Official Jammin X1CRT Thread
#276
PA
RE: Official Jammin X1CRT Thread
ORIGINAL: LJ4K
Automag,The diffs look harder to get out than they actully are. Mine had more grease on the outside than they did in them. I've had my CRT 2 weeks been working on it ever since. Thinking I should have bought the kit. Hope it's worth all the work once I get to run it.
and im good at building so i want to show it [X(]
i plan to put either a rb ws7-2 xworlds or what ever (a 21 that is a package with a pipe and shirt and hat and stickers for $400)
or a nova 21 type
#277
the fine folks at the track i run? at gave me a new name today.
now they call me sundial.
they use a sundial to time the laps that i run.
Dirby.
Dirby.
#278
Just got the kit for the race next month and had spent 8 hours for building and the other 8 hours for touching up. Although it is made of plastic and metal that is same as the other, things are found different from those by Japan. But what I can ask for more at this price that the kit comes together with a tuned pipe
#279
um, I just did some light bashing with the X1 CRT, came down on the rear end, and bent the whole rear bulhead so far upwards that it bent the rear driveshaft like a pretzel and crushed the "support" beam up against something else (I'm afraid to look). Is there a cure for this flimsy RTR frame out there? I remember seeing a brownish chassis in this thread somewhere, is that a really really ridgid chassis or...what would y'all do?
The savage x got a beating too...busted fuel tank (2nd one) and broken metal steering servo gear. With the fuel tank, I'm thinking I'm going to fashion some inboard mounted tank somehow.
#280
PA
ORIGINAL: ashburg
http://www.fastlanemachine.com/Publi...6/Default.aspx
you can use the tank and servo mount plate to do a professional mod with out all the work. There extended chassis is the bomb!
#281
ON, CANADA
Hey Ash,
in the new R/C CarMay 06 Pro Driver Chad Bradley gives out a ton on info on his CRT
You can find a ton of parts for the Jammin here
www.rcracingparts.com
They Also have a this sit listed
http://www.kingheads.com/
The King Headz motor mount looks to be a neat product.
Hope this helps,
Perry
Hope this helps,
Perry
#282
NE
ORIGINAL: Dirby
crazysavage.
i would like to get a new radio with a spectrum system in it .
what do you think about the Dx3
would this be a hit or a miss?
thx dirby.
crazysavage.
thx dirby.
One word Nomadio
#283
#285
Dang, I can't get that mag here. Anyone wanna share some of the info on bradleys CRT? Is there any special "mods" he has done on his?
#286
PA
ORIGINAL: Horde of Chaos
http://www.jamminproducts.com/chadstips.htm
and few other tips. I have to go to the track but I'll check the info and post the missing stuff later.
#287
crazysavage.
I know you are not to fond of the DX3 .
what do you think of the Futaba 3PK with a spectrum modgual and spectrum rec?
thx Dirby.
thx Dirby.
#288
I believe that is the BEST choice. That is exactly what I run. Also, they now offer the HRS version of the Spektrum module that allows you to use (only) digital servos but with even faster response than with regular DSM.
#289
PA
ORIGINAL: Dirby
crazysavage.
thx Dirby.
crazysavage.
thx Dirby.
#290
SC
One of the best menu I have used is in the KO EX-10 Helios. I don't like complicated menu systems either and just like crazysavage, I've not had to resort to the manual either.
#291
so from what i have read the Futaba 3pk is the one to get.
will it have all the whistles and bells i will ever need?
this will be interesting.
i have a dx3 and it is mated to the two rx i got with it.
now if i get the 3pk will i be able to mate the two rx that came with the dx3 with the 3pk ?
will they work?
what will happen if i turn both tx on at the same time?
thx Dirby
will they work?
thx Dirby
#292
It is the last radio you will ever need. I race 1/5 scale road cars as well and if you go to any race, you will see 99% of the drivers using the 3PK. It even has an ABS setting that you can play with that will pulsate your brakes so they don't lock up. It has everything you will ever need. And, it really isn't that bad to program and understand.
Your 2 existing receivers will work as long as you stick with the normal spektrum and not the HRS spektrum unit. You will need to rebind the 2 receivers to your new 3PK/Spektrum transmitter and they will only respond to that Tx until you rebind them to something else.
Good luck, have fun.
#293
PA
ORIGINAL: taildraggerdave
#294
ORIGINAL: crazysavage
BC, CANADA
does the crt kit comes with the power switch? im almost done with mine and i cant find a power switch with the kit. im assuming that i have to buy all the electronics for it coz i dont see any wires at all
#296
PA
Have you found that missing info? from the magazine?
taildraggerdave.
is the HRS spectrum system out now?
i talked to my lhd and he said he wasn't aware of a HRS system
he said there was a pro system coming out but it wasn't available yet.
is there that much dufference between the two and what would be the cost?
thx Dirby
thx Dirby
#298
Not sure if it is out or not. Spektrum's site calls it the Pro Series, but I thought I read somewhere that you set your Tx to HRS output when you use the new faster Spektrum module. Here is the link to Spektrum if you don't have it.
[link]http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPM1011[/link]
#299
PA
ORIGINAL: miswa
i have one on order so i guess ill have to find a wire kit with a switch
#300
taildragger dave.
i talked with amanda at horizon and she said the HRS spectrum systen is out now.
this will only work with the futaba 3pk radio no others will work.
she also stated that the regular spectrum rec will NOT work with this system
also she said the regular spectrum ran at 5.6ms and the hrs ran at 3 ms.
that is a difference of 2.6ms i don't know about you but i don't think i could tell the difference between 5.6 ms or 3.0 ms.this is only 2.6 ms.
the cost of the hrs modgule and rec is 199.99 andonly this can be used in the hrs system
if you had any other spectrum rec that wern't hrs they would not work at all.also you will have to get digital servo's to work with the hrs syste.
i have two spectrum rec that came with my dx3 and i am going to get the regular spectrum modgule so i can use them.what it all boils down to is how much money do you want to spend to go a little faster.
this hrs system is NOT the pro system that everyone is talking about this is for the futaba 3pk radio onley.
thx Dirby
thx Dirby
