They were fun little cars but you had to love to tinker with them or they were a nightmare!
Barry i was lying about having a great sounding ducati vid but i bet it scared the bejeezus out of hobbsy.
Trev you're startin to sound like biggles,just kiddin but seriously i will pour some scorn on o/t flyers,reckon hobbsy should join up all you old guys lay back and watch something go vertical whether it's a 9 or 69 i don't get it.How about going flat out in front of your face with a low flyby so you get a good earful of saito?..can i hear some abuse coming..
Pete, I scored the perfect plane kit for my Saito 1.50, (the one with the C&H Ignition), . It is an ACE 4-120 Bipe with the original tape still holding the box closed. It will be arriving around the 30th. A fun winter project.
old fart o/t duration models in full song are probably the only models that use full down elevator on take off. One of them out of control is scary, doing a " figure 9" is very dangerous and the potential for injury to spectators / support team let alone yourself is very high. I suspect you have not seen a full blown competition try to get to one of the SAM comps over your way or better still try flying one of our models. For the record I have flown all classes of pylon as well as scale raving. The incident I described was one where ego over come skill and fortunately no one was physically injured. For the record I think I have tamed this NBN thing but I am still wary of it.
Sorry trev and thanks for the polite answer,yes they take a bit of flyin mate.
Dave in loo? of the missing ducati sound vid i send you a free pic you can convert to a vinyl wrap on the side of the harley tank,if it comes out sideways you'll have to straighten it up yourself
Painted it yesterday for this weekends hotrod show
Pete, is that one half of a fuel tank for something,you do good work, Thanks, Dave
As I was breaking in the OS .95v with a Xoar 15x6 my tach went dark as I passed through 9,250 rpm, I'll get it all the way peaked today. I picked up a new tach battery yesterday. I've got roughly 90 minutes on it so far.
If you're going to put a revolver on the tank make it something special like the S&W 500 Magnum also know as a light artillery piece.
Well guy check out what I picked up last night a new addition to my stable of Saito horse power. A vintage Saito FA-120 (Guess what's wrong with the pictures an win a burnt cookie postage not included) and an O.S./Graupner first generation Wankel (some assembly required). I haven't decided if I'll keep them or not, I'm still looking for work.
Mike
Mike
That artwork is on the left hand tank of a harley soft tail show you the right hand side next. post a pic of the 95v?
Okc you left the axle and wheels off the s@w 500 revolver,here's the perfect rat rod bonnet for some target practice(39 rambler hornet) coming next post
There aren't any words for how beautiful those tanks look, Pete. Well, awesome comes to mind.
Thank you for the compliment barry i enjoy doing them for customers too.Brings a smile to their faces.
Dave that boss hog has some serious alcohol sponsership! and sounds like i should be riding it that towbar looks like it could haul a large keg trailer and i'd be popular with my riding mates...seriously tho some years ago a mate owned a boss hog with 350 chevy over here,can't remember why i turned down the offer of a ride but i think he mumbled something about gonads
Hi Everyone,
I could use some help here. I am replacing the bearings in a Saito FA-100. In the 2009 manual (the latest??) it says that the Front Bearing (Item 20), is p/n 91S22A. However, there is nothing listed for the rear bearing, just a dashed line.... I know that I could get the bearings from Boca or RC Bearing, but I was just trying to tie down this little issue...
Any thoughts???
Bob
Any thoughts???
Bob
The Saito 100 uses the following bearing numbers:
Front R6-ZZ
Rear MR6903
I found the front bearing can be the sealed type, (2RS) rather than the shielded -ZZ designation. On either you remove the inner shield or seal for better lubrication.
Front R6-ZZ
Rear MR6903
Hi Everyone,
Any thoughts???
Bob
Any thoughts???
Bob
I always buy two sets for the same job cause it's easy to lose your temper with a hammer.
I could go digging for the Boca book or log onto their site and dance all the steps every time required, but I found it much easier to record the bearings for my own engines and any that I commonly saw across my rebuild table. Much handier that way. In my case it's a simple WORD document on the PC that is easy to update and print out when needed.
This is what I have that covers my own size range:
SAITO FA56 MR698-ZZ MR6901
SAITO FA65 MR608-ZZMR6902
SAITO FA82 R6-ZZMR6902
SAITO FA91 R6-ZZ MR6902
SAITO FA100 R6-ZZ MR6903
SAITO FA125a 6000-ZZ 16003-ZZ/C3
Boca does have excellent coverage and quality choices and if your side of the border would make sense to order from them. However, since I dealt with our local bearing house quite often for work I was able to purchase the higher quality bearings for the same price(s).
Here is where I try to point out saving a few dollars on lower quality bearings is NOT good economy. They tend to fail much quicker from physical and/or chemical stress and now the entire teardown needs to be repeated, AGAIN! Also, the bearings may cause damage to other engine components not otherwise at risk. I once received a 100 bolted to an airframe and found the bearing failure also scored the liner, causing it to peel off in chunks. Costly delay from the previous owner in catching what should be relatively obvious.
ps. From my own experience I would recommend not going for ceramics for these apps. If true they are so delicate at room temp simply placing one on your finger and spinning the outside race by hand will guarantee almost immediate failure, (mind you, ours were 100K apps so things tended to happen much quicker). By their nature they toughen when heated but doubtful you want to work with them that way.
More than likely. Our 100K apps were dry, as well. My friend and his turbine group use oil mixed in the fuel, (same as IC machines) to lube their bearings. Those can run well over 100K with more modern versions upping the power to weight by spinning the same core even faster, (the unfortunate disadvantage is the higher gas flow makes their noise level go up). That environment pretty much specifies ceramic- and very careful balancing and assembly.
The reason I recommended avoidance was due to their strict requirements. I have been repairing and resurrecting engines for more than 3 decades and stay away. Unless extremely special use there are much less expensive options that will work just as well for our sport needs.
All I`m saying is even when at work with the proper equipment and fixtures the errors are easier to make and the failure rate can be greater. Do the math for someone at home.
To be fair the ones from Boca may not be true ceramic, with a combination of metal races, etc. This would perhaps make them less susceptible to room temp stress. Don`t know as never ordered any.
The fully ceramic bearings I would avoid, they might not be as tolerant for chock loads, but I don't know for sure.
The "regular" ceramics is used a lot in motorsports etc where there is high stress/-rpm and low lubrication.
As there is no metal to metal contact you can't get micro welding, so the more extreme the running environment is, the more the ceramic will excel. They also offer less resistance from reduced friction and mass.
But a good metal bearing will always be better then a cheap (low spec) ceramic!
http://www.bocabearings.com/bearing-...ito-fa-100-100
In addition to Cougar's numbers here is a picture. I use these exclusively and have them in a Saito FA .40a, an early Saito .65, Saito 1.00, Enya .80, OS 1.20e and in a Fox .50. So far all have been, install and forget. $11.88 and free shipping. I prefer to remove the outside seal on the front, several brands are mfd that way.
