Old 10-24-2010, 07:36 AM
  #18776
MetallicaJunkie
MetallicaJunkie's Avatar
i can clearly see where it goes now, thanks Hobsy....im glad i dont have to take the carb apart...
Old 10-24-2010, 11:47 AM
  #18777
mike early
mike early's Avatar
ORIGINAL: tacx
ORIGINAL: mike early
I broke a cam gear and even a tooth off the crankshaft as well.
How in the hell did that happen?
Upon disassembly, everything was nice and wet with lubricant. Dang. 70 dollars of damage and I have no idea why.
I agree. I was flying my 220 and it was running great. Then it just quit in mid flight and I had to dead stick it in. Thought maybe it needed some adjustment, but when I tried to start it again the prop just spun freely. I took the engine apart and found I had lost 4 teeth on the cam gear???? My 220 has been sittting on the bench for two months cause I can't find a gear anywhere!!
If the prop was spinning freely, it must have back-fired and loosened your prop nut. Apparently these kick-backs are hard on the cam gear?
You are lucky you didn't break a groove off your crankshaft, like I did.
My engine was running fine. I must have broke it some other time.
Old 10-24-2010, 02:32 PM
  #18778
w8ye
w8ye's Avatar
Some times they get cracked and break trough a year later
Old 10-24-2010, 10:32 PM
  #18779
tacx
tacx's Avatar
Mike,
The prop nut was not loose. The prop was turning free because when the cam gear quit turning the exaust valve was sitting in the open position. I didn't realize it until I took off the valve cover and discovered the valves weren't moving.
Old 10-25-2010, 07:50 AM
  #18780
Hobbsy
Hobbsy's Avatar
MJ, a Tee pin will do the job getting the old O-ring out, carefully herding the new one through the hole will get the new one in there. You may have to carefully move it around a little with the Tee Pin to get the new one to seat.
Old 10-25-2010, 04:17 PM
  #18781
David Johnston
David Johnston's Avatar
Hello Saito-ites!
I would like to join the Club. So far, I have read every posting up until #7226 - page 290. It has taken me several weeks. Also, I was sad to see the passing (way back) of Bill Robison - what a Saito-guru!
I currently own two ships with Saitos installed. One ship is a Hangar 9 Fokker D-VII with an FA-82B and the other is a Great Planes RV-4 that has an FA-100 in the nose. Both engines are running fine - Ilove 'em!
In addition to joining, I have a question concerning an upcoming purchase - (my birthday is in Nov. & x-mas is right after that... so, some gift certificates may be forthcoming). =(8^]
My plan is to get a Great Planes PT-17 military Stearman and install either a Saito 170R3 or an FA-200R3. The GP Stearman specs say that the weight should be about 14-15 lbs. and the prescribed engine is up to a 1.20 cu in 4-stroke single.
> Question #1. Would the 200 radial be too much for this ship? It is only 4 oz heavier than the 170 and the GP PT-17 manual indicates a need for weight in the nose.
> Question #2. Does a Saito radial need any kind of fuel distribution add-on to keep the upper cylinder from running too lean while the lower cylinders may be too rich? If so, what would you members prescribe?
Thanks for any help you might be able to give!
–DJ
ID:	1523074   Click image for larger version
Old 10-25-2010, 06:30 PM
  #18782
Vertical3-D
My Feedback: (20)
Vertical3-D's Avatar
I wouldn't worry about the engine size or weight, but can't help with the fuel question...I fly a FA-130T on my 1/5 scale cub that most guys use .72-.90 engines on and it does just fine with the added weight and power, actually I think it flys nice than it did with my FA-91S on it...
Old 10-25-2010, 06:58 PM
  #18783
n6iap
n6iap's Avatar
I have the Great Planes Super Stearman with the Saito 170R3 in it and it is great. Been flying for about a year and you can see progress and some tips from me and other on the Super Stearman posts. The Keleo muffler makes it sound awesome and keeps most of the oil off the aircraft. The gas tank centers to the engine so fuel flow seems to be okay even in rocket mode.
enjoy...
jimm
Old 10-25-2010, 07:32 PM
  #18784
DPUltimate
Ok guys, still hoping someone has an answer to my orignal post (Post #: 18434). Does anyone know? Also,<u> I requested to join the club but have yet to hear anything back as of yet. Is the club still passing out numbers?</u>
Old 10-25-2010, 08:32 PM
  #18785
w8ye
w8ye's Avatar
Origianal: DPUltimate
Hi all:
I have a Satio 180 GK that was in my DP Ultimate. Unfortunately, the plane did not survive a left wingtip stall from about 25 feet up. The plane came in at about 70 degrees and broke the prop and folded the wings. As a result, I'm wondering what the acceptable run out is on the crankshaft. I have mine on a dial indicator and I'm indicating 5 thousandths of an inch run out. What is the acceptable amount that is still within tolerance? Thanks! <span class="info"> </span>
I think Dave uses .002" run out as his tolerance. It must be OK for his clients are happy with his work. It depends on how accurately you were able to get a reading off the tip of the crank. The threads present a problem in getting an accurate measurement.
I had a 125 with a a run out like you mention and I showed it to the owner. We went and ran the engine on a test stand last Christmas eve and we could not feel any abnormal vibration difference from any otherSaito this size and to view the blade tracking of the prop it was right on. So we forgot about the run out.
Maybe you should mount yours up and see how it runs?
Old 10-26-2010, 09:30 AM
  #18786
spaceworm
ORIGINAL: DPUltimate
Your original posts were convulated with a lot of info about crank straightening etc. It would be better to post your question as a stand alone post.
Same for your number request. Post it as a standalone post, and please do not yell, that does not work well.
You do not hear from the moderators on your number, you have to read the postings and look for it.
Regards, Richard
Old 10-26-2010, 09:38 AM
  #18787
blw
blw's Avatar
#708 David Johnston
#709 DPUltimate
welcome aboard
Old 10-26-2010, 10:06 AM
  #18788
spaceworm
Sorry, I stand corrected. My apologies. I guess posting in bold underlined text does get their attention. Mea Culpa.
Sincerely, Richard
Old 10-26-2010, 10:21 AM
  #18789
w8ye
w8ye's Avatar
I'm the one that made it Bold underlined, so it would be seen, as it was more or less originally embedded in another subject.
Old 10-26-2010, 10:48 AM
  #18790
blw
blw's Avatar
Are you saying my eyesight isn't good???
Old 10-26-2010, 10:51 AM
  #18791
David Johnston
Thanks Verticle &amp;n6 for your rapid/excellent information!
DJ
Old 10-26-2010, 11:12 AM
  #18792
w8ye
w8ye's Avatar
The first time the poster mentioned that he wanted to join the club, the statement was tacked onto the end of another subject.
Old 10-26-2010, 08:54 PM
  #18793
FNQFLYER
Ok  just to make it oficial in a stand alone post seeing as how I own 1x 30, 1x50, 1x56, 1x62, 2x65's an FG20 and a FG36 (with more to come finances permitting) do I qualify for a Club Saito number?
Old 10-26-2010, 08:59 PM
  #18794
spaceworm
Yes, you qualify!
Regards, Richard
Old 10-27-2010, 03:27 PM
  #18795
Vertical3-D
My Feedback: (20)
I only own a single saito at the moment, but seeing as I will almost certainly always have one do I qualify to join as well...I almost bought an OS 120 twin but am glad I replaced my saito with another saito...my FA130T may be old as dirt, heavy, and by todays standards underpowered but man is this thing cool on my CUB in flight...
Old 10-27-2010, 04:41 PM
  #18796
blw
blw's Avatar
710- FBQFLYER
711- Vertical3-D
Old 10-27-2010, 05:02 PM
  #18797
FNQFLYER
Thanks guys, nice to belong officially.  BTB electric models burn better than gas powered ones so I have found out, don't ask it was a very short very expensive days testing and the final cost still has to be added up.
Always new these new fangled things were not for me
Old 10-27-2010, 05:56 PM
  #18798
w8ye
w8ye's Avatar
If you guys put your Club Saito number in your signature line, you will always know what it is.
Old 10-27-2010, 09:03 PM
  #18799
mike early
mike early's Avatar
Any of you gentlemen ever tried an APC 13x9 on a Saito .82? Or maybe a 12x9?
Looking for speed on a warbird. But still need a bit of thrust to get her off the ground...
Old 10-27-2010, 09:25 PM
  #18800
johnfly
Hi all..... I am in the process of changing the bearings in a FA 82 a and noticed that the conrod looks not to be bronze bushed !! or actually looks like the bronze has been worn away on the top side of the crank end. does anyone know if this is suppose to be bronze or not ???
