A pic or drawing of the jackleg tool would be nice and other people may want to study it,good conversation tool too
You asked about rebuilding harley tanks.I sometimes re-weld the earlyish(first evo model around 84) side tanks(2 of) as you know harley went all over the place re company ownership and quality/reputation suffered.To miss quote robin williams they were screwed everywhere except under the titanic..the 85 side by side tanks as i heard it were made from old steel presses they sold to asia when amf took over the company.
Bob here's a pic of the deccy after it's had a fuel tank rinse and clean plus new tubing,the 82 was starting to hiccup a bit.I'll try and include a pic of bella as well
I don't know why they f&#%ed W/it in the 1st place. It WAS a great site. It wasn't broke before & they sure as hell didn't "fix" anything!
Horizon is dragging Saito down. Almost all of the big multi glow engines are still availible from RC Japan, but Horizon only wants to carry the high volume stuff. Walmart management comes to Saito marweting. Saito has rushed into the "gas" market ill prepared, so now Horizon abandons the glow market. When distributors try to dictate what the market gets, it isn't usually doesn't have a good outcome.
GUys - whats everybody's favorite for fuel these days?
Ive been flying a lot of gas the last couple of years so didnt go through much glow fuel, but now Im down to my last gallon and need to buy a case for my Saitos (72, 91, 100). Used to run 15-20%, but with the crazy price increases lately and all the local shops gone I might have to order and am wondering if I can get by on lower nitro??
Just have a hard time swallowing 3-4 $ a flight on my 60 size planes when my giant gasers fly for like 50 cents a flight.
Even if I got some money back selling the 100 used, Im invested a few hundred $ to save a buck a flight on fuel, and now I have to carry a third fuel mix with me (20:1 gas the saito needs, along with 32:1 gas all my other planes use and glow fuel). Just doesnt seem worth it on a small plane.
The $120 difference between the FA-62 and FG-11 is easily made up after few gallons of fuel. The fuel use is doubled with glow, so the 1 hour flight I get now, would be under 30 minutes on glow. Gas is also around $2 a gallon compared to nearly $20 a gallon for glow. The larger the engine, the more glow is used. The DLE20 I run in the 4*120 on a 14 ounce tank is easily 30 minutes per flight, but a similar glow would be under 15 if that. Of course it is only a saving if you fly it a lot. The ignition modules is very light, when I compared the weight of the FG-11 to the OS-70, the FG was about the same weight. I also use a larger Life with dual outputs to power the radio and ignition and it works perfect. So even though there ia more cost at the start, once you have run though a few gallons of gas, the cost savings of gas vs glow easily offsets it and after a few more gallons, the savings doubles.
You dont have to sell me on the fuel savings... I know it, i fly large gas planes (50cc) and 700 size gas helicopters (30cc) and I would never even dream of putting a big glow in them.... its just on this plane that I have a saito 1.00 on, to get the same performance in gas I owuld need to go for at least the FG-21 which is rediculously expensive ($500!!!) for a 60 sized plane... and it would weight more and Id have to mix the special fuel.
Not worth it in a small plane for me but thats just my view. Im glad you are happy with yours.
Had something happen to me the other day that may have damaged my beloved Saito 125. My 125 is on a GP 60 size P47. I typically fly with a 15x6 prop but change it to a 14x8 to see the difference in performance.
I was critiquing the low end while on the runway and got that to a point where I was happy. Engine cowling was on. Good idle was achieved at about 2100 give or take. The problem happened when I tied up the tail and proceeded to critique the high end. At the beginning, I peeked at 9100 - 9200. I must have played with it too long because the more I played, the lower it got. Luckily I was standing behind the prop with my tachometer when the motor stopped and spun off the prop and hub. I'm so lucky I always measure rpm from behind the prop, not in front. That was about 6500 - 7000 rpm. I picked up the prop and hub about 20 feet in front of the plane where it had landed. The motor was screaming hot. I realize my mistake now after the fact....I played with it too long and overheated the motor to the point something happened. I let it cool down and the motor seemed fine when I hand spin it. Have not test run it yet to see if its actually ok. Weather has not been to good lately for me to run it.
Have any of you overheated a motor to a point of "locking the motor and throwing the prop and hub"? Was yours ok afterwards. Curious as to where I might stand before I test run it, and reality tells me for sure.
Thanks, richie
Thanks, richie
I did that with a Tower .75 before I realized that big round cowls need baffles around the engine. Once it cooled off, it seemed okay and, once I installed baffles, I had 20 - 30 flights before I sold the plane & motor. It seemed to run as good as it did before it seized.
Ruffy i don't think you have had a seizure the methanol we use is ice cold when it goes in there but it hits the panic button a bit when you throw a prop eh?did it backfire, i'm not saying you have done this but what i find is if i fiddle to much on the ground instead of flying the engine when it's nearly right it's too lean when i fly the first time on that tune.For instance today i flew the deccy for the first time this morning after a yearly tank clean and new fuel lines.Half a turn rich on the main needle and then narrowed it down to less than two turns out and clocked 9 plus for an 82 and 14x6 apc on 10% backed it off three clicks and flew it,nice smokey trail on a full tank and when empty nearly visible and a dead stick.
ps used some three year old fuel today and the same results for those who worry about storage life.
pps throw that 125 in the bin and put a 115 in it..
Ruff
When glow engines overheat the ignition timing moves way forward. This causes the engine to reverse direction and toss the prop. Using a lock nut is supposed to prevent the prop from leaving the engine. I have experienced this with a 2 cycle (OS 61 SF) on a few occasions. Generally no damage but it is possible to bend or break the connecting rod or something else. I don't know what could happen to the valve train on a 4 cycle. Chances are it is fine. If it turns over normally it may be worth taking off the back plate and cam cover to take a look things over before running it again. No need to risk turning a simple problem into a big one.
Good luck.
Good luck.
Hey, you guys are scaring me on this Glow/Gas thing. Most of the airplanes that I build are 40 to 60 size. Are you telling me that I need to be prepared to spend $500 for an engine instead of $300 for the next 4 planes I have lined up to build? What am I supposed to tell the wife?
Old fart - I guess you could say it backfired. Scared the crap out of me. Didn't expect it to backfire at such a high rpm. It certainly did not seize and freely spun between compression strokes. I will be putting the 15 x 6 back on it. Like my grandfather used to say "If its not broke, don't fix it." Will test fly next weekend if weather permits.
The reason I wanted more performance, via 14x8 prop, is because the other GP P47 at the field has a DLE 20 w/15x6 prop and the top end performance is significant. Although performance is nice, I still would rather have the sound of my Saito w/ keleo exhaust over the DLE any day. Plus the 125 runs great. Many days I'm the only one at the field flying nitro. Everyone else has switched to gas.
My Feedback: (28)
Ruffy good news with the engine.I think the 14x8 is too small for a 125 my 115 on a 14x10 apc will rip the prop tips in a midget mustang you should easy run a 15x8 the 115 will although it starts to struggle on long steep climbs.
Thats why I personally dont like to go gas on anything smaller than quarter scale / 20cc. Im sticking with glow in the small stuff.
If you really want gas in something 60 sized and dont mind the sound I'd look at the OS GT15. Can be had under $300 and runs on standard 50:1 mix that pretty much every yard tool and big R/C gasser uses.
Errr, as to the wife thing. Say nothing. Wives aren't supposed to know what we do. As if we know the true cost of that last pair of heels she bought. The way I see it, keeping them in the dark is just leveling the playing field a little.
When caught, look dumb right away. It usually works. Or, cut to the chase and go the sympathy route. Women have no resistance to attacks on their sympathy. They are helpless.
Heck yes, that's what we are suggesting. Spend lots of money on airplanes and engines.
