Hi Guys, I have a Saito 1.5 now and want to place it on a A. Works 260 Pro...that is a profile airplane. I had a 22cc gas engine on it but would like to try the Saito 1.5 on it. It will be run with a spark ignition from Adrian at CH ignitions. Do you think it be ok as far as power & vibration goes? Thanks Capt,n
Hello,
I just acquired a used Saito 82a, so I guess I can take a number to join the club?
I am totally new to 4-stroke glow engines. Given the engine is used I am doing a minor teardown to see what parts need replaced. The engine has barely run, after removing the backplate, the crankshaft is rust free and the bearings look new. It seems to have been properly stored with after run oil. The intake and exhaust valves look pristine. The only bad thing is that most of the rubber seals seem dried out. The pushrood cover seals are cracked so they will need replaced. Also, I am thinking about removing the cam cover to inspect the cam but unfortunately the gasket set for the A version is backordered from Horizon. Does anyone know if the gasket in kit 82b32 will fit? (I understand this is for the "B" version). If not are there other alternatives?
Any upgrade advise is welcome. Since I am tearing some of the engine down, might as well go through all the replaceables.
WAIT! I missed something.
I could have sworn that the reason gassers use ~ 5% or less oil was due to the use of needle bearings in the big end of the con rod.
Who suggested the lubricants used in gas mixes were better? I don't believe it! The ONLY benefit *I* see is that you CAN get synthetic lubes that will burn with the gas charge and I don't castor does.
CR
BTW did you ever do a write up on trying gas in alky Saitos? It might make interesting reading.
CR
Tiz indeed jim but you've barely scratched the surface.Girlfriend 2.0 comes as a complete software package which also has tears 1.0,jewellery upgrade 6.0 which opens automatically,and mother in law 5.0 which can turn nasty and is unpredictable by nature.In the event of a system crash it automatically drains your bank account.Aaah..the good ole days
Castor still has the highest flash point.......unless someone can show otherwise. Also, castor starts to protect with varnish when getting that hot. Synthetics turn to ash.
WHAT?!?! The moderator trying to get us off the subject of revolving girls? For shame! Well, maybe not. When I had the chance, I made my choice willingly and (mostly) knowing the end result. I still like it, mostly.
The problem *I* have had with castor turning to varnish in 4 strokes is that it takes a lot of heat for that to happen - like right at too lean a run. The somewhat richer (~200 rpm) runs with castor lead to the crud that tends to make things like valve stems drag and things go down hill very fast once that becomes an issue. That is what *I* have experienced. While I am positive there are more knowledgeable folks out there who it is great and wonderful for, it just has not worked for me.
Edit (12-06-2013)
I called Horizon to ask if the cam cover gasket included in SAI82B32 (gasket set for 82b) fits the cam cover in 82a. The answer was yes. If anyone else needed to know.
Edit (12-17-2013)
I received the engine gasket set part number SAI82B32. The cam cover gasket does not fit the 82a engine crankcase. I guess I must order set SAI82A32, which is out of stock, or make a gasket out of a brown paper bag as suggested by Hobbsy
Edit (12-17-2013)
CR
AAh the perennial discussions about women and castor and synthetic oils. A string could be developed I am sure but with regards to modern synthetics, I use the helicopter oil by Klotz and Cool power in my Ys's and now for simplicity in all my engines. However I am looking at that new red oil Saito are marketing for gas engines as a possible subsititute. And now for a little variety I am taking my other 1/2 to the local hobby shop so she can buy me a new as yet undetermined toy. Catch Ya
I keep telling her we need dog burgers for dinner.
