Skygate/CARF Viperjet
Old 04-06-2014, 05:23 AM
  #351
sailing1
My Feedback: (134)
Peter, that is a lot of smoke. Bet it will really look good in the air. And you are totally correct about he cockpit -- way cheap. I just went the complete sport jet route and smoked the inside of the canopy.
How complicated is the install of your lights to the wing and what type electronics are required.
Old 04-08-2014, 03:36 AM
  #352
Peter A
My Feedback: (34)
Peter A's Avatar
For the lights I made my own but you can buy a ready made kit from Emcotec (link below):
http://shop.rc-electronic.com/LIGHTI...catalog&p=2079
For mine I bought the Lexon lights from Emcotec, got a 10A Turnigy Receiver Controlled Switch from Hobby King for $6, and I used 2 x 5ohm, 20w resistors from my local electronic supplier.
Each wing gets a resistor, also I used a balsa /ply mount and used an Aluminium plate under the resistor with heat compound.
I am drawing 650mA per wing which is nothing really, using a 2 cell LiPo 3000mAh which lets me fly with lights on all day.
As far as the lights. I cut the skin of the wing and silicone them in place. Silicone absorbs any shock or vibration and it is super easy to remove the lights and replace them and re-silicone in place for any repairs. So far I have used this setup on different models with no issues.
If you want a nav lights etc, this method does not work of course, you need some form of light sequencer but for On/Off landing lights, this is perfect and cheap with very low maintenance and lasts forever.
ID:	1985234   Click image for larger version
ID:	1985235   Click image for larger version
ID:	1985236   Click image for larger version
ID:	1985237   Click image for larger version
ID:	1985238   Click image for larger version
Old 04-11-2014, 02:00 PM
  #353
Peter A
My Feedback: (34)
Peter A's Avatar
Finally a break in the weather. Could not resist. Test flew the Viper today (charged everything but forgot to charge the camera)
Ah well, anyway it flew like it was on rails. I needed 0 trims.
An awesome plane, tracks well, rolls great and flies like it is on rails and I do not use Gyros anymore in my models.
Will take pictures and or videos soon and post.
Old 04-11-2014, 02:15 PM
  #354
sailing1
My Feedback: (134)
Great news Peter. I love mine. I do use a steering Gyro but it is more because of the small narrow field I fly of than anything.
Also, thanks for the reply one the lights. Yours look great.
Old 05-01-2014, 12:59 AM
  #355
skywarrior
skywarrior's Avatar
Hi Peter.
Like the lights and would be happy to glean info on how they were made.
Regards
David
Whoops missed the post above sorry
David
Old 05-01-2014, 01:05 AM
  #356
skywarrior
skywarrior's Avatar
Hi Granville,
What sort of flight time are you getting from your 180 RX please and stock tank.
Regards
David
Old 05-01-2014, 01:16 AM
  #357
skywarrior
skywarrior's Avatar
Hi Achilles,
How did you operate your gear door ? Is it manually ( ie a wire trip or pneumatic ram) ?
David
Old 07-17-2014, 02:53 AM
  #358
Dave Wilshere
One of several Vipers we sold recently, this one was put together for the customer in under 10 days. JR DMSS with a P-180Rx JetCat (started and ran perfectly first time) Should test fly in at our next JMA meeting in the UK.
ID:	2014872   Click image for larger version
ID:	2014873   Click image for larger version
ID:	2014874   Click image for larger version
ID:	2014875   Click image for larger version
ID:	2014876   Click image for larger version
Old 07-21-2014, 07:49 AM
  #359
Dave Wilshere
People in Europe, there is a CARF deal on the Green scheme Viper!
Dw
Old 03-10-2015, 11:11 AM
  #360
havard.j
Hi.
I have installed a Merlin M200XBL in my Viper.
It has 25N more thrust than the recommended JetCat P180.
Is there anyone else here who has mounted 200N turbine?
Do you think the exhaust pipe and the model is strong enough?
Old 03-10-2015, 11:54 AM
  #361
Dave Wilshere
No problem with the bullet proof tail pipe tube.
Dave
Old 03-10-2015, 01:19 PM
  #362
havard.j
Thank you.
Obviously I have to use common sense in G maneuvers, but full power level and vertically will be fun
Some pictures, soon ready for maiden.
Name:	2014-10-17 14.57.14.jpg
ID:	2080449   Click image for larger version
Name:	2014-10-17 14.57.32.jpg
ID:	2080450   Click image for larger version
Name:	2015-01-10 19.37.58.jpg
ID:	2080451   Click image for larger version
Name:	2015-01-17 18.14.39.jpg
ID:	2080452   Click image for larger version
Name:	2015-01-20 16.22.00.jpg
ID:	2080453   Click image for larger version
Name:	2015-01-27 21.10.33.jpg
ID:	2080454   Click image for larger version
Name:	2015-01-27 21.11.06.jpg
ID:	2080455   Click image for larger version
Name:	2015-01-27 21.13.56.jpg
Name:	2015-01-27 21.14.18.jpg
ID:	2080457   Click image for larger version
Name:	2015-01-27 21.15.43.jpg
ID:	2080459   Click image for larger version
Name:	2015-03-03 21.46.53.jpg
ID:	2080460   Click image for larger version
Name:	2015-03-10 13.28.27.jpg
Old 03-11-2015, 02:05 AM
  #363
skywarrior
skywarrior's Avatar
Wow thats a rocket ship then as mine goes straight up on a 180 Rx no problem !
Old 04-23-2015, 03:02 PM
  #364
quist
My Feedback: (198)
quist's Avatar
anyone in the US have an interior kit that they want to get rid of? I need the front dash cover.
Old 05-18-2015, 04:16 PM
  #365
airspeed917
Default Black Eagle Viper
Just got my CARF Black Eagle Viper, First Viper made in this Scheme. The paint job is flawless and the quality of this jet is incredible,
ID:	2097021   Click image for larger version
Old 06-09-2015, 04:39 AM
  #366
paulhat
Hi All.
Can anyone tell me how the viper flies with a 140 sized turbine.
I would build it light with no cockpit and minimal electronics.
At the moment I am flying off well compacted dirt with plenty of room for take off run.
Regards,
Paul.
Old 06-09-2015, 06:32 AM
  #367
quist
My Feedback: (198)
quist's Avatar
I am flying with a 160SX (36lb) It is not overpowered but it has enough to do anything aerobatic that I want. It has very good vertical for a slow jet. The jet isn't fast, top speed I have recorded in level flight is 180 MPH. I only use full power on vertical maneuvers. I would think that the140 will be ok but not great. It all comes down to your flying style.
Old 06-09-2015, 03:47 PM
  #368
paulhat
Thanks for the information Quist.
I guess if it has good vertical with a 160 then it should fly pretty good on a 140.
I have a 140 engine that needs a home.
Paul.
Old 06-09-2015, 05:36 PM
  #369
sailing1
My Feedback: (134)
Paul,
I have been flying mine for a couple of years on a 36 lb Rhino. My Viper weighs 36 lbs dry and the performance is good with it. Can't imagine needing more power. But Having said that, I also think you will be taxing a 140 size turbine pretty hard, especially on some of those days when your 30-32 lb thrust turbine is really putting out more like 27-28 lbs. Will it fly it -- you bet, but you won't have much reserve and you will be in the upper end of the power curve most of the flight. Just my opinion.
Old 06-09-2015, 06:29 PM
  #370
paulhat
Thanks Sailing1.
Sounds like this aircraft is better flown with a larger engine than that 140.
Thanks for your feedback.
Paul.
Old 06-10-2015, 12:42 AM
  #371
lxfly
lxfly's Avatar
Hi,
I'm flying the Tomahawk Viper with a Jetcat P140, 34.7lbs dry, normal cutted grass field is no problem, have flown it to at 25-30° C with no power problem. Here is a short Video.
In comparison with a friend's Carf powered by Jetcat P180, we couldn't see much difference in flying, except verticals.
Maybe worth trying it.
Old 06-10-2015, 07:59 AM
  #372
Achillesfilho
Achillesfilho's Avatar
I have a P180 in my Carf Viper and it's overpower since the airframe isn't designed for speed, so i decide to switch for the p140.
Old 06-10-2015, 02:20 PM
  #373
RC_MAN
Does anyone have a slick way of fastening the main wings to the fuselage. I find trying to tighten the bold through the retract hole is very hard.
Old 06-11-2015, 02:00 AM
  #374
Roger M
Have a look at post 284, where a 6mm bolt is fixed into the wing root and then a wing nut is simply attached inside the fuselage. I've used this system on my Viperjet and it really is simple and quick.
Roger
Old 06-12-2015, 01:37 PM
  #375
sailing1
My Feedback: (134)
Mine are set up just the way Zeeb did his in post 284. Thanks so much for the tip. Works perfect . I just used 1/4 inch studs and couple of nylon wing nuts because they were easy to get and plenty strong.
