Old 03-17-2015, 04:57 AM
  #28901
acdii
oh that is purdy. so it that like two .50 jugs stuck together? Very curious as to how it would look on the 1/5th SIG Cub. I so want one now.
Old 03-17-2015, 08:21 AM
  #28902
SrTelemaster150
SrTelemaster150's Avatar
Originally Posted by Hobbsy
I am surprised that none of you sharp eyed Saitoists noticed that the airpump is missing from this engine. Clarence Lee noted this in his last test of the 1.82. A good move when you consider that the by pass gasses are going to vent the crankcase anyway. The right cylinder has a standard cam cover installed when the pump was removed.
The idea of the pump comes from the fact that the uneven firing twins do not produce positive/negative crankcase pressure to scavenge the moisture from the case.
IF it was my engine I would rig up a crankcase breather line to the intake manifold. Similar to the PCV systems used on automotive engines.
Old 03-17-2015, 09:21 AM
  #28903
retransit
My Feedback: (18)
retransit's Avatar
I'm sure one of you guys know the answer to this. Does the FA82A have a gasket on the plastic back plate, or do they rely on the plastic to seal the case?
Old 03-17-2015, 12:04 PM
  #28904
Hobbsy
Hobbsy's Avatar
Bob, I had two .72s and an .82 with the plastic backp[late, I believe the larger diameter portion is a precise fit in the crankcase, never had one to leak.
Old 03-17-2015, 12:19 PM
  #28905
retransit
My Feedback: (18)
retransit's Avatar
Okay, good. I thought I lost it when removing the back plate. Thanks.
Old 03-17-2015, 12:20 PM
  #28906
Hobbsy
Hobbsy's Avatar
Bob, Horizon has the .82b aluminum backplate in stock. http://www.horizonhobby.com/fa-82b-r...b--rr-sai82b17
PS, my mother in law and sister n law live in DeBary, she works at Stetson.
Old 03-17-2015, 05:35 PM
  #28907
the pope
no gasket on the plastic backplate only the alloy one Cheers the pope
Old 03-17-2015, 07:48 PM
  #28908
retransit
My Feedback: (18)
retransit's Avatar
It's a small world, isn't it?
Old 03-18-2015, 06:45 PM
  #28909
Rudolph Hart
Rudolph Hart's Avatar
Make sure you don't lose the steel support washer for the top 'o' ring on the intake tube,i did once.
Old 03-19-2015, 04:33 AM
  #28910
Hobbsy
Hobbsy's Avatar
If some of ya'll would like to read something interesting, read a paragraph or two beside the K&B add in this test of the Saito 1.82 twin. The same hold true for the 1.00 twin that I just received. The right cylinders cam, (on the 1.82) is the same as a .91 cam, however the left cam is different for some reason. Maybe do some speculating too. I'll check but it's probably true of the 1.30 also.
Name:	Saito 100 new.JPG
Old 03-19-2015, 06:07 AM
  #28911
Rudolph Hart
It seems not
Popey where you 'bin jammin'..aussie word for hiding while partying really hard.
Old 03-19-2015, 09:18 AM
  #28912
blw
blw's Avatar
I would hate to wait a few days or weeks for that one tiny part!
For all 72 owners- get the aluminum backplate if Horizon really has them after being out of stock for some 6-7 years.
Old 03-19-2015, 09:21 PM
  #28913
the pope
It seems not
Howdy there O.F. lucky Im back at all but thats a whole new story ! One I wont repeat unless I get enough requests and some donations to pay my legal bills ! Thanks for askin though
Old 03-20-2015, 01:54 AM
  #28914
SrTelemaster150
The cam is "reversed" since the orientation of the intake/exhaust valves on the port cylinder is reversed in relationship to crank rotation and therefore the cam rotation.
On a single as well as the starboard cylinder of a twin, the exhaust valve is 1st in relationship to the cam rotation. On the port cylinder, the intake is 1st, requiring the cam lobes to be reversed in order.
The same scenerio holds true for the FA-100Ti & the FA-200Ti.
It is said that the port side cam from a twin can be used to reverse the rotation of a single.
Old 03-20-2015, 07:55 AM
  #28915
blw
blw's Avatar
Welcome back, Pope. Where'ya been lately?
Old 03-20-2015, 08:10 AM
  #28916
the pope
Hey there blw , cant kiss and tell . Plus the paypal accounts still empty . Nice to be missed though by someone . Better go Im starting to tear up . Cheers
Old 03-20-2015, 01:22 PM
  #28917
Hobbsy
Hobbsy's Avatar
If a couple of the larger twins can have velocity stacks why can't my 1.00? I would rather have had aluminum ones but all the K&S aluminum tubes were too large. I also made up a temporary support for the pipes.
Name:	Saito 1.00 stacks.JPG
ID:	2082811   Click image for larger version
Name:	Saito 1.00 pipes.JPG
ID:	2082812   Click image for larger version
Old 03-20-2015, 03:41 PM
  #28918
spaceworm
Hi Dave. I \really like your stacks. Unfortunately, I can't fit my 1.30T with stacks due to the way the carb throats face each other.
Your 1.00T was fitted with the corrugated pipes? My 1.30T has rigid pipes with a pressure tap on one of the two. Do you think I should support the pipes I have? Thanks.
BTW we are welcoming spring up here in CT with 5 inches so far of new snow. Our East Coast Swamp Fliers RC Club field will never be dry; I will have to fit floats to my Spacewalker/FA-130T.
Very best regards to you and yours.
Sincerely, Richard
Old 03-20-2015, 04:05 PM
  #28919
BJ64
BJ64's Avatar
Originally Posted by the pope
...Plus the paypal accounts still empty...
Been buying up big on Cockles, huh?
LoL
BJ
Old 03-20-2015, 05:23 PM
  #28920
Hobbsy
Hobbsy's Avatar
Yes Richard, the 1.30 is a little crowded back there, the 1.00 came with the black rigid pipes and the flex pipes. I seriously considered selling the flex pipes, people are always looking for them. Hopefully it won't rain too hard tomorrow, it supposed to be 50+. Maybe I can break it in.
You could always mount a pair of stock .65 mufflers or a pair of Turbo Headers, no support needed.
Old 03-20-2015, 05:33 PM
  #28921
the pope
LoL
BJ
Hi ther Bj yes Im from the cockle capital of the world . There as big as frisbees .We used to host a cockle festival , disgusting little critters to eat but the fish like em . Been down my neck of the woods ? Cheers the pope
Old 03-20-2015, 06:16 PM
  #28922
BJ64
BJ64's Avatar
Yerp - used to live in Birdwood, so there were quite a few fishing trips down to Goolwa, Victor H, Rapid Bay, Cape Jervis etc.
These days I'm back in the land of Vic, but I've done a bit of slope soaring at Victor, 2nd Valley, Maslins, Hallett Cove and a few other spots whenever I get back over to SA.
Oh...and Cockles are deeee-lish when done with lots of garlic, black beans and chilli. YUMMO!
You just have to make sure you 'de-sand' them, then make up the sauce first and drop them in - remove and eat as soon as they open.
BJ
Old 03-20-2015, 11:50 PM
  #28923
the pope
You poor thing on 2 counts , eating them things and being in Victoria . I cant even eat mussels or oysters etc . Been sloping at hallet Cove and victor but not Maslins (wink wink ) and please dont tell me your a Port man ! Cheers the pope !!
Old 03-21-2015, 12:30 AM
  #28924
BJ64
BJ64's Avatar
Love shellfish - and no, I'm not a Port bloke. Roosters when I was over there.
Must fire my 180 up again tomorrow - forgotten what it sounds like... and eventually get around to installing it in the '109.
So much to do...
BJ
Old 03-21-2015, 03:46 AM
  #28925
Hobbsy
Hobbsy's Avatar
BEEJ, I've never owned a 1.80, soon will own a 1.82 twin, my first Saito was a gift from my daughter in 1991, a high compression, (11.24 to 1) Saito 1.50, later I bought an earlier high compression .80 GK, 15.5 to 1 compression ratio. Richards 1.30 shown above is 12.98 to 1. My 1.00 shown above is a lowly 7.98 to 1. Share the running 1.80 with us if you will, Thanks
PS, since you live Diesel-land, the .80 will run on Davis Diesel fuel un aided. In the running picture it is turning a Bolly 13.5x8 at 8,792, it now wears C&H Ignition, it runs as smooth as silk this way. I couldn't set the timing at 35 BTDC as recommended, it rattled too much, at 32 it is very quiet and smooth.
Name:	Saito 80 on Diesel 006 (Small).jpg
ID:	2082909   Click image for larger version
Name:	Saito 80 on Diesel 007 (Small).jpg
ID:	2082910   Click image for larger version
Name:	Saito .80 on C&H 004 (Small).jpg
