In the mid sixties Donna Mae Mims pink Corvair had a humongous oil cooler mounted on top of the rear fender. It helped keep the Corvair ahead of it's SCCA class, but only for a lap or so, then the engine blew anyway.
Don't/didn't some bikes run the oil through the frame tubes to help cool the oil?
I think I remember seeing some bikes when water cooled engines started coming into vogue having small oil coolers as well. Automobiles have had a transmission cooler built into the radiator from the factory for more decades than I can remember. I can't remember seeing a car that didn't have it.
I was redlining thru the gears and leaned over when a poodle darted out in front of me. I hit him with the front tire, which launched the front wheel up in the air. The rear wheel went over him like a speed bump, so I was airborne for a while. Landed on the rear wheel doing a wheelie. I should I have been tomato soup all over the roadside.
![Frown](images/smilies/frown.gif)
Oops! Almost forgot the required Saito note. I have a 100 inverted in a WM Chippie. Runs great and starts so easily. It came with a heavy smoke muffler which required lots of lead in the tail. I never use the smoke so will probably go back to the stock muffler and lighten the plane.
Nope, they were factory options, some MGBs had them and some didn't. If there's no oil,cooler, the engine is fitted with a bypass hose. Most that I saw in the desert southwest had them. I've owned two MGB tourers, both had them.
Interesting about the Corvair racer. I owned three different Corvairs. Too bad GM never figured out how to keep the oil in them. Dunno about the bikes.
CR
CR
CR
CR
Hell no but thought i heard a hissing sound normally associated with tubed tyres going flat quick.
RC i never talk about that,hospital food leaves a lot to be desired nowadays and it's depressing to be stuck helpless and flat on your back/side etc (don't popey).Back in the day you would get three course dinners at night to help you sleep,specially straight after it happened and if you could use a knife and fork without help you wer'nt doin too bad.If it hurt getting gravel rash pebbles scrubbed out with disinfectant by the ugliest ward matron you ever saw you knew you were fit enough to be riding again in a week if you had a second bike.After that it's all good again![Smile](images/smilies/smile.gif)
Charley you need long body stands just to get the mgb's e types and xj6's up to waist height where it's comfortable to work on them.Beautifull cars i'm too lazy to keep one running now.Oil coolers are handy where it's hot.
My TR-3A had the electric OD (0.8 to 1 I think) as well but I don't remember it having an oil cooler. Then again Standard used a modified version of their tractor engine so it probably didn't need it. I had the convertible soft and factor hardtop. I still have my factory service manual and I believe it shows the installation process for the hardtop so that leaves me to believe it could be added by the dealer as well. Even with the hardtop on the heater still did nothing in winter.
I knew a guy who owned a MGB he installed one of those 264 CID V8s Buick designed back in the 50s that Leyland, Saab, and assorted others licensed for decades. It made a nice sleeper just like when the TR8 came out and everybody would mistaken them for those puny TR7s.
My TR-250 with overdrive had a transmission oil cooler. Had to buy universal joints by the case as the IRS (Independent Rear Suspension, not the tax guys!) ate them at a great rate.
Saw a couple of big Healeys retrofitted with V-8's. Lots of fun but even the 72-spoke wire wheels could not take the torque for long.
CR
![Embarrassment](images/smilies/redface.gif)
CR
CR
I think what made them fun to tinker with was the simplicity of design. There was much you couldn't fix yourself provided you stay away from trying to adjust the Lucas voltage regulator. I loved the piston carbs, easy to work on, and you could fiddle with the air/fuel ratio by swapping needles. The solid brass fuel cutoff was gorgeous to look at until the natural cork packing died and you have to make a new on. Even the clutch and brake hydraulics were easy to work on compared to American cars.
Ok in spite of my best efforts I must go back on topic, I have a VK Models Fokker DR1 kit I needs a power plant. This plane flies a lot smoother with an OS .40 or .46 than the recommended .60 as recommended back in the 70s when this kit was designed. The weight comes out to about 5.25 lbs and I was looking at the Saito FA-40A, I am looking at opnions with this airplane engine combination.
