Official Tamiya TT-01 Thread
#352
OH
Hey G-Ped, thanks for the assistance. I'll have to check with Tamiya on that 29T pinion. Since this whole pitch thing is a matter of life and death for your gears, you'd think that no manufacturer would ever list any specs on a pinion or spur gear without listing the pitch. However, that is not the case, much to my dislike. It's looking like they simply don't make gearing as hard as I want it, but we'll see.
#353
ORIGINAL: MacDuff
any recommendations on what motor and gear settings i should upgrade to from stock?
#354
ORIGINAL: bIGmiK
Yes, Tamiya Sports Tuned motor, and a 58t spur gear, and a 22t pinoin gear.
ORIGINAL: MacDuff
#355
WA
ORIGINAL: bIGmiK
Yes it will go away. Best way though would be a spektrum.
#356
Dude install it on the carbon brace.. THats where most people put their recievers with a TT-01.
Macduff I would just try the sports tuned first, it's very cheap and goes very well in these cars.
#357
ORIGINAL: stewtheman
#358
RŲeBreed, how do you like the adjustable upper arms? What did you set the camber at to begin with?
And also to GTWCS14, my brother is using the same ESC as you are, and I hard wired the motor to the ESC today, and he said it was much faster. I wasnt there to see it, but he said that you could tell the difference in speed. Maybe you should try that if your look for some more power.
#360
RŲeBreed hang on, I see what's causing your glitching to begin with. Your nice white receiver wire is crossing your carbon upper brace. Carbon is contuctive, and hence scrambles your signal. Good luck with the new receiver, please ensure the wire only touches plastic/non contuctive material!
#361
WA
ORIGINAL: G-Ped
#362
OH
Well, I called Tamiya today and was informed that the TT-01 uses metric 48p and not 32p. BIGmik, where did you see that the TT-01 was 32p? Does anyone know exactly what these pitch numbers mean? I was under the impression that 32p meant 32 teeth per inch but I don't even know what that means. Is it 32 teeth per inch of circumference or diameter or what? And now that the Tamiya representative told me the TT-01 is metric 48p, what does that mean?
#363
All I know is that when I buy pinions I use 32pitch for the propper mesh.
Tell Tamiya to shove their head where it fits and I'm right.
#364
WA
i did a test with the JR RS310 receiver...no glitching! and i checked my receiver wire...its not touching the carbon fiber upper brace at all.
#366
WA
ORIGINAL: bIGmiK
IS IT GOOD WITH THE BUSHLESS?
#370
So I was right...
Did you ask them about the 52t spur and the 29 pinion?
#371
ORIGINAL: G-Ped
If anyone is looking for a Sport Tuned Tamiya Motor(Black Can). Hit me up through a pm!I can also work something out if you need the ESC.
#375
about the motor i don't really know is ae reedy competition stock motor ... don't know the turns if any one knows please tell me and about the tires they were the only ones left at the hobby shop so i didn't have a choice....thanx for the comment G-ped
