Official Tamiya TT-01 Thread
#3476
ORIGINAL: DirtBonez
I have the duratrax charger as well but I kinda wish I had gotten something that could charge Lipo batterys also. Its a solid charger but a little cheap looking if you ask me. I think it would be a better investment to get something better that will serve you well for sevral years.
#3477
NL, CANADA
Thats true but what I was trying to say was that if you spend more money on a "good" charger that can charge all batteries then it would be a better investment because you will not have to go back and buy another Lipo charger later on. But your right the Duratrax is solid.
#3478
Hmm, my order from Tower has already arrived at my friends house... and I only ordered it on Tuesday!
3 day shipping. I think that's the fastest I've ever gotten something shipped to me. Tower = [sm=thumbs_up.gif][sm=thumbs_up.gif]
#3479
Well, after losing one e clip, breaking another e clip, losing a spring tensioner, spilling oil, and losing a ball joint (found it!), as well as stabbing my finger with a knife and getting blood everywhere, I finished building and installing the oil shocks!
I must say, that was the hardest build I've ever done. Sheesh.
#3480
ORIGINAL: Raguvian
#3481
RI
hi i got my Tt-01 the other day it seems prety fast stock and i can do doughnuts in my kitchen i was wondering if i could just get drift tires and keep everything ells stock for drifting.
oh i got a high peak charger and a 2400 Mah batery idk if that is good or not
please repond thank you
#3482
hello i am from indonesia and i have bought tt-01D and i want to ask what kind of part that worth it for me to upgrade my car? and what part should i buy until i can drift? sorry for my poor english.. please for the respone
#3483
ORIGINAL: rcluke
they get easier with experience, trust me
ORIGINAL: Raguvian
#3484
MD
Is there a metal Spur gear available for TT01? I installed a brushless VXL system and it tears up the spur gear? Any ideas welcome!
#3485
NL, CANADA
Make sure you have proper mesh, get an aluminum motor mount, Bring the power on and off smooth. Usually its bad mesh or a happy trigger finger that turns gears to tranny soup.
#3486
ORIGINAL: DirtBonez
tranny soup :P
#3487
#3488
Crap, I ran my TT-01 outside in the wet for a few minutes and I ran it through a puddle and the ESC is now shorting out.
Now I have to take off the balloon and take apart the ESC and dry it out.[:@]
#3489
Ok guys I finally made a decision and got an LRP Quantum Pro Reverse ESC. Its rated for 7turn limit at 120 amps and I can already tell the difference. I decided to stop using for the time being the Tamiya RZ motor since I can tell it won't hold up to a Trinity P2K2 or Pro Stock motor. I also decided to go direct solder to the motor and change out my axles and dogbones to cut down on rotational mass. I installed a front one-way and am about to install a ball diff in in the rear. Also a rotational mass issue less weight and mass for the motor to push.
#3490
RI
hey guys im kind of confused. ive noticed that when i go forward the car turns a little bit with out me doing anything. im confused because the adjustment nob on the controler is stright in the line.and i noticed that my wheels wobble when i go forward is this bad or what? please respond
#3491
ORIGINAL: zbot
Also you may have to adjust he steering trim on your TX, but if you have turnbuckles you can just adjust those.
#3492
RI
thanks psxbatou but im very new to the hobby i just got my car a week ago i dont reely know what you were talking about. but basically i should get all aluminum parts for like the steering?
#3493
ZBOT. Not meaning to be rude or anything but I think you should start reading up. I know its 137 pages but there is alot of information in this thread and the rctech.net thread and while I am not advocating that you not ask questions because we are all here to learn it would help you to read up on your car and the geometry of r/c racing. A good book to get in the XXXMAIN Setup book which I have. Knowledge is power. You don't have to use all aluminum parts for the steering. If your on a budget you can use shims or washers to fill in the space.
#3494
Got the ball diff and dogbones in will be taking it to the track as soon as the weather clears up. I snapped the ball diff adjusting screw in half trying to tighten to much lucky for me I had another screw just the right size laying around.
#3495
RI
thanks for the advice but the thread talks about stuf i dont know... so how did u get your knowlege about rc cars? you sed the some sort of book?
#3497
I got my knowledge from reading the forum. First I would start with the forum for Newbies and then go from there look up motors then your car type I know its alot of info to process but believe me once you start reading and learning you will be on here giving advice like I am to you. By all means ask your questions and we will try to help or at least I will but start reading as well.
http://www.xxxmain.com/bookz.shtml
#3498
ORIGINAL: dfiantii
#3499
You will know how to upgrade man its all in the manuals. Usually all the parts you order some with installation paperwork to show you how to install it. You will be fine once you got all the info. I was just where you were a few months ago. Now I am installing new axles, glueing tires instead of buying them pre glued. building oil filled shocks and setting camber on my wheels. As you learn the knowledge it will work and and don't or at least try not to get mad if you mess it up on the first try. Its a learning process, have fun with it.
#3500
RI
alright i red up on some newbie stuf about the engines i was wondering if i should get a lower turn engine to go faster.... i am stil interested in drifting and i was wondering if a low trun engine would still work for drifting, because i am thinking of just geting a set of drift tires and keeping my slicks so i can either go fast or drift. would that work?
