Fei Bao Mirage 2000
#251
T1 Models doesn't make a Mirage 2000, so there's no comparison.
Basspilot, the Feibao Mirage 2000 flies easy, with a relatively low landing speed, excellent roll rate, doesn't stall much, high speed passes are impressive, a wide CG locations could be flown with good success, basically all the merits of a delta.
Regards,
Barry
Regards,
Barry
#252
Regards,
Barry
Regards,
Barry
#258
We have yet to test flight the mirage, this project was build by a good friend of mine,
Feibao own light system preinstalled,
Steering servo mount install on front landing gear to our request by Feibao
The mirage setup is
Jet Munts 200
Powerbox Mercury
Savox 2270 all around
Powerbox Smoke pump
Jeti DSD16 with Rex3 RX's
Pulse RX's Batteries
Jetronics Air /failsafe Sequencer with Xicoys values
The mirage setup is
Jet Munts 200
Powerbox Mercury
Powerbox Smoke pump
#259
Back at flying, RC Chaser got some video of mine flying this weekend. Ground handling greatly improved once i upgraded to the steering servo mount. should have done that a long time ago versus the cables
#261
F900 i have not ordered any new planes so can't comment if they have changed (i doubt it) their support is very good whenever i need something for my mirage no problem communicating with them.
#262
Wings AS Spare parts
Good morning Form Germany,
Have one of you orderd new Wings with Slats for a Fuse with Wings without Slats? My Wings have Bad repaired damages and I want to Order nee Wings. But Febao only produce only new Wings with Slats and can Not Garantie that they will fit to the old fuse. Airfoils and mounting to the Füße ist same they wrote to me. But it is Not 100percent that they will fit Well.
so habe eine one of you experience with old fuse and new Wings?
Thank you and Kind regards
Christian
Christian
#263
The mirage setup is
Jet Munts 200
Powerbox Mercury
Powerbox Smoke pump
The mirage setup is
Jet Munts 200
Powerbox Mercury
Powerbox Smoke pump
Are You completely satisfied with savox 2270 servos ?
#264
Ok who is still flying these I want to completly rebuild and rework mine with all new electronics. The plane and turbine are 10 years old. I want to make it easy with less things to go bad. I landed short this week in some tall grass and a stuck servo melted the RX so why not make it a fly iy like you stole it jet airframe is still in ver good shape just a few landing gear plate rebuilds.
Questions to the group, I want to get rid of the slats an air brakes never use them, thoughts?
I have an old rhino KS in it, but it works flawlessly should I get new power?
thanks
thanks
