Official Jammin X1CRT Thread
#327
RE: Official Jammin X1CRT Thread
crazysavage.
i have a novarossie rex 528 with a rotostart on it.
nib.
the hobby dealer i bought it from has the same engine with out the rotostart on it.
i plan to use bump start on my car.
would it be wise to swap the one i have for the one he has?
please advise.
thx Dirby.
nib.
please advise.
thx Dirby.
#328
KY
what is a "Bump start"?
So you would recomend the kit for flat out racing?
I LOVE to take stuff apart or put stuff togther.
What stuff do I need that is Not Included in the kit?
And what do I need to buy to put the Novarossi in? Exp, Pipe, Shims.
thanks.
#329
SC
i plan to use bump start on my car. would it be wise to swap the one i have for the one he has?
Zoom
If you visit truggyracer website you'll find all you need to know about engines, pipes, tires, setups..... good, specific stuff there.
#331
SC
PA
ORIGINAL: Dirby
crazysavage.
nib.
please advise.
thx Dirby.
crazysavage.
nib.
please advise.
thx Dirby.
#334
crazysavage.
what fuel would you recomend for the nova rossie rex 528?
20% or 30%?
which would make the engine run cooler?
would the ofna p2 pipe work ok on this 528?
thx Dirby.
20% or 30%?
thx Dirby.
#335
PA
ORIGINAL: Dirby
crazysavage.
20% or 30%?
thx Dirby.
crazysavage.
20% or 30%?
thx Dirby.
#336
Hello everyone.
I want to start by saying this is a great forum and I am very very new to RC.
I just bought a X1 CRT RTR and did a 7 tank break-in. It seams to be running great.
I do have a few questions about what is out there for it and what I need to get.
I am looking for a good setup guide for it. Also looking to see if there are any dirt shields for it.
What other hop ups are out there for it I am having trouble finding any after market parts for it.
Are there any bodies for this car once I tare mine up?
Also any thing you can tell me that might make my life easier with my new X1 CRT RTR.
Thank you all for your help.
#338
ORIGINAL: taildraggerdave
I see in Jammin 101's car that there is a lot of exhaust hose. Would seem to me that shorter is better for that. What is the general opinion on that?
#339
crazysavage.
what do you think about the NOMADIO radio and rec?
would you own one and use it?
compared to the futaba 3px?
thx dirby.
thx dirby.
#340
PA
ORIGINAL: Dirby
crazysavage.
thx dirby.
crazysavage.
thx dirby.
#341
My Feedback: (7)
MO
Sighh....
My radio had to get sent off for service, Tx stopped talking to Rx, and my engine (528XR) had an issue with the carb and had to be sent off for replacement. I was told the production run that my engine was in has had several carbs that were sticking across the whole range of travel after slight heat was applied. Novarossi is correcting the problem but it SUCKS having to sit out so many races! I am having withdrawl symptoms!!!
As far as the CRT, I have been racing the crap out of it and had some pretty wild crashes with absolutely no broken parts, except for the body cracking. This is one tough truck!
#342
ordered my second jammin kit today hope to have by early next week.
any suggestions on what diff oil and shock oil to use and what motor should i ger for it.
one thing is forn sure it will not be a v spec.
thx Dirby.
thx Dirby.
#343
PA
ORIGINAL: Dirby
thx Dirby.
thx Dirby.
#344
hey guys just wondering if anybody has put a bigger fuel tank on the crt besides the 150cc that comes on it. if so what tank did you use? thanks shawn [email protected]
#345
NY
Hi ,I have just ordered a 15 tooth clutch bell for my jammin along with some new bearings and a fresh clutch. I have put nearly 1 gallon through my jammin andim curious to see the effect of going to the 15 tooth bell up from the 13 will be.Doe anyone here run that on the stock 28engine and how do you like it . thanks
#346
SC
I've found a 15t cb a good match to the 528. The engine has the torque to overpower tires and the revs to tackle the longest straights. It actually makes the bottom-end a bit more controlable.
#347
hey guys whats wrong with the o.s v spec i was looking at getting one with the jp mod to put in my x1crt i know about the bearings going bad but the jp mod fix all of that
#348
roaddell.
you pays your money and you takes your choice.
some of the guys here had them and some have goten rid of them.
some say vspec some say nova rossie p5
one thing about the p5 is that they use a regular plug not the expensive turbo plug.
i had a v spec in my jammin and i got so agravated with it i gave the whole thing away.
jammin spectrum rec hitec servo 1400mh bat pack jp2 pipev spec engine
right from the first day i had the v spec i had nothing but trouble trying to run it .
it was so tight that it would lock up on tdc and i would have to take a screw driver and turn the flywheel over to free it so it would turn over to be able to start.
well now that motor can bother the guy i gave it to and it won't bother me ever again.
i am looking real close at a p5x for my next motor i have a novarossie rex 528 in my hellfire and i have never had any tyrouble starting it what so ever.
so the choice is up to you.
Dirby.
Dirby.
#349
i've had my rtr for about 2 weeks now and i have beat it senseless and only had to replace the rear shock shafts. i dont regret the purchace a bit. i took it to the track for the first time yesterday and for not having no track exp. i laid down some decent laps with it. not bad for a rookie racers
