Old 07-13-2018, 08:29 AM
  #37076
SrTelemaster150
SrTelemaster150's Avatar
Originally Posted by Jesse Open
Not actually
,I am referring to the longitudinal position of the cam along the shaft.
The Right hand cylinder's intake cam is the forward POSITION on its shaft.
The right hand exhaust is at the rear.
Conversely
The left cylinder Intake cam is at the REAR position while the exhaust valve is actuated by the FORWARD
cam.
So how then could it be that the "intake lobe on that side is now actuating the exhaust valve"? Your exact words.
Old 07-13-2018, 08:41 AM
  #37077
blw
blw's Avatar
I have a question for Jesse Open- why do you delete 75% of your posts? All those deleted posts sort of litters up the screen.
Old 07-13-2018, 09:03 AM
  #37078
Jesse Open
Jesse Open's Avatar
Not sure how you are making that twist??There are two cam assemblies, one for each cylinder. Obviously the cam assembly for the left cylinder has no affect on the right cylinder.
I had hoped to clarify that for you here:
Conversely
cam.
The lobe at the intake position on the right cylinder is next to the cam driven gear.
The lobe on the left cam assembly that is in that same position is actuating the exhaust valve on that side.
Any comments regarding Dave's timing marks?
Old 07-13-2018, 09:22 AM
  #37079
the Wasp
Originally Posted by FlyerInOKC
I'm sure Saito has a logical reason for their cam marking system it would have been nice if they shared it!
you would think they would just use a R for Right and L for Left, but that would not be the Japanese way
Jim
Old 07-13-2018, 09:43 AM
  #37080
Jesse Open
Jesse Open's Avatar
Jim
Moto Guzzi (motorcycles) uses "S" and "D" to mark the Left and Right handed carbs on their V twins. "S"inistra for Left and "D"estra for for right.
I guess too may of us couldn't read the Japanese characters for right and left.
Took me a while to just figure out "D" and "S" !
Seems the instructions and the timing pins should get the job done with the FA-90T etc.
At least I hope so
Old 07-13-2018, 10:22 AM
  #37081
the Wasp
so with this Cam Lobe swap talk about the twins, no one has pointed out that "the Valves must be swapped too" .
as for a new comment I have to say that I am surprised that Saito has not updated the performance of the FA 100 in some 14 years, most companies would have (like OS has with their Surpasss),, even if Saito only increased the Rocker Arm Ratio just a little it would work..
but with that said, if you could go back 14 years and you happen to own a Saito FA 100 you most clearly would have had the most powerful 4St engine in the 91 size, OS must have been a bit upset about the FA100 when it was released, and now after all these years OS has their 95 that is made in China (Jim scratches head). and you know for 100% sure that Saito will never be made in China..
any hoo, if some one would sell me another "never started" Saito FA 100 (or maybe a 115) for what I paid for mine (or less LOL), I would surly snag it
Jim
Old 07-13-2018, 11:10 AM
  #37082
SrTelemaster150
There is no difference between intake & exhaust valves on an Saito I know of.
Jim
FA-100 is NOT 91 size. At least not FA-91 size which corresponds to the same footprint as a .60 2-stoke..
Old 07-13-2018, 11:12 AM
  #37083
Jesse Open
Jesse Open's Avatar
I do have a FA-100 to spare, PM me. We can make a deal. You will like ir
The mirrored valve positions are the reason for the mirrored cam lobe positions.
Old 07-13-2018, 11:16 AM
  #37084
SrTelemaster150
That could be due to the intake lobe on that side is now actuating the exhaust cam.
How is quoting your exact words a "twist"?
[img]https://i.imgur.com/rFKXWji.jpg?
Last edited by blw; 07-14-2018 at 02:52 PM. Reason: Arguing with political content
Old 07-13-2018, 11:20 AM
  #37085
BarracudaHockey
BarracudaHockey's Avatar
Easy boys
Old 07-13-2018, 11:26 AM
  #37086
SrTelemaster150
Any comments regarding Dave's timing marks?[/b]
Compared to the starboard/single cylinder cam, the port side cam is rotating in the opposite direction in regards to the crankshaft rotation. Perhaps Saito did not want to cast a new cam gear/shaft so they just marked over the dot that is cast into the single cylinder cam gear/shaft.
The Saito cams are made up with lobes "keyed" onto the shaft. They are not cast as a unit. Given the asymmetrical lobe profiles it would be perfectly logical that the LSA/cam lobe timing might vary by 1 tooth when the rotation is in the opposite direction..
Old 07-13-2018, 11:47 AM
  #37087
the Wasp
they are on my FA 100
Jim
Old 07-13-2018, 11:57 AM
  #37088
Jesse Open
Jesse Open's Avatar
Not a size difference.
The I/E ports on the left and right cylinders on the FA-90T are swapped.
Old 07-13-2018, 12:24 PM
  #37089
Jesse Open
Jesse Open's Avatar
Are you saying; The left and right cams are turning in directions opposite from one-another?
How so? As the crank turns CW , both cams will be turning CCW right, left, top or bottom.
The cylinder's ports are reversed 180 deg, the cams are both turning in the same direction at any given time.
Regarding the markings:
I made a few comments very similar to yours early this morning. Of course, the wording was a bit different but the same tone regarding the reasons.
Old 07-13-2018, 03:33 PM
  #37090
SrTelemaster150
My bad, I didn't word that correctly. The cam lobes encounter the Intake/exhaust lifters in reverse order, or reversed 180 degrees as you said.
The rear cam in the FA-200Ti however (SAI200Ti35) does rotate in the opposite direction when viewed from the cam gear end, but then the crank rotates CW when viewed from the same direction..(the rear) That keeps the relationship the same albeit in the opposite direction. In fact, the SAI200Ti can be employed for CW crank rotation in a single cylinder Saito..Likewise the SAI100Ti can could be employed for the same result in single cylinder engines that use the SAI50 series cam.
Old 07-13-2018, 04:09 PM
  #37091
Jesse Open
Jesse Open's Avatar
My bad, I didn't word that correctly. The cam lobes encounter the Intake/exhaust lifters in reverse order, or reversed 180 degrees as you said..
Exactly!
I thought you may appreciate the opportunity to clarify/correct.
Old 07-13-2018, 04:19 PM
  #37092
the Wasp
as for the 100 Single I was surprised to find that intake is larger, you can see in my Sceptre link below that the Single's intake is .468" while the exhaust is .428", but to me it still looked to be a Hemi
(read to the left of the Prop/RPM numbers)
Saito FA-100
as for the 100T, I have to admit I have been wishing the .56 Jugs would work on it LOL, a 112 would be pretty cool
Jim
Old 07-13-2018, 04:33 PM
  #37093
the Wasp
you have to speed up the first video to 3:56
Old 07-13-2018, 04:59 PM
  #37094
captinjohn
Default cam gear video
This is some very neat postings you guys have shared. Thanks, John
Old 07-13-2018, 05:32 PM
  #37095
Jesse Open
Jesse Open's Avatar
Saito FA-100
Jim
Ah I see what you were talking about now. We were talking about two different things it seems. The SA-100 single does have an intake valve 1mm larger than the exhaust.
This could make the 100 cylinder more difficult to adapt for odd-fire twin uses.
An interesting bit of trivia regarding the word "Hemi":
While Chrysler Corp , now FCA did not invent the hemispherical combustion chamber, they did the next-best thing; First, they helped makeit very famous and well known.
Then, Chrysler trademarked the Hemi® name that is just as well known and a lot easier to say.
So, while just about anyone can make a hemispherical combustion chamber, only Chrysler (FCA) may legally call it a Hemi®. Of course, Chrysler can make a flathead and call it a Hemi® if they dared, it is their name.
I really like that company but for some reason, I have never owned a Chrysler built car. The founder, Walter P. Chrysler was a great man. Chrysler had always been an innovative company.
Sorry for the diversion, just thought some may get a kick out of the "Hemi" moniker story.
Old 07-14-2018, 01:05 AM
  #37096
Rudolph Hart
Rudolph Hart's Avatar
Yes but,they make for interesting reading while they survive,same goes for the pics gary posts except for that bsa rocket three,just kidding.There's been so much talk about which way saito cams are spinning my head is doing the same,good to see they both came to a consensus of sorts.
Gary was it peugeot who developed the first five valve head in 1905?.I have no interest in modifying saito's but i do carefully select the size saito engine i need for that airframe to be well powered and then a bit.So far i've never needed any tailweight with the fa engines.
Sr did you finish your 7x57 yet? i used one quite a bit years ago and properly loaded they are hard to beat re bang for buck.
Old 07-14-2018, 02:21 AM
  #37097
Hobbsy
Hobbsy's Avatar
If I may, this old guy has an intake valve of .555" diameter. I don't what the Saito 1.25 intake valve diameter is.
Old 07-14-2018, 03:01 AM
  #37098
SrTelemaster150
Exactly!
Unlike some people I am not so insecure that I can't admit a mistake.
Old 07-14-2018, 03:17 AM
  #37099
Jesse Open
Jesse Open's Avatar
Same here Always willing to admit an error.
When someone doesn't understand a statement, I offer an explanation to clarify. Ambiguity is not the same thing as a blatant unfactual.
Rudoplh ,
Thanks, Do you think it would be okay if a motorcycle is in the background when I take Saito photos?
Peugot has been quite an innovator over the years.
If not for the Jeep brand, Chrysler would have been gone years ago. The Jeep story is interesting too.
The Jeep was created by the old Bantam Motor Co .
They built the first concept in only 6 weeks. It was for a government contract leading in to WWII.
An instant success, The military loved it.
Problem was, they didn't get to produce it
Instead, Ford and Willys took up production and Bantam slipped away.
Old 07-14-2018, 04:09 AM
  #37100
Hobbsy
Hobbsy's Avatar
I have two LT 25's, one with a Saito .30 the other with an OS LA .25. The blue and white was a gift from cousin when he moved to Fla. I decided that one should be a tricycle plane. I moved the main gear back and you see the result.
This is a 1964 Jeep with a 52 hp F head engine, the engine sat just inside the right front wheel so the drive shaft was at an angle. We can't have motorcycles in the background of our Saito pictures, Pete said.
PS, when the brick house in the background was built, Native Americans still traveled to the Ohio River on the hilltop about 1,000 feet behind where this picture was taken.
