Official Tamiya TT-01 Thread
#2651
Yes they are correct and "fit". Just the length of the couplers is short by maybe 3 mm on each one. I can slide the feathering shaft out like that.
#2654
ferrari on chrome wheels. blasphemy!! haha. j/k. Its looks just about right, my body posts are shorter than yours. Is your body still hitting the ground?
might want to widen the rear end. looks kinda funky with the wheels so far inside teh body
Ferrari <3
Ferrari <3
#2656
ON, CANADA
get some offset wheels to fill in the wells, otherwise it looks like cars when they have to put the spare tire on. u know the dinky, really skinny tiny one with the black rims? haha.
#2657
blech thats what i thought i would have to do... do you know what offset it is?
damn ive been throwing money right and left lately lol
#2658
http://www2.towerhobbies.com/cgi-bin...?&I=LXETJ1&P=Z
there are 2 longer and 2 shorter axle versions. use the longer ones with the wider hexs in the kit and your FXX will look like mine. I got the FXX kit so mine already included the longer axles
#2659
Here's my TT-01R with the recently installed Venom Fireball Modified 19t motor! Wahoo! I'm not sure how good of quality the motor is, but it seems good to me!
#2661
I seriously have to fix the problem with the nose.. just look at the pic, its like 4 mm above the ground if not even lol, I've just been rocken out my Raybrig NSX lately (basher body) cause I realy dont want to mess up the FXX anymore then I have...
Any suggestions?
Any suggestions?
#2662
you should try this rims for FXX: offset +4 mm:
http://www2.towerhobbies.com/cgi-bin...?&I=LXPFC1&P=7
i got some for my RX-7...on TT-01D, for using with ABS pipe
#2663
thanks. yeah they are the stocks. kind of beat up from off the powersliding and drifting. I have 2 sets. one has the stock slicks(never used, just put them on for super shelf queen mode with the body) and this set now has new HPI X-patterns since the last tires exploded
ORIGINAL: pimpedarse
Hey Mindwreck... are those rims stock with the Fxx kit? or did you buy them seperatly...
lookin good.
lookin good.
#2664
how low is the rear? looks pretty high in the pics. my car has the front body clips that are under the body on the 2nd hole from the bottom. and the rears in the 3rd or 4th holes. about a good 1cm off the ground. good on nicely paved parking lots but i still don't want risk messing up the body.
I actually need to order new body posts since my posts were cut just for this body and it won't work with my 350z and lambo bodies.
edit: if the body clip positions don't work for you. what i usually do it bottom out the car out.. then put the body clips in so when im driving and the suspension bottoms out, the lowest the body will go is ground level.. get what my mean?
Any suggestions?
Any suggestions?
#2665
welcome to the tt-01 family cornel. glad you accepted my invite to the thread. are you going to run brushless in your tt-01? if you do i highly suggest drifting on drift tires or hard tires. much faster and fun-er, just watch out for obstacles. faster speeds = harder the crash. fall in good fun though
ORIGINAL: cornel4web
#2666
10x...no motor upgrade for now......me is like simple and cheap, course I will run on drift tires, that's how it comes becouse of the DRIFT specs...also planning to get some ABS or sushi
#2667
NL, CANADA
Hey all remember me? I am finally going to order my tt-01 tonight when I get back from work. I decided to get a tt-01 skyline kit cause it has LED lights and way better looking rims than the subaru. I am also going to pick up an alloy drive shaft and bearings. Then after I make some ABS drift tires I should have a good...slow drifter
Any advice for an electric noob?
Here is the car http://www2.towerhobbies.com/cgi-bin...?&I=LXLWS2&P=0
#2668
Hi, need some help with tt-01 running really hot. So hot the whole thing just stops running for a few seconds then starts up again. Its quite a new motor (Corrally 19T). Good it be the speed controller thats causing the problem or motor?
#2670
yeh if its the standard tamiya ESC it will struggle on some 19t motors and its meant to be a 23t limit esc,even my 21t runs hot in high temp weather []
#2672
haven't seen you in awhile.... great choice for a kit. What kind of advice do you need? good batteries is always a plus. always check wiring and swap connectors to deans or equivalent.
Drifting on abs,needs a good amount of throttle control and steering percision if you want your drifts to look graceful, however its fairly slow paced. I prefer rubber tires and chucking my car at full speed into corners with the tires smoking.
ORIGINAL: DirtBonez
