CR
Pope i'm not sure what the problem is here,did'nt watch the video but you ain't far off gettin your own new product warning label.If the mods allow it have at it son.
Ok, scale event at the field on the w/end and a few truisms came back If you don't balance your a/c correctly it really won't fly all that well and usually ends up with damage to a/c Blom and Voss Bv141 landed tail first off the end of the strip. If you run out of fuel and forget the various laws of aerodynamics you generally crash. P47 ran out of fuel, lack of skill in unpowered flight meant a/c tip stalled and demolished a/frame.
Now big question, Has anybody flown a Hanger 9 Fokker DV11. If so what engine did you use. Hanger 9 recommend a Saito 82 but the one being flown on the w/end had a Saito 100 fitted and the guy said it was barely adequate. Thoughts please as I am about to put this combination together.
Is that the bipe? If H9 recommends it, that means they flown it with that engine. The guy with the 100 might have not propped it right.
I flew my T-Clips today with the Saito FG-11. Wonderful combination! That Saito is so quiet, you wouldn't know it was gas. I spilled more fuel in the 20 minutes flying than I used flying. I corrected the fuel tank vent, I forgot to put a loop in it so it spilled gas when the nose was down, and in my taxi tests I put the nose down a few times. I put a 13x8 APC on it, it calls for a 13X7, so I need to get the proper prop, might have a bit more with the proper one. In any case, I have one tank through it, and about an ounce or two from the second tank and it is running great. Once I get two more tanks through it I will thin the mixture a bit by adding a quart of fresh fuel to the current gallon, I want to make sure there is plenty of lube, and it is getting it. I also put a crankcase scavenging system on, put a brass tube on the muffler with the end bent down and angled at the opening so that the exhaust pulls the oil out of the crank and it is working great. Burned my forearm on the muffler too. Once I get a few tanks through it I will find the right angle adapter and put the cowl on.
Why have people started calling it DV-11 as of late. Would the the DVIII be DV-111?
For blindnuts on firewalls I usually use thinned epoxy that I have mixed with alcohol for fuel proofing and get it into the threads. I thread in the bolts later. No problems backing the bolts out if needed, and the epoxy holds when reused. Been doing that for 7 or 8 years of kit building. On engines, I just swab in the threads and either use the bolts right away, or later. It never seems to act like a glue, rather more of a gripper in the threads. I suspect it improves metal to metal contact. It sure stops threaded hardware from vibrating and backing out and doesn't hurt anything.
No i hav'nt flown one trev but look at a couple of vids on youtube.It shows a laser 70 flying one at scale and what seems to be an overpowered one with a saito 82 which looks to be too rich at low throttle settings,and an fa82 will suck the paint right off a laser 70
Hey acdc you posted a pix a while back with the brass line set up ? it looks neat and tidy,glad it works well.I hear castor is wonderful for burns like you just suffered off that nasty hot running gas engine.You just sniff the castor and nitro while running a nitro fuelled glow saito,takes your mind right off it..
Gee, I got some interesting responses to my post and thanks. I'll be testing / running in the 82 in my Sig Senior trainer / experimental machine and I thought I would match the weight in the SIG to that of the DR7 (DV11) but going by the comments I think it might be a needless exersise. Old fart I got a Lazer 70 in a trade the other day so that could also be a distant option. accdii from the information I have gathered on Saito gas good repeat good quality oil is paramount and the gas engines once they have some fuel run through them (about 10 oz) are reasonable tolerant to variation in mix as long as good repeat good oil is used. Also using them in a sports environment rather than competition. Now a little secret for those interested. A while ago I came up against an Enya 53 that ran like the clappers, better than any I have ever seen. My mate some how got hold of it and we pulled it apart and found it had a ceramic liner and slightly changed timing. I have fitted a similar liner with a hand lapped piston to an OS 32SXH and we achieved an increase of 3,000rpm and the engine is still in one piece. No other parameters (fuel mix or prop) where changed. Next is to test the theory on a 56 or 62 or maybe a worn out 65
What happened to the post? I got this email:
"the pope has just replied to a thread you have subscribed to entitled - Welcome to Club SAITO ! - in the Glow Engines forum of RC Forums - RC Universe discussion forums for RC cars, rc trucks, rc airplanes, rc helis, rc boats, rc jets, rc electric helis, rc electric planes and more.
This thread is located at:
http://www.rcuniverse.com/forum/show...4&goto=newpost
But when I clicked on the link, the post was not there.
[QUOTE=blw;11869904]I learned about using epoxy by accident when fuelproofing a firewall and getting it in the blindnut threads. Now, I use it on engine backplates, those blindnuts, and for the threaded muffler attach bolts. I mix it up normally and swab some in the threads and let it dry. Bolts will thread right in and stay put. No vibrating out anymore. The epoxy gets chewed up some when you thread in a bolt and holds. I think the advantage is that it gets screwed into boogers , has better mass in the threads, and just stays there holding the threads like thousands of little blobs. It doesn't harm anything.
Now that makes sense, letting the epoxy harden, then thread the bolt in..... thanks!
Isn't the Laser engine more of a collector's item rather than comparing to a Saito for power? One of our modeler's passed away and a NIB Laser (70 or so?) had a price of $100 on it. Maybe I should have picked it up. Anyone have a clue how much it might have been worth?
Although this forum is listed under "glow engines" I thought the following might be of interest to Saito people who want to try a Saito gas engine.
I did post this on another forum but will repeat here my experience with the Saito FG-11
This is just to let people know I have had a very favorable experience with the FG-11. Installed it about 3 weeks ago and now had about 20 good flights.
Engine is mounted inverted, Evolution Oil, 2200mAH LiFe battery for ignition (but could use smaller capacity), Sullivan filter just before carb, APC 13x7 prop,
tank is close to engine just behind firewall about level with carb.
Getting 8800-9000 rpm at full throttle.
Some things that might help:
1. High-speed needle: It is difficult to set the correct high-speed needle despite having a tach. When running in on the ground, if engine dies as you advance the throttle I found mixture was too lean and richened it 2 clicks at a time until engine did not quit. I later held the model vertical with engine up, and richened it a bit one click or two so that engine kept running with no hesitation at full throttle.
However when flying and going into a loop the first time, the engine quit at the top of the loop. I then richened mixture two clicks and tried again. Next time the engine did not quit but stumbled. I did this several times successively richening two clicks at a time until the engine ran smoothly at full power during loops and verticals. I then did not touch the high-speed mixture for many flights with no trouble at all and never had the engine die while flying.
Next fine-tuned the low speed needle a little. Idle is now 2400 rpm and probably could get lower but have no yet bothered to tinker with it.
2. Starting: When air is in the fuel line after just filling tank, or between flights, the carb would not effectively suck the fuel up to the carb. With the Saito glow engines if the throttle was advanced and you spin the engine with a starter the fuel would easily fill the line and prime the engine. This did not work for me with the FG-11.
If you have access to the carb and stick your finger over the venturi then turn the prop you can prime the engine OK. However with a cowled engine, as I have, this won't work and starting the engine initially, or between flights, was sometimes a problem. I solved that as follows: get about 12 inched of Tygon fuel tubing and stick a short length of 1/8 brass tubing in one end. If the engine will not start due to air in line just before carb, insert the brass tubing into the tank vent line and blow into the tubing for a couple of seconds. This sends the fuel into the carb and the engine always started for me after that.
That is my experience hope it helps. .
New project question
I just bought a pristine kit of a Carl Goldberg Skylane 62. I built a 1/2 a version in the 60's. I am thinking of a saitio 40 4 cycle for scale sound, 2 cycle for originality or electric to help my old back. The kit hasn't arrived and I'm not sure yet of a four stroke fit in the original design. With the demise of infernal combustion I am wondering what future support of saito engines might look like going forward if I go the four stroke route? Thanks for your thoughts.
Internal combustion will be around for a long time. Not just because of nostalgic reasons, but because of higher efficiency and future improvements.
Infernal was a humorous reference to a saying my brother-in-law use to use referring to a cantankerous engine.
I've been in this hobby over 50 years. I've heard people complaining about Horizon carrying fewer parts for Saitios and see the 40's are selling for $169.00 so I was wondering if Saito support was something I need to concern myself with. I love all forms of modeling and the realistic sounds and smells of 4 strokes. I grew up on 2 strokes. I went mostly electric or gasoline over the last 10 years including the helicopters I fly, as have others. I can definitely see that trends are changing just like they did going from kits to ARF's which is sad but true.
For 4-strokes, I see what you mean about unavailability of spare parts can shelf the engine. I see that Saito is adding gas versions of the glow engines while they reduce their glow engine lineup. Maybe going with gas Saitos is the way to go.
