Skymaster 1:6 A10 Build
Old 08-08-2011, 10:40 AM
  #351
Gonzalo38
Gonzalo38's Avatar
Default RE: Skymaster 1:6 A10 Build
By the way.... our builder is the same, so he nows has experience with Michele's A-10
Old 08-08-2011, 12:24 PM
  #352
gonzalom
gonzalom's Avatar
Hey Michael,
I refused to put Bush as a pilot on my A10.... you see I am a Chilean who lives in California as a Democrat! I have to visit you guys one of these days!
Michael I should have a conference call with you and Gonzalo to hear more about your first flights with the A10!
I am planning to order the pilot from http://www.maffscav.de/ as Matthias have done most of my pilots in the past with customize uniforms!
I can't wait to hear more about your A10s back to work on mine!
Gonzalo
Old 08-08-2011, 12:37 PM
  #353
JetsRC
JetsRC's Avatar
Gonzalo, you are welcome anytime here... we will have some pisco sour ready for you...
I see what you mean about the bush pilot, but it is so well made...
Old 08-08-2011, 01:42 PM
  #354
Gonzalo38
Gonzalo38's Avatar
Pisco Sour ? I'm in........
Old 08-09-2011, 04:35 PM
  #355
Gonzalo38
Gonzalo38's Avatar
ORIGINAL: Likai
y
Here is the gsolution to lock the main gear on up- position and prevent the main gear pull out by high +G load. It is very simple, a small air cylinder and ply wood mounting bracket, that's all. There is a spring in the cylinder to pull the cylinder rod return for unlocking and an air tube connect to the cylinder supplies air pressure for up-locking. So this is a failsafe design, if air pressure is out, the main gear will unlocking and down automatically.
The air line of this up-locking cylinder is connected to the air line of close-side of nose gear door cylinder, so no extra control valve and sequence setting are needed. This is meaning when nose gear door is closed, the main gear up-locking is actived in the same time.
My A-10 arrived with the up-locking cylinders but they are not spring type. Actually, they are like a normal cylinder with two outlets instead of one. This means that I have to connect them to the open and close side of the nose gear door cylinder ?
Old 08-09-2011, 04:49 PM
  #356
Gonzalo38
Gonzalo38's Avatar
This was the first day of work on my A-10.
All extensions are done and UAT's, fuel solenoids/pumps and air valve are installed. I wouldn't be surprised that tomorrow all the servos are installed since before I left, there were already three of them ready.
ID:	1646721   Click image for larger version
ID:	1646722   Click image for larger version
Old 08-09-2011, 05:12 PM
  #357
JackD
JackD's Avatar
ORIGINAL: JetsRC
Now... Gonzalo is a Peruvian Chilean. I want to see how he reacts to the Pisco debate!!!!! is it peruvian or chilean??? haha
Old 08-09-2011, 05:19 PM
  #358
Gonzalo38
Gonzalo38's Avatar
Jack....... it doesn't matter if Pisco is Peruvian or Chilean. The only important thing is to drink it Cheers.
Old 08-09-2011, 05:41 PM
  #359
gonzalom
gonzalom's Avatar
The debate about the Pisco it's quite simple! Pisco=Peru! is just simple math!
Gonzalo38, my lock systems has the 2 outlets too as you described and the spring which it is inside. You should connect the lock as you do with your doors air system. When I simulate a loss of pressure then you see the spring active, quite nice and secure.
I am dying to see how your A10’s goes with the Cheetahs? Are you guys planning to modify the exhausts.... as they are made more for a P80? It might be OK but check if the diam of the exhaust are OK.
So far I am very incline to get 2 new JetCat P-140rx for mine perhaps Cheetahs or Merlins 140 are a nice option too.
Gonzalo
Old 08-13-2011, 04:25 AM
  #360
snobird
My Feedback: (36)
snobird's Avatar
Gonzalom, my A-10 with the Cheetahs is all ready to go, heading to the New England Jet Rally next weekend.. using the exhaust pipes as supplied by SM. will post some pictures later.
Old 08-13-2011, 06:13 PM
  #361
ECalderon
ECalderon's Avatar
Hi
Here are some picture of Michels Durand's A-10 that was maidened this weekend. It has two JC Cheetahs and it flys awsome. Probably will be posting video soon.
Regards
Eduardo
ID:	1648458   Click image for larger version
ID:	1648459   Click image for larger version
ID:	1648460   Click image for larger version
ID:	1648461   Click image for larger version
ID:	1648462   Click image for larger version
Old 08-13-2011, 06:20 PM
  #362
JetsRC
JetsRC's Avatar
Hi guys, ok this Friday I did the maiden of my A-10, did a couple of flights and today a few more. Wow this jet is amazing, very impressive in the air and it fly's very well.
I installed 2 cheetah's for power, this is more than enough, regular flight needed only half power and I only went full power on big verticals.
CG I went with 145mm, at this point it flew very stable and it was a no issue on stalls on specially on landing, it was rock solid.
IN general a great jet, I just love it and I am sure I will have some great fun with this one.
Here is a video, it is a preliminary and the aspect is all wrong but it gives the idea on todays flight, later I will post a better one.
On thing to keep in mind. The elevators need to be slightly up to level flight and the recomended travel on the ailerons y too much and the A-10 is too sensitive on this value, just put a little less.
Video: http://www.youtube.com/watch?v=FiiwMmEcsWI
Michel
ID:	1648473   Click image for larger version
ID:	1648474   Click image for larger version
Old 08-13-2011, 06:22 PM
  #363
JetsRC
JetsRC's Avatar
Nice pics Eduardo, thanks...
Old 08-13-2011, 06:55 PM
  #364
gonzalom
gonzalom's Avatar
Hi Michael,
Outstanding! a big CONGRATULATIONS to you! I spoke early Friday with my tocayo Gonzalo and he told that you guys where ready to maiden on that day.
When you have the time please share with us your setting regarding ATV's expos etc including how much up or down elevator for the flaps on landing.
Love the video! and what a superb landing you did! Did you used the provided exhausts on the A10 for the Cheetahs? Using most of the flight 1/2 power I wonder for how long thoese tanks will go.
Thank you so much for sharing with us!
Gonzalo
Northern California
P.S. That Bush pilot looks very good and did a great job landing! remarkable!!
Old 08-14-2011, 12:12 AM
  #365
MNModels
MNModels's Avatar
Michel,
Congratulations!
Morné
Old 08-14-2011, 01:41 AM
  #366
Ali
Ali's Avatar
Awesome flying Michel.
Old 08-14-2011, 03:21 PM
  #367
JetsRC
JetsRC's Avatar
Thanks guys, the jet is a lot of fun to fly.
Gonzalo, I used the standard pipe, no problems so far.
Regarding some settings:
CG 145, I heard that 150 was a bit tail heavy so I went a bit forward. The jet flew very nice like this and I intend to leave it here. It is very stable and confortable on landing.
On throws I went with SM recomendations, but too much for my taste on ailerons so I lowered that a bit.
For expos I used 35% more or less, this depends a lot on personal preference. Remember on Futaba radios this is -35%
For flaps I went as much as what the servo with a 2" arm will give me. I found that when aplying flaps te jet floats very nice with no strange things.
After a 6 minute flight I still have about 1/3 of fuel in the tanks. I will probably go for 7 minutes in the future... for now 6 minutes leaves me with enough fuel to have a few go arounds until I get used to the A-10.
With the 2 cheetahs power managment is important, the jet as a lot of extra power with this 2 turbines so if you go this way be sure not to go on full throttle all the time...
Next step is flying with all bombs on...
I just updated the video with some extra footage and the correct aspect ratio... check it out...
Michel
Old 08-15-2011, 08:31 AM
  #368
pilot tw
Hi, Mihel
Congratulation! for your maiden for A-10.,
Will you be there Jet power 2011?? before you told me , that you will be there,
Best regards
Anton
Old 08-15-2011, 08:35 AM
  #369
pilot tw
Hi, all
we now building the A-10 RTF at SM factory by Professional Builder, here are some pictures.,
Best regards
Anton
ID:	1649060   Click image for larger version
ID:	1649061   Click image for larger version
ID:	1649062   Click image for larger version
ID:	1649063   Click image for larger version
ID:	1649064   Click image for larger version
ID:	1649065   Click image for larger version
ID:	1649066   Click image for larger version
ID:	1649068   Click image for larger version
Old 08-15-2011, 08:45 AM
  #370
pilot tw
more pictures.....
ID:	1649070   Click image for larger version
ID:	1649071   Click image for larger version
ID:	1649072   Click image for larger version
ID:	1649073   Click image for larger version
ID:	1649074   Click image for larger version
ID:	1649075   Click image for larger version
ID:	1649076   Click image for larger version
ID:	1649078   Click image for larger version
Old 08-17-2011, 11:43 PM
  #371
thunderbolt90
Hello Every one,
Alex48, how many lead have you in the nose with the two merlin 140 ?, i'm very interresting by this A10 skymaster and probably with two jetcat P100 and without pylon and ordonance , do you think it possible to dry weight 22 kg in this setting ?
Congratulation for your work, it's perfect .
Eric .
Old 08-18-2011, 11:07 AM
  #372
schroedm
schroedm's Avatar
Eric,
I think Al had 0.5lbs of lead in the nose.
Also, I would say you could make 22kg with ought the pylons and ordnance (they are surprisingly heavy)
Rgds,
Mark
Old 08-18-2011, 11:10 AM
  #373
schroedm
schroedm's Avatar
Michel,
Did you run the tailpipes supplied in the kit? Did you test for the power off climbing scenario?? Just wondered if you had changing pitch trims and were seeing the same issues?
I'm 95% sure I'm about to attack mine and get it going. I just don't want to go through the effort and find it has odd flying tendencies (especially when the Mibo is supposed to be an amazing flyer).
I would be interested to hear just what the difference is between the SM and A-10 flying wise. They're so similar in size and weight that I would hope they're almost the same?????
Cheers,
Mark
Old 08-18-2011, 01:57 PM
  #374
wxman2
My Feedback: (52)
wxman2's Avatar
I am starting to put a build list together for a Skymaster A10; is there any reason why not to go with this Slymaster product?
John
Old 08-18-2011, 11:49 PM
  #375
thunderbolt90
Ok Mark,
It's great .
Are you a opinion about the difference between the Skymaster and the flyeaglejet 1/6.25, quality , fly , landing gear ect ..
When i sure, i make my order in early september .
Regards .
Eric
