Official Tamiya TT-01 Thread
#251
ORIGINAL: foolberg
I have head somewhere that you can use the tamiya 23t motors with the tamiya standard speed controllers
although it is pushing it
#252
Thank God!....Just what I'm looking for!.....some good advice!
The local model shop down my way "Dont know jack".......and its killin me!
Being new to the sport, I need alittle direction.
Brought my self a TT01...limited I know, but once I've finished should be an animal right?
This is just to have fun with, not to race, but I'm going for off the line speed.
Concerns: gearing, what the hell do I need?
Motor
http://www2.towerhobbies.com/cgi-bin...&I=LXJJG2&P=ML
Speed controller
http://www2.towerhobbies.com/cgi-bin...?&I=LXJJG0&P=M
Batts
http://boomboombatteries.com/product...x?ProductID=43
Any foreseen problems, apart from a hole in my wallet (and New Zealand dollars dont buy sh..t) would be greatly appreciated!
Cheers..
Motor
Speed controller
Batts
Cheers..
#253
Well the stock TT-01 comes with the lowest gearing you can get for it, so with gearing leave it stock.
With that set-up, you will see around 60mph and gear/tranny SOUP!!! That motor is way to powerful for the car, try the 1 star Neo..
Also you CAN purchase Take-Off tires seperate from rcmart.
#254
Cheers Bigmik....one problem...I've already brought the motor, and the speed controllers on its way!...Arhhhhhhh
Is there anyway to build the tranny/gear up? frekin model shop was more than happy to sell all this to me, with little advice!!!!!!
GREAT!
GREAT!
#255
Haha no way to beef it up.. I would just sell the motor, will prolly fetch around $60US if its never run. Then just buy a new one, cost around $75US.
Sorry I didn't give advice sooner.
But you can try it, but it will destroy ur diffs, pinions, and spurs.
#256
Roger that....so if I put it on
http://www.trademe.co.nz/Toys-models...0925-1306-.htm) you guys seen this site???
and order this
http://www2.towerhobbies.com/cgi-bin...?&I=LXMAC5&P=0) we should be ok????
Thanks so much Boss
![Frown](images/smilies/frown.gif)
and order this
Thanks so much Boss
#257
Yeah thats the motor you want. But I do warn you that you will end up in the red a little..
What you can do if you don't want to sell the motor, run the esc on "sportsman" setting, and it has about the same RPM as a good arcing 19t motor, but lots more torque.
#258
ORIGINAL: bIGmiK
also with the diffs... what if you went for ball diffs? and full alloy uni shafts and axle cups, etc.
I'm only new to R/C but i would have thought these options would be out there?
#261
Finally some good advice!
Thanks for this guys, So.........Should I keep the 9T and run it on "Sportsman" or sell it for the 13T?
And, I can run the stock gearing?
Cheers bIGmiK...even if u are from Oz!
Ants
Ants
#265
I'm fairly new to R/C and I've had my TT-01 since last year. It's a great kit for beginners alike and good for tinkering with.
One thing that I'm not to sure about is what gear set should I go for. I would like to have max speed and I've got a Tamiya SuperStock TZ Motor, Alloy shaft with all ballraced.
C
C
#266
ORIGINAL: Chrispybee
C
C
So that might suit that engine fine. Maybe a 27 or 28 pinion gear since those TZ motors rev out another 6000-7000 RPM over the GT Tuned motor.
#267
Now what difference is it that I came from Australia.. We race the same RC cars, have the same type of economy, and both have retard presidents and prime ministers.
Haha man I dont really care what you think
Personaly, I would try the 3 star in sportman before buying a new motor. I bet it will still go great. Give it a shot and if you don't like it advertise it as used once.
#268
Ermmmm with the 55t spur, you can ONLY fit in 1 pinion with the correct mesh. I can't be bothered going to check what one it is. I would go with 58/23. It's a really good combo IMO.
The guy that want's to rally his TT-01, it shouldn't be too hard to do. I would get some rally tires and CVA Oil filled mini-shocks.
#270
TT01 ,I'm very new and I have 2 questions 1st could u give me a quick crash course on pinion and other gears and how it relatesto speed and power? I want to replace the wheels and tires can u tell me what to get and where.thks Tim
#272
Well guys I finally got to "Speed Trap" the TT-01. Unfortunately I only did it with a non-matched battery that was half dead lol.
So keeping all that in mind, my average was a bees doodle under 49kph. I'm sure if I geared it harder I would be over 60kph, because I am gettting wheel spin to about 30kph..
#274
NJ
hey which one do you think i should get first
alumminum proppeller shaft
http://www2.towerhobbies.com/cgi-bin...?&I=LXETM7&P=M
motor heat-sink
http://www2.towerhobbies.com/cgi-bin...?&I=LXFSE5&P=M
thanx for any suggestions
motor heat-sink
