom line, if you beat the valve through the guide the cylinder is history.......pkease don't ask how I know that.
Old 07-13-2023, 05:19 PM
  #54099
Jesse Open
Jesse Open's Avatar
Yessir,
Likewise, dragging a burred valve stem tip thru the guide. The keeper grooves can pick up a mean burr too.
Life's lessons.Learn from others when you can. Or pay dearly as you go
Old 07-13-2023, 07:00 PM
  #54100
the Wasp
that was the Exhaust, I will look at the Intake.
Jim
