#2577
By the way, I'm going to put some serious hours on my Saito .56 tomorrow, I moved it from my RCM 40 to my Sig LT 40 today. I tried mightily to put the .72 on there but where I have the mount holes drilled in the firewall is just too skinny.
#2578
Dave:
You were included in the address line as a sort of "Info Copy," that's all other than the implicit question about whether the TNC tach has a selexctable gate time.
Bill.
Bill.
#2580
ORIGINAL: N3OKI
Hey guy's thanks for the info on the 40. I think after the 2 larger (65in span) profiles are built I will order in a 40 and build the 25 size MoJo. Should be neat to have a small 3d plane.
The wife thought i had lost it yesterday, when upon arriving home from some honey do errands she looked out and saw a new 6x10 enclosed trailer attached to my vehicle. She did not go for the "it followed me home. Can I keep it?" line. So i had to tell her the truth. Hit a hell of a sale att the local Lowes. 2000.00 on sale. They miss priced it. Priced as a smaller trailer. Bt the manager gave it to me as priced. I could not pass it up.
she hit me anyway [&:]
Although my constant griping about how my planes are now too big for the family taxi has elicited the concession that I can now go buy a big trailer (again she balked at the idea of a new pickup) to put them in if I like.
I LIKE!!! I LIKE!!
#2581
Banned
Left field?? I don't play left, I'm a right field guy. The only reson I asked the question was no engine will run with at that steady an rpm. There is a thing called standard deviation and by definition the rpm will hover around some base number, say 14,000. So it would be 14,000 + or - a small error. Even closley regulated power supplies have a +or- error and they are extremely accurate. May be small but it's there. Ain't nothing in the world perfect. Even our electronic scales as accurate as they are have an error. Nothing you can do about it. 1/10 of 1% of 10,000 is 10rpm and I know your tach isn't that accurate. You are talking about 1/100 of 1%.
Anyway I just wondered what tach you were using.
#2583
Bill,
I think that you don't need ovens for modern crystal circuitry unless the temp drops quite a bit. I have an oven switch on my R-390A but nobody ever uses it from what I can tell unless in artic conditions. Anyway, not trying to start a p. contest with anyone........
#2584
Banned
ORIGINAL: William Robison
In order for any counter to be accurate to a untis count, it has to have a gate time, the counting interval, equal to the period being measured.
In other words, for a tachometer to be correct to ONE revolution per MINUTE it will have to sit there counting for an entire minute before giving a reading. Few people would accept such a thing.
What we actually have are devices that have a much shorter gate time, and obviously, less digits of precision.
What modern tachometers do is measure the time interval between when each blade passes in front of the light-sensor.
This means that the accuracy is not dependent on the number of measurements made, providing the engine is holding a constant RPMs.
For example, if your engine is turning at 10,000 RPMs with a 2-bladed prop, there will be 3 milliseconds between each blade passing the light sensor. No matter how long you measure it (providing the revs are constant) there will always be a 3mS interval.
Exactly how many digits of precision are measured depends on the tachometer's time-measuring resolution.
If the tach has a measuring resolution of 3 microseconds then it will be accurate to 3 digits. If it has a resolution of 0.3 microseconds then it'll have a resolution of 4 digits, etc, etc -- no matter how many times you measure that time interval.
What the gate time does is "average" the readings for a given period of time.
A gate time of 1 second will effectively take a minute's worth of pulse-width measurements and return the average of those readings. A six second gate-time will effectively do the same, but over a six-second interval.
The results returned are the *average* RPMs during that time.
This means that a longer gate time may actually produce *less* accurate readings. If you set the gate time to (say) 5 seconds, and your engine has a brief hiccup that causes the revs to drop for a second or two, the average reading will not correspond with either the actual RPMs at the end of the gate period -- just the average -- which will be lower.
Having said all this, most tachs have a gate period of about 1 second or so. This is long enough to provide a relatively stable reading even if the engine RPMs are varying a little (as they inevitably do) but short enough to reflect the effects of any real RPM changes in near enough to real-time.
#2586
XJet:
You are quite right, sir. I had not thought of measuring the pulse interval. But even a minor clock error in such a tach would lead to a gross error in the rpm reading.
Thanks for telling me about the alternate method of measuring. But then you go on to mention the one second gate time, so I'll guess what we have are totalizers as I was mentioning, rather than the intervalometers measuring the time?
Barry:
I haven't seen an R-390 for years. A real boat anchor that would heat your house in the dead of winter, but if you had one working right you couldn't ask for a better HF radio than Mr. Collins' big box.
My old frequency counter, ten digit, was certified down to one cycle on readings up to 99.999999 Mhz, but only if I gave it a 30 minute warm up of the crytal oven. It did have selectable gate times of 1.0, 0.1, 0.01, and 0.001 seconds, with auto decimal placement.
Bill.
Barry:
Bill.
#2588
Banned
Speaking of "old tachs" (and Saitos of course), I wonder if those old reed-based tachos would read half RPMs on a 4-stroke because it only fires once every two RPMs?
Does anyone (apart from me) remember those old reed tachs?
#2589
I have one of those old reed jobs. Seemed to be sympathetic to harmonics
http://www.humboldtmfg.com/c-2-p-284-id-2.html
H 3753 $29.95 is the third item down.
These things were sold in the model magazines in the 50's - 60's for around $19.95
I have one. It is actually rather crude compared with today's electronic tachs.
It takes more skill to use one than the current electronic tachs
To try to keep down harmonic sympathy, you slide the wire all the way out before holding close to the engine.
You then draw the wire back slowly into the holder. At a certain point, the wire will wave back and forth at the same frequency as the engine. You seek the widest sympathy vibration. Then read the rpm off the calibrated scale on the holder.
The device had a pocket clip so you could carry it in your shirt pocket. Mine came in a leather belt clip pouch.
It was called the Vibra Tach and was very durable if taken to the field.
The link above is advertising the device for use with concrete vibrators. This is a rugged environment. The Vibra Tach is the best device for this application due to its ruggedness.
#2590
ORIGINAL: EMVIN
#237
mwarren400, I'm glad to hear the good news, I have a 220 and will be fireing it up this weekend for the first time. What size prop did you use? What kind of fuel?
#237
Used a 20x8 Master Airscrew Classic (only thing available in that size) with 15% Cool Power and 4 ounces of Castor mixed in to the gallon
#2592
Bill
Re: intake stacks ( sorry to rehash this old stuff )
quote:
Sealing the intake stack
I never said anything in particular about the o-rings, only that the gap between the carb body and the stack had to be sealed for it to work properly.
Once I got the part I had a better picture of what in does. I read back through the "Bill's Guide" notes ( thanks ) and I have to ask....not being a smart azz....does the Saito Intake Stack have air leaks by design ? I take it that the part is not made work like a sealed intake air box / filter on a gas engine, rather to catch fuel spray/fog and is just not that critical to be sealed. Thanks, sorry to drag this out.
over and out![8D]
Drums
Great Weekend to All!!
Bill
over and out![8D]
Drums
Bill
#2593
BillD:
The gap remains from the early days when all the Saitos had a sliding choke plate in that gap.
The manual chokes have been discontinued, but the stacks have not been redesigned to close the gap. So we have to cobble up some sort of seal between the carb and the base of the stack.
Bill.
Bill.
#2596
Jerry:
Generally, not enough prime, or the throttle not far enough open.
Do be careful, with a full tank the engine can draw fuel through the pressure line and keep running. The exhaust heat going out through the carb can damage the o-rings, don't let it keep going. I have actually melted the element out of the Bru-Line air filter with just a couple seconds reverse running.
Bill.
What causes the engine to start backwards? New Saito 125.
Bill.
#2598
Banned
All Saitos didn't have a choke plate in some gap or even a gap. The original 30, 40, 45, 80twin had a clamp on choke that was held by an allen screw. The twin carb 80 and 90 twins didn't have a choke at all. Just my finger.
#2600
At Ford NVH (noise, vibration and harshness) school we played quite a bit with the reed tachs. With carefull adjustment you could isolate Crankshaft and Camshaft freequency, independent cylinder firing and even auxillery frequencies. Interesting thing is that to get a tool that would do everything a $10 Reed Tach, available at any small equipment shop, is capable of, you had to spend thousands from a specialty dealer. Of course the expensive unit would do so much it was silly, and invaluable.
