CARF Rebel MAX - Build Thread
Old 05-07-2024, 10:28 AM
  #351
BarracudaHockey
BarracudaHockey's Avatar
Sorry, what's not legal in the US?
Old 05-07-2024, 10:30 AM
  #352
bluelevel
My Feedback: (39)
bluelevel's Avatar
The flares are not allowed. AMA rules state "Devices that propel hazardous projectiles are prohibited. Dropping any object creating a hazard to persons or property are prohibited."
Old 05-07-2024, 10:59 AM
  #353
BarracudaHockey
Oh ok, I didn't see it but I didn't sit and watch the whole video.
Yea, that's a no-no. Not illegal as such, just not covered under insurance.
bluelevel (05-07-2024)
Old 05-07-2024, 07:36 PM
  #354
rcmigpilot
My Feedback: (26)
I was looking at how close the tree line is.
Old 05-07-2024, 09:39 PM
  #355
Kenrico
Kenrico's Avatar
Originally Posted by Schiefsko
I never had a smoke system in my jets. But yesterday I made a "smoke maiden" :-)
smoke maiden
with my Rebel Max:
nice setup!! I have to try a smoke system one day.
Schiefsko (05-08-2024)
Old 05-22-2024, 02:52 PM
  #356
DUCMOZ
Hi All, for all you that might be using Powerbox with I gyro (i am using Mercury SR2 with I gyro), can you please advise that what is your gain set at? Thank you.
Behzad
Old 05-22-2024, 08:50 PM
  #357
Dave Wilshere
Do you mean iSat gyro?
Old 05-23-2024, 03:03 AM
  #358
BarracudaHockey
Behzad
It's set at whatever works for your installation. Start small, work your way up.
Old 05-23-2024, 04:04 AM
  #359
bluelevel
My Feedback: (39)
bluelevel's Avatar
Behzad
As others said, the main gain setting must be seen in context. If you have a GPS installed as well, you can usually use about 10% higher gains than without. Also if you select the "soft" dampening setting (instead of the default "normal" or "hard") your gains can also be higher.
I have reduced the individual gain for the elevator by 10% (set to 90) and my master gain is set to 40% (with gps and default speed compensation setting). In landing configuration or full flap fly-bys I have dialed the master gain up to 50%. I use the "soft" dampening. Hope that helps
Old 05-23-2024, 04:10 AM
  #360
smcharg
smcharg's Avatar
Behzad
Agree with @BarracudaHockey. However, it's safe to start at 20% on A or B. It'll be important to make sure your Rudder gyro is NOT active in Attitude mode (whichever one you set to be that meaning A or B). It's best to put the input on a rotary dial so that you can adjust in flight and sneak up on what you want...what feels good. The plane really doesn't need a gyro but it is fun to play with. You'll probably wind up with 25-35% at the end but it will be based on what you want. Remember that EXPO will change with gyro on/off so you may want to set your gyro then set EXPO. Once you find the amount of gyro you like, grab those numbers and transfer it to a 3-position switch (assuming you set A and B) so that you have A, B, and, most importantly, off for the gyro.
Enjoy!
Scott
CobraJet (05-23-2024)
Old 05-23-2024, 10:40 AM
  #361
DUCMOZ
Hi Dave
Yes you are correct. The reason for my question is that one friend is using Cortex and has about 30% gain. another friend just did the maiden and with ISat, he was getting wing rock at 8% and had to reduce to 6%. so i was wondering that if this is correct or it is a set-up issue.
Thank you.
Old 05-23-2024, 10:42 AM
  #362
bluelevel
My Feedback: (39)
bluelevel's Avatar
Hi Dave
Thank you.
sorry, something must be awfully wrong there
Old 05-23-2024, 10:43 AM
  #363
BarracudaHockey
Yea that doesn't sound right, I have an isat in just about everything and the only thing I couldn't get much past 10 percent gain on was a 60inch extra NG from Extreme Flight with HUGE elevators.
Old 05-23-2024, 10:51 AM
  #364
DUCMOZ
that is what i thought. I will set mine up as usual and go forward.
Thanks all.
Old 05-23-2024, 10:57 AM
  #365
smcharg
smcharg's Avatar
Definitely something not correct.
Old 05-23-2024, 10:59 AM
  #366
BarracudaHockey
FWIW my Rebel (i dont have, can't afford, and don't have room to transport or store a Max LOL) with an isat I run 25 in flight and bump that to 35 with full flaps. Attitude assist mode on aileron.
Old 05-23-2024, 12:15 PM
  #367
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Can't help with afford, but these things can be stored in a medium space and transported in a medium vehicle.... The pic with another brand plane shows the back halves of the fuse from the ceiling.
Old 05-23-2024, 12:19 PM
  #368
smcharg
smcharg's Avatar
Sheldon! You got a BDX??? My next jet for sure!
Old 05-23-2024, 12:22 PM
  #369
AEROSHELDON
My Feedback: (99)
Kinda hidden but it is a BDXs (2 meter). Here is my "Wayne's World" quality unboxing!!
smcharg (05-23-2024)
Old 07-06-2024, 02:57 PM
  #370
737Driver
737Driver's Avatar
Hey all MAX builders,
Just added lights to the wing, here are some photos with measurements and the light that I used. Pretty easy to cut into wing, nothing blocking the cut part and running the wiring down the wing
Tom
The lights I used for NAV/Strobe
how long I made the slit to slide in the heat sync, have to round off the aft end to make room for the resistor to push into wing
how far away from the trailing edge to beginning of the cut/slit
The following 4 users liked this post by 737Driver:
camss69 (07-11-2024), CobraJet (07-06-2024), GeorgiaFlyer (07-06-2024), Ken Bryant (07-07-2024)
Old Today, 08:21 AM
  #371
AEROSHELDON
My Feedback: (99)
Over 9,000' density altitude and the max did great. Check out Jeff's video page for more cool stuff--our club has a lot of diversity in jets.
