Hey guys thats no joke cost me a house once,jim start eatin them oats 24/7 we got an aussie jihad comin to this place and your the number one target right now buddy unless sr pops his ugly bean up
my friend has a Saito Twin, I'm 98% sure it's a 100, but it's some 15 years old, and I don't think it's been flown for a gallon worth since the bearings were replaced, I was thinking if I got him to sell it, it would be that cat's tail in my .60 size ShoeString (61 inch span)
Jim
Someone gave me info a while back on setting up a Saito to run in reverse by using the cam out of a twin. Trying to find the data and available engine list it would work with. I need to set up a 90 +/- as a reverse rotation for a scale project.
Has anyone actually done this? Is so, was it typical in performance? Looking at a twin engine application and I don't like electric personally.
guys, is there another place to buy Saito's ??, Horizon isn't stocking all their engines
sorry Thunder, I can not help you there, but you should Google, even YouTube it
Jim
Jim
Boat, if I remember this correctly, this cam is the standard one for the 91S, (engine code K) and for the right side of the 1.82.
https://www.horizonhobby.com/cam-gear--right%3A-g-k-dd-ee-as-bm-bn-bv-bs-ca-sai6535a
This is listed as the left cam for the 1.82, (engine code DD)
https://www.horizonhobby.com/cam-gea...Add-sai182td34
I have no sperience with this though.
Gazing upon the 1.82 helps understand why the two cams are different, when the right cylinder becomes the left cylinder, the front cam lobe becomes the exhaust on the left side. I hope that makes some sense.
It's easier to see on the 1.30.
Thunder tell us what twin you are putting the saitos in? hobbsy's on the money knows his stuff.Sr telemaster it would be good to hear from you too,this guy is good.But...dave and dan like tractors mate so take no notice of their flying tuning tips ok?
ps dan thinks a 115 will tear the nuts out of a 125 anyday in many ways and i reckon he's right acdc
ps popo you throwing up yet?
My Feedback: (28)
Saito parts
The full 1.82 story: http://sceptreflight.com/Model%20Eng...20FA-182T.html
A partial explanation of the cam timing at the top right.
The .91 cam is explained in the right column of this.
http://sceptreflight.com/Model%20Eng...%20FA-91S.html
Counter-Rotating Saito Cams Fact Vs Myth
Attachment 2216172
The full 1.82 story: Saito FA-182T
Saito FA-91S
Saito FA-91S
http://www.rcuniverse.com/forum/glow...l#post12338303
I reckon that's way to sweet dave,next thing you know sr will get fired up about cdi again,man won't that be boring and i don't think popo needs to go on to the dry reaching stage poor bugger.
I appreciate it when fellow GearHeads dig into something I haven't gotten into. Of course, I'm, equally into CDI, I now have a Saito high compression .80, a Saito 1.00, a Saito 1.25 and a high compression 1.50 CDI'd. I was going to do a brand new .65 but sold it instead. I have a second 1.00, you may remember the one with the busted out cylinder bolts, I sorta blew it on that one. I spent nearly what the other 1.00 cost new. Oh well.
What sort of ignition do modern automobiles/motorcycles/outboard motors/etc have?
I shoehorned a system into a .40 size high wing trainer and it was borderline. 650Mah "AAA" battery packs will run a single cylinder CDI for over 30 minutes. If the modules and high tension leads could be made smaller, t would make their use in smaller airframes more practical.
A 1/5 scale Cub has plenty of room.
