Old 06-17-2024, 03:56 AM
  #55051
easystar123
Location: Kilrea, County Derry, N.Ireland. United Kingdom
Originally Posted by 1200SportsterRider
BTE - Flyin' King
It appears that Bruce Tharpe is shutting down, what a shame, I am lucky, I have a Flyin King ready to cover, one of the nicest flying planes I ever flew. I powered it with an early high compression Saito 80. This one will be powered by a Saito 100 with CHI, simply because I have a 100 that is sitting in it's box.
Hi there, can I ask you a question? Ive had a few different Saito engines through the years, the largest being a Saito 72. In recent times ive thought hard abput buying a Saito 100, but ive read a lot about vibration issues due to the Saito 100 having a long stroke. This results in the engine shaking the life out of the plane. Is there any truth to these statements or is it all a bit far fetched? I have a brand new 60 size Escapade 61 and I was looking at a new Saito 100 for this plane. Many thanks and kind regards Aidan.
Old 06-17-2024, 04:50 AM
  #55052
Jesse Open
Jesse Open's Avatar
I have a BTE Flyin King ready to cover, it's difficult to do anything with some medical thing nearly every day. Double MRI today, without and with dye.
Any recent pics?
Old 06-17-2024, 04:58 AM
  #55053
FlyerInOKC
FlyerInOKC's Avatar
It sucks getting old! Beautiful airplane!
Old 06-17-2024, 05:14 AM
  #55054
Glowgeek
I've had a couple FA-100's and didn't notice that they vibrated more than similar size 4 strokes. Just prop it for 9K to 10K rpm on the ground and you'll be fine. It's good to keep in mind that overly rich mixtures can cause excessive vibration.
The FA-100 I had on my Sig 4*60 was a perfect match. I only got to fly it a handful of times because someone at a fly-in just HAD to have it.
Old 06-17-2024, 05:53 AM
  #55055
easystar123
Many thanks for all your help. That has convinced me to go ahead and get the Saito 100. Cheers
Old 06-17-2024, 07:56 AM
  #55056
Jesse Open
Jesse Open's Avatar
I have built three of the Four Star 60 kits. The first was powered by a Saito FA-91. Seemed adequate at the time. Next one was fitted with the newly released YS 91AC. The differences were amazing. Not just the massive additional power but the transition and idle were were awesome and like no other engine of that size. I decided to build a third one a couple years later, this one was a clipped wing version with reinforced stab and elevator, also a scaled up, balanced rudder. Of course, another YS up front. Soon became the favorite Four Star.
If I come across a Four Star 120, I would like very much to build one. I would likely power it too with a YS-91AC with CDI . No doubt a good match for the way I fly now
That Four Star with an FA-100 will be Superb plane. They do quite well with a wide range of engines.
Old 06-17-2024, 06:58 PM
  #55057
the Wasp
I have a Four Star 60 (71"), I have not finished fixing it LOL. I have been wondering a long time if my Saito 100 T is too heavy for it. I have had one good pilot tell me it is not too heavy for it. seems to me it is, what you guys think.
Old 06-17-2024, 07:11 PM
  #55058
Glowgeek
As said, Jim, mine flew great great on the FA-100 single. Over powered for sure but that's how I like them. Unlimited vertical and fast enough to fly knife edge without loss in altitude, great fun for me but not everyone's cup of tea.
Don't know how the 100T would balance.
Old 06-18-2024, 02:32 AM
  #55059
1200SportsterRider
1200SportsterRider's Avatar
I have always considered the 100 to be a smooth engine, but due to it's light weight and strong power pulses it's torsional impulses will either rock the engine a little or rock the plane if the plane is light.
If this carb is set up the same as the FG 41, the HS/main needle goes in the empty hole.
Old 06-18-2024, 03:49 AM
  #55060
modeltronics
My Feedback: (27)
My style of flying must be very different because I'm flying a 4 Star 60 with a Saito 80.
Old 06-18-2024, 04:15 AM
  #55061
Glowgeek
The FG-40 & FG-41TS have different carbs than the FG-50.
Old 06-18-2024, 05:11 AM
  #55062
Jesse Open
Jesse Open's Avatar
No problemo! I wouldn't hesitate to fly one on a Saito 65 today.
Or, better still a YS 63
Back then, I was having a ball with the YS-91. It started 90 times out of 100 with a single thumb and forefinger back flip on the spinner nose. You could idle super low for 10 to 20 minutes and never skip a beat, rock solid idle. Slap the stick forward at any time for a snap instant transition. Very tractible . At any speed setting the RPM was very steady, Fuel tank location was anyplace of height you wanted. Even back then I rarely used full throttle but the other qualities were priceless. It did weigh a (small) bit more than the Saito but it was a lot smoother and easier on the airframe.
Old 06-18-2024, 07:35 PM
  #55063
the Wasp
Four Star 60 with a Saito 100:
I have seen the plane with the FA100 on you tube, and it sure goes. and because the FA100 is the same weight as the old OS 61fx (550g less mufflers), the plane still could be a floater when the pilot asks it to be.
Lonnie, I'm like you. I like to screw with things. you know, like that 82 you hopped-up. when I was working on my crashed Four Sar 60 I moved back the cockpit. maybe a bit too much. not as far as the GeeBee R, but enough. the Dashboard is about 1,125" behind the wing's trailing edge. the upper front deck is really long and looks so cool. it makes the plane look old, real old, like the first-effort built speedster. I will get a pic tomorrow.
Old 06-19-2024, 02:24 AM
  #55064
1200SportsterRider
The silver throttle lever on the FG 50 is the travel limiter for the throttle, you can see the blade that the lever hits in this shot.
Old 06-19-2024, 02:29 AM
  #55065
1200SportsterRider
Jim, you should build this Raven by OSMW, then share some Jet stories with us.
Old 06-19-2024, 02:36 AM
  #55066
Jesse Open
Jesse Open's Avatar
How about the real deal, a Bruce Tharpe Venture 60!
Old 06-19-2024, 02:42 AM
  #55067
1200SportsterRider
That was my second build, an RTC Tower Trainer 60 was my first. The V 60 wore a Saito 72 GK. The Tower Trainer wore an Irvine Q 72 which I still have.
http://btemodels.com/venture.html Sadly, the current status of the Venture 60.
Old 06-19-2024, 03:49 AM
  #55068
Jesse Open
Jesse Open's Avatar
They have been pretty much out of production for quite a while. Sad to see.
My first kit was a De Bolt Livewire Champ in 1960, the second was a Goldberg Junior Falcon quite a few years later. The Champ first flight used a 3 tube "Bramco" receiver. The Jr Falcon had a Min-X Galloping Ghost radio. Both radios were made in the Detroit area. John Krauer, the designer of the Min-X was in our club. The Bramco designer was Dick Branstner, of "Color Me Gone" funny car fame. He was a friend of my sister.
https://www.modelaviation.com/history-of-rc
Old 06-19-2024, 06:39 PM
  #55069
the Wasp
Me? nop, I have to slow down my P-40, the guys at the field say it's a 100mph plane, it lands around 30mph
Old 06-19-2024, 06:55 PM
  #55070
the Wasp
here is a pic of my unfinished Four Star 60. if you remember I post it back a long while. I will get better pics tomorrow IF I remember.
Old 06-20-2024, 09:26 AM
  #55071
the Wasp
OK, so here are more pics of my 4Star, my God, the digital really show up, the table is not really that dirty to the eye. I have got to get to work on the plane.
Old 06-20-2024, 10:09 AM
  #55072
the Wasp
hey Dave. you said you wanted a story. so here's a short one.
my Daughters youngest is 4, she's a joker,,, so. I call her "the Joker", every time she come her she comes over to me smiling. I get a kick because I know what she wants. she wants me to turn her upside down, so I do. she loves it.
EDIT. I had to come back and start up my computer. the Joker showed up right after I shut the computer down. she showed up to get a snack from Grammy. and of course I had to pick her up and turn her upside down again. she left with a smile LOL.
her older sister is 8, she's an artist. she loves sculpting with clay, and of course paper and tape. she loves tap.
Old 06-20-2024, 10:34 AM
  #55073
FlyerInOKC
FlyerInOKC's Avatar
I see Piglet is waiting patiently.
Old 06-20-2024, 04:12 PM
  #55074
the Wasp
Piglet: yes, I am guilty. I was going to put him in my Four Star 120, but I am going to sell it, it's too big for my car. to fit it in the Rav-4 the wing tip goes between the front seats. LOL want to buy it, it had only 6 flights LOL
Old 06-21-2024, 05:30 PM
  #55075
1200SportsterRider
As you can see below this Saito FA 40-a has some serious time on it. Mostly on an RCM 40. It will no power an OSMW SpadPort bipe. The top wing is complete, the bottom port wing is complete, I just had to jump ahead and mount the engine. The RCM succumbed to a tank bung hole splitting and soaking the entire noose from the wing forward.
Not my actual RCM 40
I have the graphics for thois.
