Richard and Pete, here is a little trivia, Harley was the first to use one quarter speed cams, supposedly to reduce friction and heat and reduce the torque required to turn the cams. They were made by a man named Schaller. As you can see this bumpstick by Ed Iskenderian has twice as many bumps. They never really caught on.
VBR, Richard
I have CR and I would say your experience is in the minority. Overall the Yugo was a failure. If it had not failed it could have been a big success in countries like India and on the continent of Africa where there was and still is a big demand for an inexpensive car.
I suspect you have an attitude that you can't defend rationally but won't give up. Forget it.
CR
Saito FG-40 info wanted please
I've posted the same request on the gas forum too, hoping to benefit from the wider trawl.
I have been flying a couple of FG-36's for the past few years. Mine are the really early ones and have been trouble-free. I'd like a tad more power for a 27.5% Bucker Jungmeister I designed a while back which came out rather heavier than I wanted, and if the FG-40 would give me 400 or 500 more rpm on an 18x8 APC wide blade, it would probably do the trick. The 36's give me about 7700-7800 on that prop, and I'd like at least 8200-8400.
Or, is the 40 better on bigger props, say 19x10, on which prop I think the 36 would be lucky to reach 7300 or so.
Can anyone help?
TIA
Gordon
Can anyone help?
TIA
Gordon
Starting a new Saito question: I recently purchased a used Saito FA-56 and ran it on the bench. I used a 12x6 MA prop, 20% nitro/20%synth oil. It ran quite nicely even though I didn't have a way to tach it since it was late in the afternoon shade. The questions I have are:
1. I would like to reverse the carb orientation, but I can't because the intake manifold is stuck in the carb and I am afraid to apply too much effort to twist it. Any tricks for that?
2. The compression feels very soft statically even though the idle, transition, and wot performance were quite nice. Should I do something about that? I guess top end performance is the sole indicator of compression health?
3. Can the FA-56 handle an APC 13x4 prop? I need something with 4 inch pitch only because I want to put it on a floater plane. I suspect a 12x4 is too small for this engine?
Thanks in advance.
Thanks in advance.
H, the O-ring may just be stuck a little in the top of the carb, they don't turn easily anyway. I can't respond to the popsickle stick prop question, I've never owned any, I prefer, make er go props. Is the valve lash OK, not set near zero as some advocate. I have been using the Saito provided gauge for 28+ years with never an issue. Thanks
A year or more ago I bought a used Saito 125 ( I think its 125) and put it in a Top Flite P51, Today was the first day I had a chance to fire it up. All I can say, the previous owner had tuned it well. It fired right up ad ran perfectly. It flies the Mustang very well, nice flight at half throttle. Hoping I can keep from cracking up the plane on landing so that I can get good at flying it. I finally worked out the snap roll issue by reducing the elevator throw, and it is a nice flyer.
I set the valve gaps to .04 pass, .10 no pass. For the o-ring, can I use some penetrant oil to help loosen it? For the prop, I need a low pitch (x4) because the Rascal 40 would never land if the prop pitch is any higher. All I have is the APC in teh 13x4 size and I am too cheap to go buy another one.
Hi hsukaria.
I use the "power factor" to get ballpark prop selections.
The power factor is a comparative number calculated by multiplying the diameter squared by the pitch.
ie a 12x6 would have a power factor of 12x12x6=864.
the 13x4 would have a power factor of 13x13x4=676.
It is therefore slightly less propellor for your engine and you can expect slightly more rpm.
Below is the data for a Saito FA82B recommended props. You can see that the data points fall in a distinct region.
Any unlisted props can be used if their calculated data falls within this region.
Now this is the data for the FA56 recommended props, with your 13x4 added in in red.
This post is an attempt to help hsukaria, but also a discussion point to which I would welcome comment from the more experienced guys.
Charley okc feels like that way about YUGO that i feel about harleys and dave forgives me for that plus! if the 'allied bombers" had managed to lob a few through the LADA fourwheel drive factory there's many people who would shout them a box of beer at least.
Huk i've never run a 56 but my 62 loved a 12x6 popsicle stick..
Nice bike Mr Fart, but has anyone any advice regarding my Saito FG-40 questions in post# 31,506?
Pretty please?
Pretty please?
Can anyone help?
TIA
Gordon
Can anyone help?
TIA
Gordon
was not necessary, we do know how to go back and read previous posts.
Hi hsukaria.
[QUOTE=spaceworm;12211482]Looks like you got your answers over on the Gas Forum. [\QUOTE]
No I didn't. Regrettably you didn't understand that reply. The reply was in respect of the OS 40cc petrol and had nothing to do with the Saito 40cc..
So many of the recent posts on this huge thread related to motor bikes, old cars and farm tractors (interesting though they are in their own ways) that it seemed worthwhile attempting to get back on to the topic of Saitos. My re-post didn't take me any effort, and maybe would have saved others some time.
Clearly you set out to be unhelpful as your post had nothing of substance to say about the Saito 40cc. (Does that make me a stinker too? )
Gordon
Gordon
Some of the guys here dont like stinky engines, if it aint glow, it dont go. I have run both glow and gas, and love the efficiency of the FG-11. The FG40 might pull more RPM than the 36 after break in, that 4CC could be the difference you need. I would put the FG57T on it though if it would fit, then you have plenty of power, and one bassadd looking plane.
Thanks acdii. Funnily enough, I don't find the Saito petrols stinky at all. They run so cleanly that apart from a dab with a damp cloth at the rear of the cowl to remove a smear from a small oil weep from the exhaust rocker cover, the models don't need washing after every flight like equivalent size glow-powered models. I recently re-engined one of my models with a 40cc Laser 240 vee twin glow engine and have rarely had such oily hands before. So the Saito 36 is going back in even though the Laser is 500rpm faster on an 18x8 APC wide!
FWIW, here's how I dispose of the crankcase breather oil on my 36's:
The result is no breather oil anywhere on the models. Additionally, the Walbro carb won't let fuel through unless the engine sucks it. This means that I can block off both fill and oveflow vents to stop petrol fumes coming out of the tank. You can't do this with a glow carb, since if you do, if the vapour in the tank heats up in the car on the way home, the pressure in the tank will increase and force any residual juice out through the carb, to drip onto the car floor. I only made that mistake once.
Judging by the apparent reluctance of anyone to own up to having a Saito FG-40 it looks as if I'll just have to cough up the dough and see for myself.
Cheers
Gordon
Cheers
Gordon
The engines are a whole lot cleaner, but the fuel itself stinks, storing the fuel is dangerous too unless you have a shed. My T-Clips is gas, and even though its sealed up, it will still smell after a while, especially if its in a hot trailer. I scavenge my crankcase to the exhaust, so other than a few specks on the landing gear, no cleanup needed.
[QUOTE=Gordon W;12211566]
Yes it does and if you don't settle down soon i'm shoutin you guys a harley each so you can suffer like we do PFFFT
Gordon
Gordon
Pete maybe I'm going to the dogs, I am buying an other OS, a .95v and am looking at a water cooled Harley. A Saito 1.25 is in my slightly more distant future too.I may be busy tomorrow, all the stuff I need to re-charge the AC in my truck is coming. Yes, including a vacuum pump. A new tool never goes to waste.
