Lars good to hear from you again i like the 'strong like a bear' reference to the fa220 zues.I run one on nitro.
Jim the cam you need is in a saito 182 flat twin,you'll get that when you buy that engine,lots more performance without putting a spanner anywhere near the 130t.Maybe sr would give you some power to weight and physical comparisons.
ps electrical heat shrink tubing is good for sealing the ends of pushrod covers
SAI30S35; FA-30 through FA-40
SAI5035; FA-50 through FA-56
SAI6535A; FA-62 through FA-125
SAI120S35; FA-120S through FA-220
Not counting the various port side & rear cams for twins which have similar lobe profiles as the opposite cylinders albeit with differing LSA & rotational direction in the case of the inline twins, there are only 4 different Saito cam profiles for "single cam" (per cylinder) engines.
a suped up Saito should be in a sport racer or a war bird, JMO
I still would like to see a couple photos of that 100
Jim
I have been trying to trade Jim out of the 1.30-t for a 1.00-t, it might still happen.
Jim
Here is the only shot of it I currently have, since this I have removed the Velocity Stacks and reinstalled the choke. The V-stacks were not going to accomplish anything since the air has to almost immediately make a 90 degree turn.
Wasp
sometimes you build for stump pulling and not for speed. Now my 180 HC will be put in my GeeBee and we will see how fast i can get er to go. 180HC number 3 would look good in a war bird it could find a 120 size bearcat.
Depending on how it is propped, the high compression engine can develop high speed or high thrust numbers for impressive vertical performance. It would also be great for a high drag airframe like a Curtis Jenny or the like. The outstanding pulling power and fuel economy of transportation related diesel engines is in large part due to the extremely high compression ratios.
I have the 11:1 FG-57/FA-180 hybrid version in my Rascal 110 and I am considering swapping out the 18x8 for a 20x6 prop for slower landing approach speed and even better vertical.
Boosting compression is the most versatile performance boost as it increases torque across the power band. You don't have to give up low end torque for a high RPM HP boost.
I also use it on control rod dowels to cover thread with CA, etc. Looks clean and provides support. You can cover wire for landing gear assemblies with it. It is also good when you cut fully threaded push rods like 4-40 size. Put it on to cover all the threaded rod between each clevis. Looks neat, stays clean from oil, etc.
That would look sweet on a SIG 1/5th Cub.
Jim
Jim please don't use that pilot figure (he looks a bit light in the loafers) after you took all that care to bash the cockpit backwards,it looks neat.Here's a pic i suggest of what a pilot should look like when he's flying a mean sounding saito,on castor and nitro,or i can pm you a personal portrait.If it was me i'd stick with the dog.
Welcome and jump right in and tell us about your Saitos. I'll update my Saito list since it's been a while:
(2) little Saito FA .30's
(2) FA .40a's one early, one not yet run
(1) FA .50 age unknown F on the right lug
(1) FA .62 early no letter n the right lug
(1) FA .80 with 15.5 to 1 compression, late 80's
(1) FA 1.00 about 2 years old
(1) FA 1.25 about 1 year old with the newer cylinder
(1) FA 1.50 with 11.24 compression, the first 1.50 sold according to a lady at Horizon
(1) FG 11, a .66 by any other name.
(1) FA 1.00-T
(1) FA 1.00-T
Wasp looking good I always think i have an idea and then someone else does what i was planing. I am going to use the Astro Hog.
Saito inventory update for Captcrunch
2- 30
1-40 new case
1-40 old case
3-45
3-50 one of which is a golden knight
6-56 four of them are golden knights, on is a black with stainless screws
1-65
2-72
3-80
2-82
4-91
2-100
1-115
1-120 old school
1-125
3-150 one of witch is a golden knight
1-180
2-180HC those are cool
need to break down and get a twin someday.
2- 30
1-40 new case
1-40 old case
3-45
1-65
2-72
3-80
2-82
4-91
2-100
1-115
1-120 old school
1-125
1-180
Funny idea, here comes my Saito collection. There is 1 engine of each size
FA 40a
FA-50
FA-56
FA-62
FA-82 GK
FA-100
FA-100TI
FA-170
FA-220 with CDI
And the FA-80T lacks many parts
Can anyone say how to post pictures here.
It's done that does not work (or I understand)
Lars
FA 40a
FA-50
FA-56
FA-62
FA-82 GK
FA-100
FA-100TI
FA-170
FA-220 with CDI
Lars
Noise from the valves, they are certainly many of who know about this.
I felt at Saito 100 and noticed that they were a noise from the valves.
So I took out the valves out of the engine, which was hard to open
They only have to clean valves and valve holes from solid-burned oil.
Now the valves open smoothly and fine and the camshaft is less loaded.
and what's the noise, it's a hard click, click
Lars
Lars
