CARF F4U-1 Corsair build thread
#302
We will get the gear mounted in the wing on BIG HOG #2, install the outer panels on the folding mechanism, and then that will be removed and sent to Mitch for conversion. The gear doors and canopy will remain air operated on #2.
#303
My Feedback: (27)
ORIGINAL: ram3500-RCU
Here are the mains.
Here are the mains.
#304
ORIGINAL: samparfitt
this worked for mine:
I also don't like the location shown in the manual for this servo. Behind the cockpit and basically inaccessible after the cockpit is installed. I was going to move it down and into the wing saddle area on #2, so I could get to it and also to move the weight forward. An 8711 weighs 2.5 oz, so if mounted in the rear, it needs about 10 oz in the nose to balance it out.
#306
ORIGINAL: onewing
Gary, on the second picture of post 295, when gear is deployed (lowered), the threaded rod extends pretty far back. Would that interfere with the main spar?
Here are the mains.
Here are the mains.
Good news is, the jack screw, at it's farthest reach, will be well below the top structure of the bay.
#310
My Feedback: (158)
http://www.servocity.com/html/servo_savers.html
Gary,
The plane is looking great
#311
you should go to corsair 82 to see a real giant scale corsair. i dont know how many cc's the engine is but its somthing like 1600 liters,,hehe.
#312
ORIGINAL: fred985
I recently subscribed to Model World, a UK magazine, because of all the wonderful GIANT scale planes they build oversees. Very cool stuff.
#313
ORIGINAL: fred985
www.youtube.com/watch?v=bra3hyUrcuk
#314
My Feedback: (60)
AZ
The Corsair82 is an 82% scale homebuilt Corsair replica. That's replica as in man carrying aircraft rather than a model. Just in case anyone was wondering! ![Smile](images/smilies/smile.gif)
http://www.corsair82.com/
#315
ORIGINAL: Chad Veich
The Corsair82 is an 82% scale homebuilt Corsair replica. That's replica as in man carrying aircraft rather than a model. Just in case anyone was wondering!![Smile](images/smilies/smile.gif)
#316
While we are at it, how about this Spit? Quite the project.
http://www.youtube.com/watch?v=Z9VuQxVPqbE&NR=1
Taking a break from detailing to do some 'surfing'. The chips are still flying.
#321
The electric gear for #2 is almost installed now. Here are some pictures. Note the 1/8" shim under the front of the body. This eliminated any shaving of the underside of the skin above the gear. Only the one side of the housing needed trimmed.
#322
It is an easy thing to remove the electric assembly so the gear can be moved up and down during installation.
Also we will simply use a small drill bit and by hand mark the spar for the little hole to allow the jack screw to go through it.
#323
Brian cut out the gear doors from the oversize piece they give you, and then used that finished size to mark and cut the openings in the wing. Worked well.
BTW, he used a diamond embedded cutting wheel on his Dremel to do the cutting. Worked great on the CF.
#325
Now for some fun. Here is the first test of our simulated gun flashes. The final LEDs and gun barrels will be about twice this size, although the same little boards will run them as well (three on each side / board). The LED is about half way buried in the barrel, and reflect all over the inside of it. The effect is pretty good. Even this smaller LED is very bright in person.
http://www.youtube.com/watch?v=-dgHa4hCI6o
Imagine some sound and smoke with this.
