Composite ARF Mig29
#305
My Feedback: (44)
IL
Today I got some time to work on the Mig 29 I cut open the inlets and install the screens and then I will cover it with 1/64 lead sheets ,after that I will detail the doors. This also will give it some weight so they will close when it's not in-flight I don't use the hydraulic on the inlet doors they are just by gravity.
#307
My Feedback: (44)
IL
Hi to all,
The weekend was here and some time to work on the Mig 29 I just finished the on/off fuel valves controled by a manual push pull system and close to the engines which they are operated from the service panel. I have also finished the lineup for the engines , pumps and ECUs will be next until next time I'll see you all
#308
Sure can. Will get them out and measure it up and post it here for you.
#310
My Feedback: (44)
IL
Hi Walter, I hope you get well and is nice to hear from you . What measure do you want ? length or diameter . I am doing the wing with one bolt in the wheel well to hold them on. I will post later with pictures.
#313
#314
My Feedback: (44)
IL
Hello there, I was testing my hydraulic system and unfortunately the The pressure board or ECU does not work if anyone has one spare and they can spare it,I would appreciate it here's the picture of which part I'm looking for,thank you Nick.
I tried emailing to hausl in Germany but there is no answer back .
#318
Hausl
The Hausl business is now Modell Technik Hausl, Weyerngasse 41, 8720 Apfelberg, Austria, www.modelltechnik.at Email: [email protected] I'm about to buy their hydraulic system and valves for my MiG-29. The units are only made to order and delivery ex-factory is 3 weeks after receipt of order. The HPU10 pressure unit is EUR 365 and the V4/2N2 valves are EUR 48 each.
#320
My Feedback: (206)
Also looking for a droug chute and tube if anyone has one. Or really if you have a wrecked bird lying about it could use a few parts. PM me or email me at [email protected]
There are several parts I'm looking for that I could use to complete mine.
#321
#323
My Feedback: (44)
IL
TSHArK203 for the feather turkey I just eyeballed it a quick measurements on the distance between the support for the pipe and just cut the ends and use a pair of pliers to make it rough at the ends look at the pictures I also went down to Menards and got a graphite paint spray for high heat and I shut it a few times,I think it looks OK
#324
These are big wheels and brakes in as new condition.They were NOT cheap.
So, 200 us d for the pair (cheaper than a set of wheels for my BVM F4!)
David.
David.
