Ripmax Xcalibur Sports jet
DenisFerrari (05-26-2022)
#2604
Dented my Xcal and tore right wing off and broke both booms. 100% pilot error, not flaring it off enough and allowing it to bounce, then hit runway side marker.
Funny enough, the fuse and left wing got away without a single scratch - literally.
Has anyone any idea as on where one could get a new set of wings and booms in sport yellow ?
I'd hate to write it off after merely 60 flights...
#2605
My Feedback: (53)
Dansy (07-18-2022)
#2607
Dave,
what exactly do you mean by that ?
I just wish to know if i'll be able to get the parts or will i be forced to write-off. Waiting is not a problem, ie i am aware of it...
The following 3 users liked this post by Dave Wilshere:
DenisFerrari (07-21-2022)
#2610
My Feedback: (7)
Ok, it’s been about 7 months now since I got the X back with damage, after completing the Kingcat’s refurbishment and maiden flight about a month ago, I worked on something easy ( GP Cherokee brand new, maiden to be done when we get a dry day )
I was in the garage looking at what should I work next and the X jumped right in front of everything ( I do have lots of projects and repairs to work on 😬 )
And here we go, should be ready in about a couple of months ( hope so 😁 )
First was to remove all the internals ( 7 months ago ) tonight, I glue the cracks on the fuse using thin CA to start with, next is to add fiberglass patches to the inside of the cracks then fix the outside of the damaged spots, I don’t do painting, my friend will have to do that, then some bulkheads will have to be replaced, will be adding some Hysol here and there.
Correction on the time line, it has been over two years since the mishap.
DenisFerrari (01-12-2023)
#2618
My Feedback: (7)
I replaced the broken fork ( thank you Johnboy2 for it ) the nose strut needed a new pin, made one, had the release pin size for it already and found a small bent on the nose gear pin track, no sweat, a little filing and it should work as normal, will order some part from GJC this week.
#2620
What receiver and turbine batteries are you guys using?
I need to replace mine, I was using 2 x Turnigy nano-tech 3000mAh 2S 20C LiFe receiver packs connected via a Failover Regulator Switch and it looks like the recent heatwave knackered them along with some other batteries, ho hum.
I think I'll replace the turbine battery too at the same time just in case - that's a Flightmax Zippy 2650mAh 2S 40C LiPo
#2621
I’m using a Pulse 3S LiPo. I think it’s 3000 mah. That’s on the turbine control unit. I use a 7.4V Duralite lithium ion 2S2P pack for my Spektrum 10100T receiver. No regulator. I stopped using regulators 2 airplanes ago. Just run Hi voltage servos. Both batteries are in the nose cone section.
BikerDon (07-03-2023)
#2622
DenisFerrari (07-08-2023)
