Old 09-21-2016, 02:50 AM
  #32226
SrTelemaster150
SrTelemaster150's Avatar
Originally Posted by RC Specialties
I have a question. All of Horizons data shows the FG-30b to have a 14x1mm exhaust thread. I have a customer that claims differently. Horizon Product Support says it has a 14x1mm exhaust. Can someone please confirm.
Originally Posted by liemtran75
Just to provide some additional information regarding the adaptor and muffler I got from Jim. The picture shows the manifold that came with my Saito FG30B. The diameter is definitely bigger. Maybe Saito made some recent changes.
Liem,
Thanks for the photo. Something is strange with the Horizon data. Maybe other owners can help us solve this puzzle.
Jim
According to HH's site, the FG-30 takes the same 14 mm FA-120 based exhaust pipe as the FA-120-150-180. (SAI120S75A)
This is nothing new.
Old 09-21-2016, 03:17 AM
  #32227
RC Specialties
SrT,
You are correct. HH does show the FG-30B uses the 14x1 header pipe and nuts used on the engines you mentioned. I believe this to be in error. I spoke with HH support and they verified what is shown to be correct. I plan to call them again today. Liem's measurement indicates a 15x1mm exhaust. Which seems odd given it is a 180 size engine.
Jim
Old 09-21-2016, 03:18 AM
  #32228
Hobbsy
Hobbsy's Avatar
Jim, maybe he has a 2.20 and doesn't realize it.
Old 09-21-2016, 03:26 AM
  #32229
RC Specialties
Dave, Liem sent me a short video and the engine had the FG-30 markings on the side. I did find a list of four stroke prop shaft and exhaust sizes and it shows a 15x1mm thread for the FG-30. We will see what HH says.
Jim
Old 09-22-2016, 03:37 AM
  #32230
Captcrunch44
Sr
so can we base the power out put on the new FG 90 cc on the 84 cc adding say 10 percent. I am just trying to wrap my head around the power. And a radial engine has better torque then an opposed engine?
Old 09-22-2016, 04:03 AM
  #32231
Hobbsy
Hobbsy's Avatar
You guys need to quit this, you keep makin me look at the FG 11.
Old 09-22-2016, 04:49 AM
  #32232
Rudolph Hart
Rudolph Hart's Avatar
That will be a step up from the 125
Old 09-22-2016, 05:12 AM
  #32233
FlyerInOKC
FlyerInOKC's Avatar
They are a cruel lot aren't they Dave?
Old 09-22-2016, 05:19 AM
  #32234
acdii
HA HA!! Nothing wrong with the FG-11 other than lack of grunt. It will fly a long long time on a few ounces of fuel though.
Stop picking on the 125, mine works great, though it does like the alky, kind a like old farts do.
Old 09-22-2016, 05:34 AM
  #32235
SrTelemaster150
Originally Posted by c-crunch
Sr
The FG-90R3 has a better intake plenum design & it will be much more efficient than a stock FG-84R3. The FG-84R3s that have the Ray Engish modifications would be a better benchmark to work from. The power increase over the stock FG-84R3 was over 35%.
If you want to estimate the outputof the FG-90R3, look at the various Ray English modified FG-84R3s & add about 6%.
https://www.youtube.com/watch?v=ffUehgpp8Ug NOTE: The intake modification as shown was a "red herring" in case Saito tried to steal the design. (they did)
Saito has since licensed Ray's intake design.
Old 09-22-2016, 08:36 AM
  #32236
p3arljam
Can anyone tell me the best way to get after run oil into the breather nipple on a Saito 82?
Old 09-22-2016, 09:07 AM
  #32237
acdii
get a tiny container, like one of those medicine measuring cups, put some oil in it, then stick a fuel line on that nipple, and the other end in the cup and spin it with a starter. You should see oil move in and out of the tube. Start with the piston at BDC so it draws some in quicker. If you have an aerosol can of oil then stick the nozzle tube in the fuel line, and at BDC squirt some in, spin it with the starter and repeat a few times.
Old 09-22-2016, 09:31 AM
  #32238
p3arljam
Thank you sir.
Old 09-22-2016, 11:01 AM
  #32239
SrTelemaster150
I CA'd a brass tube over the plastic straw that came with this & that adapts to a piece of fuel line that will fit over the breather nipple. Rotate the propeller to place the piston at the bottom of the exhaust stroke & you will see the fog pressure turn the prop as it forces the piston to the top. When you see bubbles around the pushrod cover rubber, you know that the crankcase is well lubed..
Old 09-22-2016, 11:40 AM
  #32240
p3arljam
I just thought of something and i know the answer is probably obvious but i am missing something. I fly all my saitos with a piece of fuel tubing coming off the breather nipple out the bottom of the cowl to to allow for a less messy cleanup while flying. If i am trying to add oil thru that same nipple and spinning the prop wont it be pushing the oil out like it does while i am flying?
Old 09-22-2016, 02:44 PM
  #32241
blw
blw's Avatar
I have a 72 in my Something Extra, and it is a little power house. One time I was taking off and was about to run out of runway due to tall grass, so chopped throttle, and just as i did that, the plane decided to lift off, so I firewalled it, and it pulled the plane straight up. Good little engine and getting better the more I run it, getting good fuel economy too, I have yet to fly long enough to empty a tank. 15 minutes and I still have at least a half tank.
It too does not like Castor based fuel.
acdii- are you saying the Saito 72 doesn't run well with castor? Not sure of what you are saying here.
As for how the SSE flies, remember how short coupled the model is. Mine may knife edge and I'm going to find out when I fly it again, but that's because it was built with fairly large counter balances. That may be enough.
I used SSEs as trainers teaching students to fly (on low rates). It is what they call an honest design. The only plane more prone to good hacking and modding is the Sig 4 Star, imo.
I have a basket case model that is just bones built by someone else and given to me. I'm thinking of lengthening the fuselage at least 3 inches for a Saito 72.
Old 09-22-2016, 02:53 PM
  #32242
Charley
I suppose it's the difference between the crankcase pressures when the engine is running versus when it's flipped or spun with the starter. There's no combustion blowby past the rings to affect the crankcase pressure if the engine is just turned over. True, there is air in the crankcase displaced by the piston going up and down in any event but not as much without the blowby. Personally, I like to invert the engine somehow while injecting after-run oil into a 4-stroke crankcase. That way, only air gets blown back out the breather nipple when the engine is turned over.
CR
Old 09-22-2016, 03:13 PM
  #32243
blw
blw's Avatar
Originally Posted by Old Fart
Dave could you explain what sangria is and does it have castor in it? Grand Marnier may have some if that's what you are looking for.
Acdc what size tank to you have on the 72? i use a 14oz tank flying the 82 and that will get me a safe 10 to 15 minutes with different needle settings and flying style.
Old 09-22-2016, 04:35 PM
  #32244
acdii
None of my Saitos run well on Castor based fuel. They smoke heavily and burble at WOT, and no amount of tuning will get them to run well. I switch back to Wildcat and they run great.
The stability and big wing is all that saved mine when the elevator servo died in the up position.
Old 09-22-2016, 04:38 PM
  #32245
acdii
CR
This is correct, you have positive pressure in the crankcase when the engine is running, but when you are just spinning it you are drawing the oil in and pushing air out, and spinning helps to wash the old fuel and crap out of the bearings while you spray the oil in.
Old 09-23-2016, 04:14 AM
  #32246
SrTelemaster150
If you use a product in an aerosol can, you won't have to do the rotation thing as the pressure from the aerosol will force the ARO into the case. Having the piston at the bottom of the exhaust stroke allows the case volume to increase when the piston is forced upwards as the pressure is applied, thus allowing more product to enter the case.
Old 09-23-2016, 04:22 AM
  #32247
Captcrunch44
Well here's my 2 cents worth. I just use a fuel syringe. Suck up some oil and squeeze it into the breather nipple.
Old 09-23-2016, 04:52 AM
  #32248
acdii
I rotate it to help flush out the waste oil and contaminants. Helps get the good oil around the bearings where it is needed the most.
Old 09-23-2016, 05:15 AM
  #32249
Rudolph Hart
Dead right and the prop turns on it's own as you squeeze the plunger.A couple of hand flicks to check all is good and hit it with a starter.You can get to the after run/flying beer fridge quicker.
Old 09-23-2016, 05:26 AM
  #32250
alex24
Here is a short video of the clip of the Hangar 9 F4U Corsair 60cc with the Saito FG-84 3-Cylinder. Enjoy!
https://www.youtube.com/watch?v=7IK0Sk2Mv1I
