Vert if it's upside down choke it till it squishes or if you can't see the engine,a drop of gas hits the ground.Igniton on and flick it.
Popey i still reckon when you popped out the doc slapped your mother real hard.
I have found with the glow Saito's they tend to like hand starting with a back flip. On the FG 30 you would pull it through compression to go through the hall sensor I take it? I am all about hand starting engines, prefer it honestly, but the 4 strokes I always preferred an electric starter. Hoping the FG 30 is a good hand flipper.
I recon they had to put a pork chop in his nappy to get the dog to play with him
This is true for the FG-11. Once it has juice in the carb, it will start with one or two flips, though for safety reasons I still use a starter. The only engine I have no choice but to hand start is my DA 100.
I took this engine to the field when i first bought it 2 months ago and bench ran it with a friend of mine who is really good with the nitro engines . We tested it up right and set the low and high speed and it ran like a champ.This is not a new engine but it is great shape and ran smoothly when we bench ran it. I did not know i was going to mount it inverted or i would have bench ran it inverted.
No Pete, you got it wrong. The doc slapped the nurse. He had to stop her from laughing at him.
Enough already , what is it kick the pope day or something ? If you must know when the pope was born he was so ugly he slapped himself in the face . Even Tele has had a shot , he's finaly lowered himself to my level . He must have a sense of humor after all . Who knows one day we might become friends ! cheers the pope
FA 30, 56B, 72B, 91S, 115, 220, 90TS, 100T, 100TI & 200TI.
FG36B & FG57T
These engines are taken out of production for March, 2016.
http://www.saito-mfg.com/Stopproduction.html
●FA-30S(H) ●FA-56B ●FA-72B ●FA-91S ●FA-115
●FA-220a ●FA-90TS ●FA-100T ●FA-100Ti ●FA-200Ti ●FA-30S(H) ●FA-56B ●FA-72B ●FA-91S ●FA-115
FG36B & FG57T
91s
I do like the direct fit 100, but for some projects the 91 is the perfect match.
Linkan, your posted link does not work.
I just took a few minutes, 35 minutes in truth and ran an old .65 I in which I installed new Boca Bearings. Despite the ancient design of the carb and 12.7 to1 compression it indeed ran like Swiss watch.
Engine===early Saito .65
Fuel=====Wildcat 2/4 10% with 18% full synthetic
Plug=====Fox Miracle
Prop=====Bolly 13.5x6
Exhaust==new style caste, "revised" muffler
Max rpm=9,600 a little rattily. richened to 9,500 for smooth as silk
Idle=====2,150 again nice and smooth.
It's 41 degrees here, 35 minutes was enough of that. No today pictures.
Dave what are you doing with that 65? I assume you aren't running any nitro because if you are you sure as hell aren't really trying. What sort of Bolly prop, the sportsman? My "sports" figures with a 13 x 6 APC are 11,500rpm with 10 % nitro and 10,500 easy with no nitro. It will take 20% nitro with no worries and 20% oil and run well. With a 13x6 carbon prop and 30% nitro 13,000rpm is easily obtained.
I use throttle trim to shut mine down & that eliminates any siphoning. I use an electric started for the 1st start of the day to get things juiced up only cracking the throttle just before I start to spin it over. That routine works well W/inverted Saitos
These are my numbers from a few years ago on the .80 with 15% Wildcat.It was a discussion in Tachometer readings Forum. The same 13.5x6 Bolly.
Earl, your numbers coincide with mine. Yesterday I ran my old high compression .80.
Fuel=== WildCat 15% 2/4 with 18% all synthetic.
Fox Miracle plug
Prop===Bolly 13.5x6
Muffler==Davis SoundMaster In Cowl
RPM=======10,200.
Fox Miracle plug
Prop===Bolly 13.5x6
RPM=======10,200.
