New TopRC T-28 Trojan
#254
My Feedback: (47)
Looks Great Peter, not too much longer now!
I have been busy with work and baseball and I forgot to follow up about the baffle. I did complete that last week and here are a couple pictures with and without the photo. I don't have a UMS 180 here to test fit. But maybe I can send the file and you can hand cut with paper or cardboard to test the fit and then I can tweak it if needed and then I can laser cut it and mail it to you or you could hand cut from ply. Just want to make sure this fits first. Since, the photos of the 180, must be off a little bit. When you create the 275mm diameter circle, it doe not perfectly align over the circle in the picture. It is all patterned from an anchor point in the center of the prop hub and used 72 degrees. Talk soon.
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/792x722/baffle_testing_with_photo_592e72f82ea8d8afeb729c3e6b577a0612b60f3f.jpg)
![](https://cimg4.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/848x729/baffle_testing_without_photo_a7f1bc71675d0355ac63269780f1fe6834be3f13.jpg)
#256
My Feedback: (47)
No worries, I would appreciate the trial fit and feedback. I sent you the .dxf file for you to review and evaluate. I just design it straight on and with the 15" diameter OD, it can be trimmed to fit to account for the right thrust and most situations. That can all be modified though and I could make it specific to the T-28, would just have to figure the dimensions of the cowl at the proper station where the engine and baffle would sit. The main issue was the picture I found looks like a scanned photo and its certainly a little oblique/skewed and you can see that with the spacing on top of the cutouts around rocker arms.
Thanks and talk soon.
Jason
#258
I fitted first servo into a stab half, tricky to get it in there. I would have liked to use the nut/bolt setup that came with the Savox servos but can't get access so will have to use the screws. The ones I am using are a larger gauge so should be ok.
also cut the slot for the servo arm. I presently have a 1./5 inch allow arm but may go down to a 1.25 inch. Allowed a bit more in the slot for just in case.
I went through the bag of bits looking for the rods and while I found 2 of what look to be M3 rods x 60mm (ex thread) all the others are very thin and flimsy so won't be using those for any thing but gear doors.
![](https://cimg0.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/480x640/t28_8_77f873efd1ac53590337bed469d7848589788be6.jpg)
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/640x480/t28_7_80660cdee9b7c2298737386783d90a865c51b5e7.jpg)
JRSmith (03-03-2024)
#262
#263
Gents, for those who have installed your flaps and ailerons already what setup did you use? External horns or did you use the hidden horn method?
If the latter id be keen to see some photos.
thanks
thanks
JRSmith (03-14-2024)
#266
yeah they certainly are nice. Sing out if you want my list for the lights.
Need to get some M3 rods and probably more M3 captive ball links. I'm not going to use the rods the kit comes with but will put those into my stash of stuff I'll probably never use!
#267
Fitted most of the flight control servos, no linkages as yet. As I am using the internal method of linkages for flaps I had to put those servos on a slight angle from square as there is a large chunk of plywood that holds the anti-rotation pin in place and I really did not want to cut that.
I'll enlarge the pushrod opening a bit to compensate for the servo angle.
Unilights and 16 pin connectors should be here this week.
Need to order some more alloy arms, the ones I have are too long. I'll get some 1" & 1.25" & some control rods in required lengths, not sure on length at this stage.
#268
Not much to report. UniLights and the 16 pin connectors arrived. Working up an order for more alloy servo arms, 1.25 & 1". Need some rods of various sizes, not sure if I will go with bought ones or make some out of 2mm & 3mm threaded rod then use brass tube over the outside.
I did open up the holes on the air brake which came out nicely though made a big mess. Vacuum cleaner will sort that out.
While I am working out what I need for control rods I may start the process of fitting the retracts and doors.
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/640x480/t28_97_a6b118bc0413cf09d6f9dc285a6b4a19ededf511.jpg)
![](https://cimg6.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/640x481/t28_96_07bb7bfd850b1344e575003b9d471062b73d08e5.jpg)
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/481x640/t28_98_c428e5d8faea05e1382b191f6e84dda6f058f24a.jpg)
![](https://cimg9.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/640x481/t28_99_ab126567e9745fae73d12f50ecb89b506d3a5b3b.jpg)
![](https://cimg5.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/640x481/t28_100_64a248c64d6c7aa285d6c6ccaaf74ee7083a74b8.jpg)
JRSmith (03-28-2024)
#270
Inner gear door linkages done. Put some tri stock gussets under gear rails as well.
Not sure of the capabilities of the controller as it will need to reverse one servo and the doors need to stay open when gear is down.
Will be onto main retracts and associated doors next.
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/640x481/t28_102_d3308ab65ebb81d92516d4979a0b121237b5af56.jpg)
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/640x481/t28_103_6c4b1283d52e5311fc5ef25d754370d8415e1005.jpg)
#271
had to do some tweaking to speed brake servo arm, rod length etc so the arm is out of the way of the wheel. It is very close now.
Started work on the gear doors. Still trying to work out how to get those flat hinges installed into the wing.
Door that goes over the wheel is tricky and will be taking my time on that.
Retract leg is just sitting there to work out where it needs to sit. I may need to raise the retract a mil or so so that bottom of the leg does not wack the gear bay rib.
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/481x640/t28_104_ece68a2fe28143075bf27f9cb386004e9ae4302a.jpg)
Not much to say, this bit is simple. Will split the bottom open to allow the flat hinges to be fitted.
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/481x640/t28_105_42e17d728a118fb690270323c4c52ff87b3daa9e.jpg)
#272
Still working on gear doors. I'm doing the ones over the wheels at present. Goop should be cured by ow so hopefully I have it correct. Then will work out where the holes go for the upper bracket.
#273
Just need to screw a piece of plywood over the hinges so that the lower doors can be removed easily.
I'm happy with how the doors turned out, very fiddly and lots of checking this and that.
![](https://cimg4.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/481x640/t28_106_c18f57d417c4c613e7a8323b85455c28c80fe90a.jpg)
![](https://cimg5.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/481x640/t28_107_540e837cc2fedd75fc345493dfd3f64b3fb156dc.jpg)
![](https://cimg6.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/481x640/t28_108_ab8e225d373aef9082176916a591a4702a9f8412.jpg)
totka (04-02-2024)
