Cougar. I bought a PSP test stand, and though it is expensive, it is the the best I have owned. Very high quality, easy to set up and adjust.
Glad to hear your 65 is coming together.
Old Fart, I have already played with a Saito 30 in a Lanzo Racer for open texaco, which I had to return to its owner which is the reason why my NIB 30 is finding its way to the engine test stand ASAP because of the Nats in April. It is great, burns very little fuel in both "normal" and Texaco modes while returning a good rate of power through, for me. a good power band. I have never had throttling problems reported by other guys here. Only thing not to hand is the propellor range that I used can check if you want. It was operating 10% nitro 20% synthetic. Hope that helps a bit.
I got around the flap slowdown on my Futaba 9CHP by using the rotating sliders instead of toggle switches. I rotate the sliders slowly to bring down the flaps.
Believe it or not I have gone back to the original engine on this trainer, an ASP 60 two stroke. When I started reading about guys flying it with OS55AX's and weighing in at 11 pound plus (mine s less than that) I stopped worrying about overpowering. On the JR radio thing when I went computer radio back in the 90's I chose JR over Futaba because they had names for the various channels instead of numbers. I have never regretted the decision and once tackling the technology / options available in my current in use JR's (3 off) I have no regretts. For old farts sake consider the following, throttle cut off after 30 seconds, coupled with down elevator at engine cut and a bit of right rudder to counter act loss of torque effect. That is the set up in my duration models so I can / have mastered some of the technology just the "new" stuff that defeated me for a while. Now back to Saitos. Future planning indicates that the 115 will be going into a Marutaka Stinson Reliant with the flap mods incoporated. Long term project to be started after the Nats.
Hi DBD1 Welcome aboard. That 40a is one truely great motor, I have one on a 50" shoulder wing and I am more than pleased with it, and have a second 40a NIB. I own a bunch of Saito engines and like them all. The 40a I am running on my World Models Attack 20, is very efficient with fuel. I have a six ounce tank in it and after a twenty minute flight there is always about a third the fuel left in there. I am running the 40a with 20% Cool Power and swinging a 12.25x3.75 APC prop and spend most of the time at around 1/2 throttle, which has something to do with the economy, I am sure. What aircraft do you plan to put yours in? You will be pleased with your new Saito, guaranteed.
I've used both JR and Futaba. I really like the 10X but never had one. The only radios I don't like are the low budget ones where the menus are like hieroglyphics with tiny screens and cryptic symbols for simple things that you have to memorize. Still, I remember the days when that was all I could afford and felt on top of the world with it.
Yes i think we tend to forget how lucky we are sometimes and tend to whinge about small things on otherwise good equipment.I use a jr9503,it must be easy to use as i programmed it myself and happy with the result.
Perhaps I can cut off the bearings and gain enough room to make it work. Glad you brought that up.
blw, they are more of a pain to set up. The problem with the mount that came with the kit is that the area that mounts to the firewall is 5/8" thick with the molded in nose gear bearings, making the engine sit too far forward.
![](http://www.rcuniverse.com/forum/attachment.php?attachmentid=2065679)
I prefer the SIG mounts over the GP ones, More clearance, and they are not that hard to set up. A good set of spring clamps to lock the motor to the mounts comes in handy.
Sincerely, Richard
Club Saito #635; Saito 56, 100, 120abc, 130T, 180
Richard i like using good quality plastic engine mounts with stainless allen head self tappers and a mount with long beams,helps soak up that small range of vibration in our saito singles.
Trev i understand all about texaco and duration because you have been raving on about it here for years
forget about the radio...if you are running large dia props on small/ish saito singles what's the prop torque like on take off and a steep climb out?
I use the aluminum ones when I can, if I dont have a mount, then I use the SIG ones. My FG-11 is using the one that came with it, I had to make some modifications to the firewall to make it work, but it works well. The one downside of metal mounts is if the bolts come loose for whatever reason, then you get metal on metal vibrations which can interfere with the radio, making or an interesting flight.
On the SIG mounts, I always use a nylon locknut on the bolts, even though they are tapped and tight, gives that extra bit of insurance. It is a sure fire way of cracking the case in a crash though, or so I have discovered with my 100 GK.
![EEK!](images/smilies/eek.gif)
Sincerely, Richard
My P-51 hit at such an angle that the FW didn't break, the Fuse did in the middle, but the force on the spinner cracked the case. Had I not used the nuts, the bolts may have sheared out instead and not cracked the case. Eh it needed new bearings anyway.
Old Fart, With Texaco models the biggest problem is using enough revs to match the conditions. I usually use around 5,000rpm for take off (give or take a bit) and once settled into the climb drop back to about 4500rpm. This is applicable for all the saitos. However weather conditions determine rpm because height is the determining factor followed by engine run time. In Texaco engine torque is no problem. Duration, t/o is usually at max rpm and wing drop is expected BUT can be factored in to the t/o regime (I don't) so yes torque effect can be quite high. When I started using the YS I used 1/2 throttle for t/o and still dropped a wing but now I still do it sort off but it isn't as terrifying. The 65 has lots of grunt in duration mode and coupled with bolly carbon props can be a hand full if you are not on your game. But then if you launch the model with only the tail wheel touching the ground and and an 88 inch w/s model looks like the length of your little finger (if you can see it) after 30 secs then the torque doesn't really have enough time to manifest itself IF the set up is right. I could rabbit on but I think you get the idea.
On engine mounts, I use factory ones when I can afford them, and carbob fibre or f/glass otherwise. I use pk's (or self tappers if you will) on small engines and bolts and nylock nuts for bigger ones. I also have a collection of cast aluminium ones from an old manufacturer here in Oz that also get a look in occassionally.
