CARF Ultra Flash Evo build thread +
Old 12-13-2021, 09:56 AM
  #226
737Driver
737Driver's Avatar
OK, issue solved with CARF Reps, thank you all!!!!
Old 12-13-2021, 11:41 AM
  #227
jvaliensi
Hi,
What was the solution?
Old 12-13-2021, 12:24 PM
  #228
Dave Wilshere
Thanks Dave, Both Ray and Mike are working on it!
Yes, Andreas WhatsApp message me saying they were working on it…that would have been about 11pm his time!
Old 12-17-2021, 11:00 AM
  #229
jetpower
Another quetion
witch type doe carf use?
notised that when instaling the pipe the rear former that also holds the taiplane.
on one side there is no glue on one side of the former.
i think they forgot to put glue on that side
should i us 24hr epoxy with micro baloons and cotton flock or use hysol 9462
Regards peter
Old 12-17-2021, 11:20 AM
  #230
Dave Wilshere
That area is less critical, but if you have 9462 that is perfect. Or 30minute epoxy with flock/talc
Will let the factory know it was part missed. Thanks
Dave
Old 12-17-2021, 11:27 AM
  #231
scoeroo
My Feedback: (9)
scoeroo's Avatar
I brought this to note about former gluing and a few other issues ages ago and was blown-off .......
What's QA sticker number & order number ?
I also sent a communication to Adraes G. and guess what ......not one response
comp arf has piss poor QA !
That's my opinion -
Old 12-17-2021, 12:12 PM
  #232
jetpower
will use 9462
My fuse does not have a number written in it
regards peter
Old 12-17-2021, 12:39 PM
  #233
737Driver
737Driver's Avatar
Hey Peter, I know your all set on the glue front, that Hysol works AMAZING!!! I believe that glue you took a picture of is called CAB-O-SIL. That stuff dries hard as a rock!!
Old 12-17-2021, 02:41 PM
  #234
jetpower
thanks for the answer bud i cant get a hold of that stuff bud i already used hysol.
regards peter
Old 12-18-2021, 08:42 AM
  #235
xradarusa
My Feedback: (8)
Would sure like to see some more pics of radio installations under the canopy. On my trainer type jets I have just ran two 4200 nimh 6 volt batteries into two heavy duty normal type switches and then on into the radio. Would this work with 11 high end digital servos on my Carf Ultra Flash EVO?????? Would really be nice if this installation did not turn into the usual rats nest...........thanks in advance.
Old 12-18-2021, 10:09 AM
  #236
737Driver
737Driver's Avatar
eradarusa.....
I'm at that stage of install, getting the equip tray planned out. When I finish I will post some pictures. Your servos, are they high voltage? If they are, you're defeating the purpose of that voltage of said servos with Nimh. Jam some Lipos/Lion in there, may need the extra weight for CG purposes
Old 12-18-2021, 11:26 AM
  #237
Rudeboy
Rudeboy's Avatar
Yes it will work.
But using 2 batteries and switches and then just connecting them in parallel on the receiver end is a bit of a weird setup?
The only "protection" you get out of that setup is against switch failure?
Old 12-18-2021, 11:36 AM
  #238
xradarusa
My Feedback: (8)
Am going to give it some more thought. And you should see some of the weird looks when explaining it at the field. Thanks.
Old 12-18-2021, 02:08 PM
  #239
Rudeboy
Rudeboy's Avatar
I would say, if you want to keep it simple: use something like a Powerbox Sensor Switch.
It gives you redundancy on your dual battery setup. And things just keep on running should 1 battery fail + you can tell from the led light something is off when you're back in the pits.
If you wanted to get fancy you could have a voltage sensor on both packs, feeding telemetry back to to you while flying.
Old 12-18-2021, 02:14 PM
  #240
Dave Wilshere
Two switches/ batteries is a time bomb. One battery goes bad it takes out the other. The Flash series of jets were designed around the Powerbox Sensor switch, the V3 is another step forward.
You can use your 5N NiMH packs with a Sensor switch if you wish
Old 01-04-2022, 11:11 PM
  #241
737Driver
737Driver's Avatar
OK Evo guys!
Thanks to my friend Colin, he held my hand for the Unilight install. I wanted to share my experience with the install. I took a few pictures along the way, the install was really easy and straightforward. Easy Peasy!!!!
flaz (08-24-2023)
Old 01-05-2022, 04:25 AM
  #242
scoeroo
My Feedback: (9)
scoeroo's Avatar
Did you do a strobe on the bottom of the fuse ?
Old 01-05-2022, 07:19 AM
  #243
txshan130
My Feedback: (114)
txshan130's Avatar
OK Evo guys!
Spoiler
Hey Tom...which lights were those?
Old 01-05-2022, 08:12 AM
  #244
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Thanks Tom, the more pics and light info the better, seems we all are interested. Nice scheme!!
Old 01-05-2022, 07:01 PM
  #245
737Driver
737Driver's Avatar
that’s next, doing those tonight. I’ll post pics of the install, but I’m following Colin Bell’s install.
Old 01-05-2022, 07:03 PM
  #246
737Driver
737Driver's Avatar
Hey Brian!
Uni-Light. Can’t say enough how nice these lights are, the shipping was Uber fast! I ordered the lights on 22 December and got them 27 December!
Old 01-05-2022, 07:08 PM
  #247
737Driver
737Driver's Avatar
no problem! I have to say I was really scared when I tore into a brand new wing to put these things in but it’s been nothing but easy. It’s like they were meant to be there the whole time.
Old 01-11-2022, 08:49 AM
  #248
737Driver
737Driver's Avatar
Here’s a little progress report on the Uni Light install. I used hot glue to install the lenses and light assy. The nose door light hot glue is a tad messy for me, but that light ain’t going anywhere!
Lense installed
Light install with hot glue
Hole drilled
Old 01-11-2022, 08:59 AM
  #249
737Driver
737Driver's Avatar
Had to remove that black thing, door wouldn’t close with the EV 40 gear. It was plastic so not sure if it was necessary for heat sync
WAY to much hot glue
Old 01-11-2022, 05:18 PM
  #250
jvaliensi
Hi,
Anyone have an Ultra Flash they wish to sell?
