Guys it is hard to prime my 200ti. I pretty much have to squirt some fuel in the carb and it start right up and runs like a champ after that. Getting fuel to the carb the normal way does not work. Any suggestion?
Have you tried inverting the plane to prime it? I have a Gemini 120 that if I put the tank too high it dribble fuel when not running, and where the tank gets placed to not dribble, it is difficult to start, but runs fine once started. I inverted the plane to get fuel to the carb, then flipped it over to start.
My Feedback: (25)
I have a saito with a stripped gow plug hole in the cylinder head. Is there an easy fix like a helicoil? I hate to think of disassembling everything and trying to replace the head or is it the entire cylinder? Any help appreciated. Thanks.
With the low price of nitro engines today, I may just sell mine as a parts engine and buy another used one. Just sayin.
My Feedback: (149)
believe Clarence Lee is the most recommended fix for stripped plug threads.
Lee Custom Engines
10112 Woodward Ave
Sunland, Ca 91040
818-352-3766
you didn't say what size your Saito is?
Lee Custom Engines
10112 Woodward Ave
Sunland, Ca 91040
818-352-3766
sailr, which engine is it?
One option that is much better than Helicoils is called Timesert.
RC Glow plug thread repair 1/4-32 glow plug spark plug
I was thinking of getting the kit, but the installation gear is much more than the inserts, (you usually get 4 with the kit) and don't repair enough to justify. If you can find someone that has it already much less expensive.
what size is it? If it’s something i have I could trade you even up
Lower the position of the remote needle valve in relation to the fuel tank. That is why they supplied a remote needle valve due to the fact that the usual inverted mounting position places the carburetor below the C/L of the fuel tank.
TIME-SERT Inch Kit 1/4-32 GLOW PLUG KIT Part # 0142SP
The SP makes it different than the one you show in that it has a copper coating and is only .180" long, that has to mean the outside threads. The .180" would be scary short,for the inside threads.
Hobbsy, that was the one I linked to earlier. Only problem here is the total kit is over $100 with 4 inserts included.
I first used these in the auto trade back in the 90's, repairing the end results of the industry "100K miles before your first tune-up" binge. Not a huge problem with cast heads, but alloy really suffered.
Hello all, I'm new here.
I am doing a Saito 180 CDI on methanol conversion and got to the part were I was ready to flip the prop. That's when I discovered that putting the magnet directly into the prop hub was a mistake. Turns out that the hub slip no matter how ridiculously tight you make it.
I decided to tap a 5mm grub screw into the hub and ground a little flat spot in the crank shaft. I dont know though... Maybe I should have just got the damn adjustable magnet ring that clamps on. Have any of you guys managed to pin down the prop hub successfully. I have not tried my grub screw yet. I had to buy a longer screw because I felt the the short one that I had was not engaging enough threads.
NC
Stuck throttle barrel, how to get loose?
its on an older 48 I believe and tried everything from heating to soaking in oil and rust busters to carb cleaners. This is the first one that heat wouldn't take car of. There's an o ring where it attaches that appears will be damaged if I remove it like if I want to bake it in the oven. Is it a regular o ring that is easily replaced? Thanks for any suggestions.
Jim
Jim
hi Jim, my name is Jim
I just had the same problem (on what OF may call, a dirty 2St), I soaked the Carb in this for a week "fuel", didn't work, soaked it in that for a week "degreaser", didn't work, soaked it in this for a week "denatured alcohol", didn't work,,, heated it with a propane torch 3 different times, 1 long, 2 longer time, 3 longest time, didn't work, the barrel would not turn, not come out,, then I took a 3mm screw and screwed it into the barrel and grabbed it's head with pliers and pulled and the barrel popped out, it made a snap sound when it broke free,
so, once I cleaned the barrel and Carb and oiled it with ATF and reinstalled the barrel the barrel felt very gritty as it turned, I cleaned it more and still it felt gritty, well I cleaned it and cleaned inside and out and it still felt gritty,,, so I got annoyed (don't get annoyed), I figured it was my last resort and I lightly used, used-600 grit sand paper on the barrel and a bit in the Carb and guess what ? it's smoother but not great, I think the barrel is tight enough so it wont leak, but it really should have a better Carb,
sO, you can do all that I did, but most likely some one else know's better,
good luck
Jim
good luck
Jim
