Sincerely, Richard
AMA 861960
Club Saito #635; Saito 56, 100, 120abc, 130T, 180
Hole in pickup tube at the 1/4 tank mark? Sucks air when the fuel level gets to the hole? Just a thought. Another thought: Maybe the clunk is stuck in the tank at the 1/4 tank level? Again, sucking air after that. Good luck. Sucks to suck air instead of fuel.
Sincerely, Richard
AMA 861960
Sincerely, Richard
AMA 861960
Sad to hear richard and my condolences to you and yours...just try to remember that there is always someone who has a bigger problem.Mine's nitro
Clunk and lines all checked out, that was my first though too. I will try the tuning with 1/4 tank instead of half tank and see if that helps. OTOH just wondering it my AOA had caused it by leaving the clunk high and dry. I was in a steep diving bank just before it quit, so maybe it had sucked in air just before leveling out. I wasn't going very fast either, so who knows. I thought it ran out of fuel, when I picked it up it looked like it was empty, but when I put it on the stand and lifted the tail level the fuel was over the clunk, just barely. The clunk is the brass type with a inverted cone towards the opening so it sits a bit taller in the tank. Maybe thats the problem.
YMMV
Yep, using muffler pressure. The one thing different on this one from all my other tank setups, I am using the filler valve from DuBro, mounted at the bottom of the firewall on my Cub. think I will change out the clunk next time its in my shop for maintenance.
[QUOTE=FlyerInOKC;12094531]Stupid question are you using the muffler nipple to pressurize the tank?[/QUOTE
It's ok not to,just richen the main needle a bit,lsn will stay the same.
Acdc next time you have an engine on the bench make sure the fuel tank is easy to move around while the engine is running,you'll be surprised
My Feedback: (213)
I have been working on a friends Saito 150 and I am lost. The engines runs great, good top end with a very good idle. The transition from low to high is right on.
The problem is as you open the carb there is a fine mist of fuel coming out and the more it opens the greater the mist gets. I had the carb apart and no problems
found. I checked the tank and lines, no problems found. No air leaks. This just started and until now the engine has been running super. I have not checked the
valves and that is where I am going next. Any help would be greatly appreciated.
Rick
Rick
Here is the trumpet before installation to the carb inlet (shown inverted):
FA-150 similar, maybe the same part number.
BTW, I almost lost two fingers, and certainly my nerve, hand starting a new 150. It kicked back and actually cut partially through a heavy leather glove I treated it with much more respect after that, and used an electric starter, making sure the prop safety nuts were securely tightened. Good luck.
Sincerely, Richard
AMA 861960
YS F 120
My Feedback: (213)
Thanks for the replies. The engine dose not have the trumpet. Until now no problems.
I will have him order one to see if this helps. Also I forgot to mention that the engine is inverted.
Thanks, Rick
Thanks, Rick
My Feedback: (213)
Richard, sorry to hear about your glove and happy to hear you still have all of your fingers. I have used
4 stroke engines for years and I got bit once and now I use a starter even on my 4 stroke 20. Be careful !!!
Thanks, Rick
Thanks, Rick
Man, yesterday was a crappy day to run an engine. They would not run smoothly at WOT no matter what, must have been the high humidity. We both flew high just in case.
Most 4 strokes like to be wet, so I prime them by opening the throttle and flicking (with said chicken stick) through until you see evidence there is fuel in the manifold (usually indicated by dripping from the carburetor). Then I put the glow driver on and use the stick to rotate the prop BACK against compression. I let it sit there for 5 seconds or so and then smartly flick it backwards against that compression. Most of the time they start right there just fine but sometimes with the larger engines they start running backwards. Sometimes that can be corrected by reducing the idle until they pop and start running correctly. If not, pop the throttle or kill the idle on the transmitter and start over again. Remember to take the glow driver off while you are massaging the prop and fuel combination.
YMMV
Chicken sticks FTW!
The cheap ally intake trumpets are well worth the money,cleaner engine bay too.Jim i think the ex handbrake MUST have been a fourstroke,you had to use a chicken stick(taser)with her too.
To all I have not forgot about my offer of the Little Red Saito Book. Family life etc intruding into my life has gobbled up lots more time than I would like but I will attend to this matter shortly. Of note only 2 people have responded Spaceworm and Old Fart. OF suggested that I copy / scan it and make it available to all. Don't have the time at the present but will consider same soon. More later
That's a fair question jim.I agree with your prop choice.Have you bought an engine from somebody who never intended to run it? ie someone who likes tinkering with mechanical things but not interested in firing the engine up to see what happens,or stand near it? pull the carby apart and have a look specially at o rings,if you can get around 9000 or under on the ground you won't be too lean,hobbsy has seen heaps of props disappear over the back fence doing that and it takes a brave bloke to lean over the main needle when you think that may happen,or has happened.
Trev do you feel like copying the 'red book' and sharing here?
ps could keep you out of 'the little black book'
<off muttering and grumbling about NIB stuff that isn't from RCU folks>
Can I have a little red book?
It is possible, I didn't drain the tank from my previous flight like I always do, and had a half tank of fuel in it that sat for awhile, and was in my cold basement before it was brought up and stuck on the truck for a few day and it was very humid during that time.
Jim if you can please do some low passes in the rain sometimes heavy,makes the 82 hiccup a bit watching the prop spray makes up for it plus meant to add if you don't run a pressure line all is good except violent aerobatics where you get the same hiccup for a split second.
Mike
Touch and goes in the heavy rain are simply awesome.
This particular airframe is scale and open cockpit so it does not qualify as being a wet baby.
Oh, for sure! On the correct airframe, flying in the rain is a blast. I was part of the out of town party that kick started an event we were visiting that was getting rained out. We taught them how to fly in the rain and had fun. The event has been that clubs only income generating effort of the year for over 30 years, even that year was successful.
