Skymaster 1:6 A10 Build
#226
RE: Skymaster 1:6 A10 Build
ORIGINAL: pilot tw
Hi, Alex
Sounds good about the weight, the pylons with ordinances are almost 4kg,
Great Job...
Best Regards
Anton
Hi, Alex
Great Job...
Best Regards
Anton
Anton,
Is that the production or prototype weight? 8.8lbs for ordnance seems a lot when you have saved so much weight in the rest of the model??
Do you have pics of the painted ordnance yet? And anything from the paint factory of my A-10 yet?
Rgds,
Mark
#227
Alex,
That really finishes things off - especially the paint inside the nacelles.
That's a lot of decals!! Waterside or dry
Ralle has been a little generous with these decals so not all of them will be used. He recommended water slides for the ordnance as dry rubs would struggle with the tight curves etc... Having statred with them he was right. Dry rubs for the airframe and water slides for the gear and ordnance is the way to go.
Cheers
#228
ORIGINAL: schroedm
Anton,
Rgds,
Mark
ORIGINAL: pilot tw
Hi, Alex
Great Job...
Best Regards
Anton
Hi, Alex
Great Job...
Best Regards
Anton
Anton,
Rgds,
Mark
about the prototype of A-10 was 23.5kg dry unpainted and without the pylons and ordinances,
i just back Taiwan yesterday , so can not take the picture for your A-10, i will ask John, if the paint job is finish,
Best regards
Anton
#229
Mavericks are nearly done, notice the visible decal carrier sheet outline, This will disappear once a water-based clear is applied.
#230
Sweet!
I wish we had another pair of these mavericks, instead of those rocket launchers.... I hate those damn things [:@] I always think they look like they are the wrong scale..
I think its fair to say that I am getting that tad, slightest bit excited now!
Regards Al
Regards Al
#232
Ive modified the cluster bomb slightly to fit on the pylon where the rocket launchers go, Its not scale but then I don't suppose you mind Let me know if you want me to go ahead and do both. There's loads of white decals on these bombs which is scale but I cant help thinking its a bit much and seeing that its not going into a scale comp what do you guys reckon? I've still got the end portion of the bomb to paint.
Cheers
Cheers
#233
Love it thanks.
I do think there are a few too many white rectangles on them mind.... Mavericks look nice and detailed. What does the hand written text on them say?
#234
I'll take some of the white placards off, I didn't really like how they had turned out. I'll add some more yellow text to the other side too. I'm pleased with the Mavericks if I had more time I'd cut the nose off and make a clear plastic part with a little internal detail but If I want it finished soonish the black nose will have to stay. Just been called out to work today so no more progress until Sunday It's nearly there just the ordnance and a few little bits on the airframe and its yours...
#235
Ordnance is all done, I'm just waiting for it to stop raining so I can do the clear. The sidewinders are OK but they are the least impressive out of all the ordnance. I need to re mount them on the rack as the way SM have done it they don't line up with each other. They could do with the fins being cut off and new sets applied from D4S. I know I'm a bit fussy but it would look better...
I got a PM regarding the strut compression under full weight and the gear door set up so I've attached a picture.
#237
Hello Alex48:
The main struts compression in your picture is OK. In fact, compare to real thing, it is still a little higher. The other thing that I find in your pictures is that you'd better to rotate the brake 180 degree to place the brake line nipple on the downside to avoid the nipple be damaged by compressed strut and please inflat the main tires to 143mm of diameter.
#238
Hi Likai
I've forgotten about pumping the tires to that diameter, thanks...
I turned the hubs around as I didn't like the brake line so visible, it doesn't snag the nipple even at full compression but I'll double check again. I use the small bore BVM brake tubing which is much better and more discrete than the 3mm SM clear tubing that's supplied.
Cheers, Alex
Cheers, Alex
#239
Its nearly there now
All the ordnance is finished, I just need to repair the cockpit as it was damaged in transit (again [:@]), glue the little scale details on, make a cradle and do a few little jobs. When I do another the aerials will be the first thing I do, this way I could make them removable. Unfortunately its not possible to do this now as everything is already installed. Its a shame because no matter how careful you are they are going to get knocked off at some point.
Alex
Alex
#240
Alex, what a master piece ypu did there! and I haven't even start mine, but I order all the electronics and air equipment so it's a move in the right direction
After my trip to Germany we will be moving at very fast rate thanks to all the pictures and info you provide us. Thank you so much!!!
I can't wait to see pictures and videos in the air.
Gonzalo
Gonzalo
#242
You can order it in either state.
Pylon complete set (painted) $ 495.00 USD / order no. AP1108P
(buy the A10 combo on pre-order and get the Pylon set for $ 295.00 USD)
All ordinance kit without pylons (painted) $ 995.00 USD / order no AP1109P
(buy the A10 combo on pre-order and get the Ordinance kit (without pylons) for $ 695.00 USD)
Pics of painted ordnance should be available from Skymaster next week.
Rgds,
Mark
Rgds,
Mark
#243
1 Post
Alex, looks very nice indeed - even more incredible is you work in a small room which always seems immaculate!
One question, did you get a chance to measure the fan diameter for me?
marcs
marcs
#245
No not the camera as I've been using my SLR recently with a fast lens so the pictures are a decent representation (in post 235) even though they are taken at night under artificial light. Luckily Alis seen the model and likes it so far. The base coat on the gear like the full size in this scheme is grey not white which is why they might appear to darker if you were expecting a white gear.
#246
Hi Marc
The diameter of the fan unit is 153mm and depth around 70mm. Please don't use these dimensions to fabricate anything because they're not accurate but should give you a rough idea. Perhaps someone else with a set of fans that aren't installed could give some accurate dimensions.
I do all the building in a spare bedroom, it's a little tight at 4/4 meters but its warm...........the only down side is its on the third floor and most of my customers take the piss when they visit, well mainly Ali but I wouldn't expect anything less If it starts to get messy I cant find a thing.
#248
Marc,
If you need exact dimensions, my A-10 should be here before Bickley so you can bring your calipers and measure the fans before I fit them. You can then also admit what you're up to to need the dimensions
Cheers
Mark
Cheers
Mark
#250
Lol.....I hope not as the house is being redecorated and my wife would kill me
Come on then Marc what you going to stick those fans in
