Old 06-12-2015, 10:29 PM
  #29476
Rudolph Hart
Rudolph Hart's Avatar
Dave i'm looking forward to seeing both those 30's mounted and running together,with maybe some sound.I like apc props and getting a pair would be easier?
ps a note to the moderators: popey is being insulting in the extreme when he mentions holden gemini cars after he mentioned datsun 120y's please google it it's not even half a good datsun 240z,whats the world coming to trev?
Old 06-13-2015, 03:01 AM
  #29477
Hobbsy
Hobbsy's Avatar
Jerry, I'm pretty sure that Pete and others mentioned sneaking up on the peak, typically a Saito when at full peak the rpm will wonder up and down a little. One click rich and it will run rock steady about in the middle of the wondering rpm. The early high compression ones don't have this little bit of forgiveness, they go right from peak to hurling the prop into the neighbors garden.
Pete I found two Graupner 10x5.5's. I have the new one in the PSP ready to run today with a 10x5.5 installed. I only have one of the 10.5x5's. My previous LT 25 had a nose gear, ALA some great engineering by your's truly, luck mostly, to be honest. In not so short grass it would have trouble getting rolling when using the 10x5.5, I would install the 10.5x5 and would quite literally jerk the plane up on the grass and away it would go. I have a few of the blender blades to test for other people but never fly them.
PS, mentioning any of those junk cars is insulting.
Old 06-13-2015, 07:24 AM
  #29478
RH
FA-82 carburetor gasket set question?
I'm rebuilding my FA-82 and decided to attack the carb while I am at it. I ordered the gasket set (SAI91S91A) that was indicated for this engine. The set I received has more parts than I expected. I suppose that this set is designed to service more than just this model engine, but I'm not sure now which ones I need. I haven't completely disassembled the carb (haven't pulled the barrel out) yet and I can't seem to find a detailed schematic of the engine that includes a full break down of the carb. The one in the book doesn't show specific gaskets other than #32. Here's what was in the package...
1) is there a detailed schematic available for these carburetors?
2) It looks like 4 and 7 are the same. It appears that 7 and 8 go on the upper end of the intake manifold (listed as part 32 on the schematic). Then 4 would go on the lower end. Any suggestions as to where 1, 2, 3, 5, and 6 go?
Rick...
Name:	Carburetor gasket set.jpg
Old 06-13-2015, 07:54 AM
  #29479
Hobbsy
Hobbsy's Avatar
http://www.horizonhobby.com/pdf/SAIT...der_Manual.pdf
Page 18 has a poorly focused picture of the exploded carb.
Lose #2 unless you have a choke.
7&8 go on the upper end of the intake tube
#3 goes under the nut that holds the needle clip
#6 goes in the end of the spray bar
1 or 4 goes at the bottom of the intake tube, judge by the room you have
Old 06-13-2015, 09:54 AM
  #29480
Hobbsy
Hobbsy's Avatar
Well Pete the second one is ready to go. broken in my usual way.
New Saito .30 E series, not sure that means much.
Prop===Graupner 10x5.5
Fuel===WildCat 18% 2/4 with 18% full synthetic.
Plug===Saito SS, came with it.
10 minutes @ 4,000 three turns out, glow power needed
10 minutes @ 5,000 two turns out glow power not needed but still smoky and rich
10 minutes @ 6,000 same setting
10 minutes @ 8,000 two turns out
10 minutes @ 8,500
10 minutes @ 9,000 took 16 oz tank down to .375" from empty. Refilled to about .75% full
Re-started and allowed to warm up, set idle at 2,200, then slowly peaked the HS needle to the reading you see. That rpm is sustainable and repeatable.
The cosmoline or whatever came out for a full 30 minutes then stopped.
PS, I almost forgot, the new paint stayed nice and shiny and stayed on there. Hooraw.
Name:	Saito .30 oil.JPG
ID:	2102378   Click image for larger version
Name:	Saito .30 Tach reading.JPG
ID:	2102381   Click image for larger version
Name:	Saito .30 at full blatt.JPG
Old 06-13-2015, 02:18 PM
  #29481
FNQFLYER
not bad at all, would like to see a comparison between the graupner and the bolly clubman prop of similar size.. Hobbsy you should be able to get both Bolly clubman and carbon props from the distributor they have in the USA, check out the Bolly website for the addess. The carbon props are well worth the expense.
Old 06-13-2015, 02:25 PM
  #29482
FNQFLYER
Oh yes I forgot, after I developed my limited skills in rallying in the Gemini ZZZ I moved on to a Datsun 1600 /L 510 that was part of the Datsun rally team of the era. But food for thought imagine a support car kitted out like this 1970's Datsun Econo Van with a rally spec'd 280z engine, series 2 5 speed g/box, ford 9 inch rear end, 4 wheel disc brakes ex 280z, and Koni rally adjustable shocks. It carried 300 litres of 100 octane fuel and all the other spares needed to support a 240Z car. It was one of 3 factory converted support vehicles I managed to acquire (in its dotage) in the 1990's, cost me a lot in speeding fines before I got rid of it.
Old 06-13-2015, 04:24 PM
  #29483
RH
Good tips. I shall now venture forth with the rebuild. I've had this 82 on an Ultra Stick for many years and it is one of my favorite Saitos.
Rick...
Old 06-13-2015, 04:40 PM
  #29484
Charley
Originally Posted by SrTelemaster150
Spitting the prop with the PROPER HSN mixture means the engine is not capable of sustaining the load & is over heating.
Gosh, I alway thought that if I set the needles properly for the prop I'm running, it wouldn't detonate.
CR
Old 06-13-2015, 05:10 PM
  #29485
Hobbsy
Hobbsy's Avatar
Trev, I'll check out my Bolly supply and see what I have in that range. I have been getting them from Dar and Derek, Dar is about out of them.
RH, keep us posted on how the .82 progresses.
Old 06-14-2015, 02:03 AM
  #29486
Rudolph Hart
I'll second that i'm picking up a new 82 this monday that makes three.Thats a long run in to me but the figures you got are very good mate.10% nitro or none? and the following is a joke,sort of.
Trev don't worry about dave's bias for all things american re the datsuns,i hate datsun 120Y YI YI's... just quickly,imagine you had a 90yr old frail lady living next door and she was having car trouble and could'nt get out to do her things she needs to do.In your driveway sits a datsun 120y and you offer to loan it so she can get on with her life,it might cost you yours after she half beats you to death with her zimmer walking frame,even beige coloured oldies won't drive them.The 240z i hasten to add is a whole other story.
Old 06-14-2015, 03:04 AM
  #29487
Hobbsy
Hobbsy's Avatar
Pete, I have to be honest, there sits a 2000 Mitsubishi Galant in my driveway that is one of the quietest cars I've ever owned. A gift from our daughter, the ride in her new Acura sounds like a road wagon by comparison. My 1995 F-150 is still very quiet inside at 204,000 miles. Our neighbor has a new Scion that is also noisy inside on the road. I like quiet.
I owned a Saito .91GK for a short while, I horse traded it to w8ye and then bought an .82, despite it's relatively short stroke the .82 is a torquer. I then sold the .82 since I still have the early high compression .80, now with C&H Ignition. Since I was successful painting the .30's cylinder I'm think about painting the old .80 GK, it looks a little worn.
Name:	Saito .80 on C&H (Small).jpg
Old 06-14-2015, 04:11 AM
  #29488
spaceworm
Originally Posted by Hobbsy
... Since I was successful painting the .30's cylinder I'm think about painting the old .80 GK, it looks a little worn.
Hi Dave,
You have inspired me to do a "GK" on one of my Saitos. Have you seen any thermal studies on having a blackened cylinder re. cylinder head temperatures? I am thinking they should run cooler due to "black body" emission, but I don't know if that applies in this case. Thanks, and hope to get down there this summer.
Best regards, Richard
AMA 861960Club Saito #635; Saito 56, 100, 120abc, 130T, 180;
YS F 120; Fox 35
Old 06-14-2015, 04:41 AM
  #29489
Hobbsy
Hobbsy's Avatar
Good morning Richard, that was Bill Robison's take on it too, it's somewhere in his Saito notes. I'm kinda in a rush, we got a new preacher and we're having a hello and goodby party this PM for the new and the previous. I found a small long nosed Tru-Turn spinner for the .30's and two three blade 8x6's. I won't get to experiment. until tomorrow. I'll have to measure the spinner and get a second one.
Old 06-14-2015, 03:54 PM
  #29490
the pope
Im sorry but a turd is still a turd even if its got sweetcorn init ! Now enough with the gemini and datsun stuff . I love the pure racing machines , F1 in particular . Nothing IN MY BOOKS can beat the likes of Senna ( the best ) and just watching that pole lap in Adelaide in the jps lotus , those spec cars were insane ,still *****les the hair on the back of the neck . Just watch if you wish how its just dancing on the raggard edge of control .
https://www.youtube.com/watch?v=gbKbg-Bg8mk
https://www.youtube.com/watch?v=3GOEorrE4mY
https://www.youtube.com/watch?v=GTJZTc1U1tM
That last clip is awsesome , if I was a passenger I would be crying for my momma ! Cheers
Old 06-15-2015, 06:24 AM
  #29491
blw
blw's Avatar
Dave,
Good thing you found the Graupners because the tan Bolly 10.5x5s were an utter disappointment for me. This was on a 2 stroke, but one tank of gas and that piece of junk prop was history. If you are calling APCs blenders you need to give them a fair chance in the air. They out pull just about anything else. I've heard people say they are afraid of them but a prop is a prop and all of them do a good job at cutting fingers.
Old 06-15-2015, 06:29 AM
  #29492
blw
blw's Avatar
See old fart these yanks really don't read our posts.
Yanks? I'm in Alabama. There's no Yanks around here! You have to watch what you say around us foreigners.
Old 06-15-2015, 09:03 AM
  #29493
FlyerInOKC
FlyerInOKC's Avatar
You better watch calling them southern boys "Yanks" the will be all nice and polite right up to the time they gut you like a fish!
Old 06-15-2015, 01:24 PM
  #29494
captinjohn
Yup...Watch the video called "Hell on Wheels" there is some mean stuff to see. Look for it on Netflix !
Old 06-15-2015, 01:41 PM
  #29495
SrTelemaster150
SrTelemaster150's Avatar
Fact still remains that they lost. They need to get over it.
Old 06-15-2015, 01:51 PM
  #29496
spaceworm
If you start hearing banjos, best run fast and try to hide.
Old 06-15-2015, 02:13 PM
  #29497
Hobbsy
Hobbsy's Avatar
Mean while, back at the ranch, here's my Saito .30 with the long Tru-Turn spinner and a 3 blade 8x6, numbers tomorrow. I am looking at this configuration for the 50 Caliber twin.
Name:	Saito 30 & three blade.JPG
Old 06-15-2015, 02:42 PM
  #29498
SrTelemaster150
Ned Beatty Had the Hardest Part
https://www.youtube.com/watch?v=j1KZOApOVlg
Old 06-15-2015, 02:49 PM
  #29499
FNQFLYER
blw, I agree with your assessment of Bolly Clubman props (tan ones), for the price APC props are my prop of choice EXCEPT for competition when it is Bolly carbon first followed by Sherlock when I can get them.
Old 06-15-2015, 08:44 PM
  #29500
blw
blw's Avatar
Who said it's over?
