Well good news is I would much rather fly the Rascal with the DA100 than the CARF 330L it is on now. I have never flown it, nor do I want to. I might just strip it of servos and everything else and use them in the Rascal. It has a Powerbox, two Lion packs, 32 ounce tank, and 8 high torque digital servos, along with a standard throttle servo. IIRC the Rascal uses 4 in the wings, two in the tail and one for the rudder, so I will have a spare servo. The biggest unknown about using the DA 100, the prop clearance. It swings a rather large prop, 28x10 is what I have now.
Given that the Rascal 168 is 53% larger, it should have room to swing a 30" prop. You might consider going to a 30 x 8 for the same reasons.
Yep, after watching the video I can see there is plenty of ground clearance. The wing design looks very strong with a full center section and 4' tips with dual tubes to attach them to. I think the DA100 on the 168 would be the equivalent to the Saito 100 on my 1/5th Cub. Calls for a .60 FS, and I have a 1.00 FS. The 168 calls for a 60CC, and I have a 100CC.
If you pull a + 4 -G maneuver, that's 88#of dynamic load on each nylon bolt. SIG only spec's a 60cc maximum. When you exceed the spec, you need to make sure the airframe will be up to the added stress.
I would add some wing struts.
The other alternative would be to substitute metal wing bolts, but then will the anchor points hold up?.
I have been looking around and see that DLE has a good price on 111. But I sure would like to put a big saito in the rascal. Refresh my memory,what is the biggest saito they make.
Boy there are so many choices. It all depends on how I would like to fly a big airplane.
now I see the problem that acdii is having. Well at least I still have a lot of time to ponder.
Sure would like to see a Big saito in it.
This will probably be available before the Rascal 168. It has the Ray English intake modifications for better A/F distribution. The FG-84 has had temperatures that vary widely between cylinders and this modification has addressed that flaw.
https://www.youtube.com/watch?v=o7aXsrTY5Qc https://www.youtube.com/watch?v=c_9OM8eCGV4
Psst, Dave has an impressive collection of props. Some of our perceptions come from how we fly. I'm not a pattern competitor but I like to fly pattern stuff and expect good vertical performance out of my planes. So, my way of flying shows up good/poor performance more than guys who enjoy just flying around, flying on the wing, and doing touch and go's. Let's hope Dave uses the right APC so he sees how well they perform.
There you go, making me ponder some more. thankyouverymuch. Well, it all comes down to one thing, money. I aint got none at the moment, so will have to wait and see.
This is why I aint got none.
My Feedback: (213)
Just discovered this forum. Getting back into flying after after a forty four year hiatus. Have a lot of these saito engines and love them all. Is it still possible to join this brotherhood?
Mailtape bear with us you'll get sa number very soon!
Mike
Numbers? Wenoneednostinkinnumbers
It's actually cleaner than my house! Well, except for my workshop.
No way, I just got it in June and took three trips already that we normally would not have been able to afford when you factor in hotels and meals. Been to Utah and back. Got some really nice pics too.
Was that (three panel?) windscreen ever fitted to the J3? Thanks.
Sincerely, Richard
AMA 861960
Cub Brotherhood #187; Sig 1/4 (Koverall/dope), H9 100 inch (Gen 1) (Solartex/?), GB Anniv Cub (NIB)
Club Saito #635; Saito 56, 100, 120abc, 130T, 180
I am seriously thinking about this end of life approach. When you consider the initial cost of the RV, and the low fuel (diesel?) mileage, what does the cost per trip, amortized over the RV's life and resale value, compare to what trips by car and hotels would be? Did you have to sell your primary residence as did another poster? If you did, do you have a trailer to tow behind the RV to hold your RC stuff Thanks.
