The new Tornado sport jet
#3351
RE: The new Tornado sport jet
ORIGINAL: colesifer3d314
Mike,
i have thought that same thing..which engine would you recomend? i was thinking the k80g or the p-60se
Cole
Mike,
Cole
Mike
#3352
My Feedback: (9)
im on a budget bud..so having this engine i have is kind of keeping me to what i have at this point..but the weight is def a concern with me..but if it ends up being what i have to use to get started than its what will be used for sure.
Cole
Cole
#3353
My Feedback: (25)
Why don't you sell the p80 and buy your self a k100. More power less weight much faster spool up time warranty etc.
The Merlin series mike mentioned are also excellent but a bit more expensive than the kingtech.
You'll be much happier with the airframe as a whole with a k80/100.
The p80 will make it extremely tail heavy which you will counter with lots of nose weight which will
significantly increase wing loading. Then you'll have to deal with additional stress on the Airframe and gear from all
the increased weight, and reduced flight time from the increased fuel burn.
I understand the budget part most all of us have been there.
But if its a matter of holding off a few months to fly and get a better suited engine...i would personally wait.
Besides why come on here asking opinions of the p60 vs k80
to just say the p80 is all you have and that will be the engine you use????
#3354
Cole
Cole
Mike
#3355
My Feedback: (9)
i really do appreciate the honest information guys..i guess ill post the engine up for sale and see about buying a kingtech..which i know would be the better option for me..im looking at buying the ptoling gear set for the airplane so waiting a bit to get the better motor is worth it to me as well..
I already baught the airframe so im commited for sure..so ill work some black magic and see what i cam come up with.
Cole
Cole
#3356
Hi all
finally my Jet is ready to go. Now only the weather has to improve and I can maiden her.
But spring is definitely around the corner. Unfortunately for this weekend the forecast says 35 miles/h wind [&o]
Here are some facts:
JetsMunt VT80 with 8Kg thrust
Hitec HS-645MG on aileron
Futaba S3152 on flaps
4 x Hitec HS-5085MG on elevator and rudder
TowerPro MG995MG front steering wheel
Electric retracts from Lado
Weight (empty main tank and full header tank): 7.5kg
The last thing to do is to get the CoG right. At the moment the plane is tail heavy and I definitely don't want that.
So, no more excuses. But I am actually looking forward to fly it for the first time.
c u
Ulli
c u
Ulli
#3357
Im getting closer to maiden'ing my jet, same colour scheme as 'uixkes' above. Does anyone know where to find solar film or other brand of yellow covering? The ones I've seen in the model shops just arent the right shade of yellow. <div>I had to do a few minor repairs to the balsa sheet on the wing, and need the right colour to go back on top!</div><div>
</div><div>Also what are people using to centre their front strut? I've seen some nifty wire devices which keep it tracking straight, can these be picked up anywhere?</div><div>
</div><div>Jim</div>
#3360
My Feedback: (13)
NJ
That scheme looks awesome, but why did you put your gauges and fill valve on the outside???
ORIGINAL: dslivingston
New Tornado just completed. 100% ready to go. Will maiden as soon as weather breaks sunny this week.
#3362
Hey Guys,
Does any body know if Henry is still doing a package deal on these Tornado Trainer Jets. I meaning just the model itself & a K100 Kingtech Turbine.
Thanks.
Thanks.
#3363
ORIGINAL: Backplate
Hey Guys,
Thanks.
Hey Guys,
Thanks.
ARF 399, gear package 599.
K100G should be from 1800 to 2000....
let me know if you find any different nos....
#3364
Hi Txshan130,
How was your maiden ? You jet looks great and I am keen to know as am considering getting one.... The color scheme is awesome... I think you have a K100G ?
Cheers...
Sandy Jain
Cheers...
Sandy Jain
#3365
My Feedback: (46)
Well I went to fly my Tornado yesterday and guess what? It wll not fit in an Escalade. Out shopping for a 8 x 18 trailor today.
Do not believe what a salesman will tell you when ordering something. It's really my fault I should have done my own measuring. What the heck ... I needed a trailor anyway.
#3370
My Feedback: (114)
Sandy, <div>
</div><div>The maiden went great...only needed 1 click of up and 2 right. CG per manual but showed 2.0 lbs on the nose gear. We glassed the booms and our weight came in at 19 lbs even with UAT full. Maybe a touch heavy for version 4 but it wasn't noticeable on landing. Love the K100G...so far has worked well. </div>
#3372
My Feedback: (114)
Version 3 has composite booms. the latest version does not. I don't mind the weight and like the added strength and durability...had no cc issues with ecu battery in mid-cabin by steering servo. We got 6 flights in on Sunday. Great vertical with the K100 but taking out the smoke system and maybe replacing it with a header tank to get a little more flight time..we're a bit on the short side at about 4.5 minutes.
#3374
My Feedback: (114)
Dslivingston,<div>
</div><div>I know someone who keeps the wings on and transports it in an Explorer I think. He made some rails that he installed in the back of the truck and then places the jet on the rails...that gets him a few inches of space to allow the wings to fit. Not easy, but easier than removing the wings I think..</div>
#3375
My Feedback: (114)
Joseph - we weren't taking the tank down that far as I couldn't see exactly how much was left in it..and we obviously were landing with enough for at least 2 go arounds, but it still seemed pretty empty after 4.5 minutes. Maybe there was more in there than I thought...will investigate a bit more. I think the new plastic tank is a few ounces smaller than the last fiberglass tank in the Ver 3. Maybe someone else could confirm that, but I was told by someone that its at least 5 ounces smaller...
