Nitro models pusher Bobcat?
#3701
RE: Nitro models pusher Bobcat?
Well I finished my Falcon/Bobcat 25 Wednesday. Didn't get a chance to maiden today. But here are some pics of my color changed Falcon/Bobcat 25 Jet.
Specs:
OS AX .35 Engine w/9x6p prop
Rudder - Hitec 65s
Aileron - Hitec 81s
Elevator - Hitec 81
Throttle - Hitec 325
Nose Wheel - Hitec 325
Specs:
Rudder - Hitec 65s
Aileron - Hitec 81s
Elevator - Hitec 81
#3704
My Feedback: (13)
NJ
It looks a little extreme, but I don't think it would cause a problem so much as not having enough of positive AOA. I use an incidence metter on the wing and make sure I have at least 1-2 degrees positive. That is usually all you need, but I really can't see how having more than that is going to hurt you.
ORIGINAL: HeliTB
Hey Tumbler, do you think my AOA is too high in the front? I got the front about a 1" higher than the rear.
#3705
ORIGINAL: HeliTB
Bill
#3706
My Feedback: (13)
NJ
Very true. I fly off grass and generally they bounce off rather than fly off the runway alot of times before they are ready to fly. I just make sure to keep the nose leavel and let the plane build up speed before making a turn or climbing. it's when you get the nose up that you get yourself in trouble. [X(]
ORIGINAL: BillS
The downside is that the airplane might take off at a speed that is below stall speed, which might not be good. But you alreay know that.
Bill
ORIGINAL: HeliTB
Bill
#3707
Thanks Tumbler and BillS. I will reduce the AOA to about 1/2" difference from front to back. I had another fellow pilot question the AOA stating the same thing BillS stated about lifted off below stall speed.
#3708
Besides the stall speed, if the landing isn't perfect, it will bounce and bounce and bounce......well you know how it is.
#3710
XairFlyer...Are you saying you kept the same AOA and changed the main wheels to reduce the bounce. I'm using Hanger 9 2" wheels all the way around instead of the foam. I fly off grass and I think the grass would tear the foam up.
I did lower the AOA to where the difference from the front to the back is 1/4" which is about 2 degrees. It actually looks better as well.
#3711
I have 3" foam wheel on front and 2 1/2" wheels on the mains, It now has a obvious positive AoA look when sitting on the gound, I found before it was nearlly negative which made it hard to fly off the runway.
I tend to takeoff on our narrow tarmac strip and land on the grass.
My Turbine Bobcat is setup to be practical and reliable, I have changed the undercarriage legs for 5mm wire and also beefed up the mounts inside the wing for the mains as they were just glued to the side of one rib.
I like the foam wheels as they are very lite and cheap
#3712
XairFlyer....I guess I should have mentioned that my initial AOA was 1" positive, which was about 7-10 degrees. So my AOA is still positive but not as much.
#3713
Maiden was aborted due to a faulty main gear. As I was taxiing out the right main gear broke at the bend. What a bummer. Actually its better it happened before take off rather than landing. I will have to order some 1/8 wire and bend it.
#3714
hi,
does the kit come with the retracts?do nitro planes sell the retracs for it or what alternative works? will my Magnum 52XLS (ringed) with a 11x7 APC prop will fly this thang?
Got the green light from the wife!!!
I almost want to get the 120,but i got a 60" A-10 on the building board!!!
Fernando....
Fernando....
#3715
ORIGINAL: mr.scale
hi,
hi,
ORIGINAL: mr.scale
ORIGINAL: mr.scale
ORIGINAL: mr.scale
I fly mine with 2 stroke GMS .76 engines using a Graupner 11x8 pusher prop.
This gives the plane lots of power and speed.
#3717
My Feedback: (540)
ORIGINAL: mr.scale
hi,
Fernando....
hi,
Fernando....
Spring air retracts for the greatplanes patroit 40 kit may/might fit. #305
http://www.retracts.com/GearKit_Sets.htm
I had one fixed gear flew it with OS.50SX and Jett .50 (not broken in yet), flew ok
but a .75 would give it some go! several guys used tower .75 cheap but runs well.
stock landing gear blocks in mine were poorly installed broke on 2nd flight.
#3719
Bill
Most Bob Cats will weigh 7 pounds or more.
#3724
will this set work? does incluide all three assemblys?http://www3.towerhobbies.com/cgi-bin...?&I=LXL406&P=0
or this will work?http://www3.towerhobbies.com/cgi-bin...?&I=LXMJK2&P=0
any comments? other than going 200bucks for air retracts? I'm thinking on taking all the covering off and do a military with armament!!Lol ( i have all the bombs and missiles ready for it!!!!!!!)
