Old 10-21-2013, 12:20 PM
  #25601
johnpope60
johnpope60's Avatar
I have a 17 cc and a 21 cc four stroke gas. Both of these engines idle great and run great at higher rpm. But at 1/4 throttle they both sputter. Any ideas ? Thanks
Old 10-21-2013, 01:21 PM
  #25602
tailskid
My Feedback: (34)
tailskid's Avatar
Originally Posted by FNQFLYER
On the 30 thing, my old flying mate is at the "not the nationals" old timer comp at Cootamundra as I type this. (I would have been there if it wasn't for the dammed shoulder, which is slowly improving ) He has a duration model (vertical drag racer) powered by a Saito 30 on "steroids" (read nitro) but we both agree that this is not really the best application for the little engine. But never the less it proves the adaptability of the Saito range.
I would love to see some pics of this plane......
Old 10-21-2013, 09:42 PM
  #25603
FNQFLYER
Once I work out how to add photos etc I will start putting that stuff up on the posts but until then you'll have to create mind pictures. In the mean time attend a SAM comp near you you'll see all sorts of interesting engines and applications / adaptions of same not to mention the variety of airframes and characters operating them.
Old 10-22-2013, 04:27 AM
  #25604
Hobbsy
Hobbsy's Avatar
FNQ, for picture loading,
Reply
Go advanced
Manage attachments
Add files
Select files
Choose file location, (My Pictures, My Docs) etc.
Upload
Check, insert inline (1) or more
Select Done. The picture loader will store your chosen pictures so the next time you want to load the same picture or pictures just drag them to the Insert Box.
That looks and seems complicated but will be automatic after a couple of times.
Old 10-22-2013, 10:10 AM
  #25605
cubfloater
Originally Posted by cubfloater
Thanks Hobbsy, I thought WD40 wasn't good for engines and I just sprayed on top while I was trying to work the valve. I then dried it all off when I tried heat. I've used PB Blaster for some really stuck bolts so I'll try that and I have tried pushing it down some. Will try all tonight. And I want to add some caster to my fuel but don't know where to buy it. Is there any local stores that sell it? Or where can I order? Thanks Hobbsy!
Well finally tried the PB Blaster overnight and no luck. Sprayed in a little more and will wiggle on it tonight to see if any movement. If not I'll try soaking in fuel to see if that does it. Then I guess I'll pull out the wrenches...if I can find them. And I forgot to try the first simple idea which was pushing it down and releasing as Hobbsy suggested. I'll try that shortly. Hope that does it. Will update you on what works. Thanks
Old 10-24-2013, 03:13 PM
  #25606
cubfloater
more PB Blaster, no luck, soaked in fuel still no luck. Guess I'll have to take apart. Will try tapping or wiggling a little more just in case before the dismantle.
Old 10-24-2013, 03:54 PM
  #25607
bob62
My Feedback: (28)
bob62's Avatar
If all has failed get a bigger hammer, works everytime
Old 10-24-2013, 07:45 PM
  #25608
Hircflyer
Hircflyer's Avatar
I have a older 1.20 that needs to be overhauled. Can anybody recommend some who does a good job?
Old 11-01-2013, 01:03 PM
  #25609
Hobbsy
Hobbsy's Avatar
http://bj-model-engines.com/home.html
This gent had a good reputation before he was a known quantity, he may be the repair center for RCV also.
Old 11-01-2013, 03:16 PM
  #25610
bob62
My Feedback: (28)
bob62's Avatar
I do my own, they run good.
Old 11-01-2013, 03:22 PM
  #25611
Hobbsy
Hobbsy's Avatar
Yep, DIY guys rule, but are always glad to help out not so DIY guys.
Old 11-06-2013, 01:54 PM
  #25612
FNQFLYER
Hope every one out there is still alive and kicking. On twins, on of the old guys at the club resurected a gold knight twin (capacity unknown) on the w/end. It was seized from miss use and not being used for a couple of years. Poured fuel down the plug holes and rocked the prop until it turned over. Oil on the valve stems and gentle tapping until they moved, replaced the old plugs and connected power and hit it with a starter. Result my old flying mate now needs a new shirt, the old one was blasted with a mixture of rust, carbon, old oil and fuel but the bast ran. Very noisy but nothing a set of new bearings won't fix. Now onto the next of quite a few Saitos in this collection.
Old 11-12-2013, 01:41 PM
  #25613
Red Fish
Do you guys know anything about the reliability of the larger Saito gas engines. I know. Saito got off to a poor start with gas ,but don't know how they have progressed. Reviews are hard to find. I am looking at the 57cc twin gasser. Perfect for my project , but I don't was something unreliable.
Henry
Old 11-12-2013, 02:20 PM
  #25614
Hobbsy
Hobbsy's Avatar
Red, more Gas Saito guys will see this question over in the Gas Engines Forum. You'll get lots of responses there
Old 11-12-2013, 08:19 PM
  #25615
w8ye
w8ye's Avatar
If you are going to run a gas Saito, you had best have a good knowledge of Saitos as well as small gas engines. The original Saito inductive pickup ignition wasn't that successful and the Saito branded 1/4-32 spark plug has been prone to foul and the insulator to have shorting problems. The present version ignition module is made by RCEXL with a Hall Effect pickup but it says Saito on it. The 1/4-32 boot is made for the Saito spark plug. The CM-6 boot is the same as RCEXL.
The carbs up through the FG-21 have very poor fuel draw so the tank must be mounted right against the firewall and on centerline with the carb.
To tune the carb on the test bench is just preliminary to adjusting the carb for effect while flying in the air (fly-adjust-fly again).
The Saito/Walbro barrel carb on the larger Saito engines is somewhat of a failure for there are no diaphragm kits available for it from Saito, Walbro, or after market and a couple years down the road when the metering valve diaphragm goes bad, you are stuck $96 and have to buy a whole new carb from Saito.
You must run a 20:1 gasoline-synthetic oil mix in these or risk loosing the big end of the connecting rod.
Old 11-13-2013, 04:50 AM
  #25616
Rudolph Hart
Rudolph Hart's Avatar
Red plus one on barrys reply.I run 25 to 1 with klotz 200 synthetic,plugs run a light brown at factory settings.Don't feel overly inclined to change them as the engine pulls factory specs on the benchmark prop.Did i mention how good they sound when you throttle them up?
Old 11-13-2013, 01:32 PM
  #25617
FNQFLYER
Old fart, have you tried that oil HHQ is marketing as Saito oil suitable for gas engines? I am about to get the Storch up and running (in the next month or 2 ) with an FG20 in it. All the Fg20's I have seen with the modified carby supplied by HHQ (from Saito) seem to run ok with minimal fuss. I also have an FG36 and those comments W8ye have me a bit bothered. I have read a lot about ignition failures (on both saito and os etc) but a lot of it can be put down to correct handling (particularly leaving the ignition switched on after engine shut down). Your thoughts please
Old 11-14-2013, 06:28 AM
  #25618
Rudolph Hart
Hi fnq don't worry to much about the way saito have there fourstroke gas engines set up now,tho they jumped in at the deep end first,i wonder at how long they benched or flew the engines before they offered them for sale.I think the problem with the fg30 and 36 initially was that the ignition system barry talked about(plus every single outsourced damn carby)was really average.They still sound awesome and i think we should open up this forum and include them also.They may not have that special bark that nitro saitos have,so what,we all like flying them.
Old 11-14-2013, 08:34 AM
  #25619
Hobbsy
Hobbsy's Avatar
Pete, I think that Barry and Jim would concur that talking Gas Saitos here is just fine, after all a Saito is a Saito is a Saito. I only recommended the Gas Forum to Red because there is lot of info there already. Not all of it good or accurate but there none the less. Jim straightens it out where needed.
Old 11-14-2013, 08:55 AM
  #25620
hsukaria
I need help deciding between a Saito FA-82 and FA-91. I have a 60-size sport plane, a Phoenix Extra 330S that has been using a 74 and a 90 2-stroke glow engines. But now I would like to switch it to 4-stroke. The plane weighs about 7.5 lbs. I would like to get unilimited vertical so that I can do some 3D flying also. Would the 82 be enough, or should I get a 91? I already have an FA-82 on a 7.5 lbs Great Planes UCD46 and it gives unlimited performance. Weight or space are not an issue with the Extra 60.
Old 11-14-2013, 11:58 AM
  #25621
Red Fish
Thanks. I will try that.
Old 11-14-2013, 05:14 PM
  #25622
cubfloater
how do you know if your bearings are worn out. I thought one I had needed it but then I got another and it may but the first ones seems smooth and quiet compared to it and others I have. Would it be loose or just noisy? Thanks
Old 11-14-2013, 06:13 PM
  #25623
Rudolph Hart
Huk if you were happy with the 90 two stroke you should probably go for the 125 saito even if that means putting the flight pack in the tail.
Old 11-14-2013, 06:18 PM
  #25624
Rudolph Hart
Cub position yourself in front of the engine then gently put a hand on each prop tip and rock the prop tips back and forth (towards and away from you)if you feel ANY movement the bearings are toast.
Old 11-14-2013, 06:45 PM
  #25625
Hobbsy
Hobbsy's Avatar
Pete, I'm not so pessimistic about a fourstrokes power, paper hp on a fourstroke doesn't look so good, flying hp looks about the same size for size. But that's just me. Between the .82 and the .91, the .82 turns a 14x6 close to what the .91 does but weighs less. I call it a toss up.
