The Official Tamiya TA05 Thread
#351
ORIGINAL: symbios24
hallo there im jim i want to ask if there is a guide for newbies like me for rc car servo setup that explains excacty how to do it in here or in another page? i mean how to setup servo from the begin to the end.
i have a ta-05 and try to setup servo but it always steer by it self always i must steer it to fix his course thank you
p.s. all the turnbackles are weel configured.
Good luck.
#352
dont forget to centralise the steering servo before putting the servo arm in place and fitting the steering coupling, this is easy to do, just switch on the transmitter then the reciever with the steering servo connected and let it centralise, then finish the build as per the instructions and then do what bullet69 has suggested.
#353
ORIGINAL: southturn
So would the mamba max 7700 be a good start.
#354
Just bought a TA05 IFS-R today. The manual seems to indicate that the Pinion Gear is available seperately? Is it true? The stock spur is 107T right? What's the current best Pinion/spur ratio for better aaceleration? I'm putting in 18T Team Orion motor, Futaba MC330CR ESC, Futaba R203HP digital servo and Futaba S9551 servo.
Thanks in advance for replies.
#357
ORIGINAL: mkoresh12
That would be a good start. But remember, just because you get a mamba ESC your not limited to Mamba motors. What type of speeds are you looking to hit?
ORIGINAL: southturn
#358
ORIGINAL: adrictan
Sorry. Are TA05 parts compatible with TA05 IFS-R models?
#359
ORIGINAL: southturn
As fast as I can get it to run.
ORIGINAL: mkoresh12
ORIGINAL: southturn
#360
No replies?
#361
ORIGINAL: adrictan
No replies?
No replies?
The 04 module or 64dp gearing is better than the standard tamiya gearing.
The surface you are racing on determines which gear ratio you need.
but remember, smaller pinion = more acceleration, larger pinion = more top end speed.
You will enjoy this chassis !!
any more questions, fee; free to ask.
#362
I went Taroda after work today. The guys there were pretty nice and spare parts quite comprehensive.
Anyone here has assembled his TA05 IFS-R? Wanted to assemble mine just now but after putting the motor mount to the chassis, the next step needs cement which I didn't buy. So I ended up doing the TRF damper shocks only. Sucks...
Somemore the 1st pg also indicates must cut 3 parts of the chassis to prevent the belt from hitting them. I don't have dremel. Can don't cut away?
Anyone can help?
Anyone can help?
#363
ORIGINAL: adrictan
Anyone can help?
Anyone can help?
why do you need cement for the build (you do realise that it is just super glue)
#365
My 2 problems. Basically is where exactly to cut and how much to cut. And also whether or not to apply the rubber cement to the Diff plate and diff joint or just sand paper as recommended in many forums.
![](http://i299.photobucket.com/albums/mm289/adrictan/IMG_0277.jpg)
![](http://i299.photobucket.com/albums/mm289/adrictan/IMG_0286.jpg)
![](http://i299.photobucket.com/albums/mm289/adrictan/IMG_0275.jpg)
![](http://i299.photobucket.com/albums/mm289/adrictan/IMG_0276.jpg)
#366
Odd that you need to cut to avoid belt rubbing. I haven't noticed any problems with mine and I didn't cut it. The diff doesn't appear to be the d-cut type thats on mine. Check your actual parts, see if the plate has a D or if its actually totally round. If its a D you won't need to glue. Seems odd that they would change something like that. Is it a one-way diff?
#367
hiya, been reading all 15 pages of this TA05 forum and i must sat i m impressed, now i need some answers
do you know where i can get spares for it, i want UK based, and links pls
any options parts, uk based and links pls
if i were going to buy this car for club racing(TA05-IFS, horz mount front suspension), what will be the first upgrade on this car only, i already have quality radio, servo, motors, speedos, etc so no worries abt electrics.
tamiya website is limited info compared to other website so like to know if drive cups, dogbone is metal, i hope they are not plastic
cheers
cheers
#368
ORIGINAL: mkoresh12
The parts are as per stated in the manual.
#369
ORIGINAL: adrictan
So should I sand both parts or just use super glue?
#370
ORIGINAL: jaws1
cheers
cheers
you can get loads of spare parts from www.rcmart.com (not UK based, it's in hong kong, but it is really cheap and reliable.
you can also get the hop-up parts from rcmart.com
I would get the Tamiya TRF shocks if I were you (or get the TA-05IFS R to start with, it has lots of hop-up parts already included.
I have the new Tamiya drive shafts on mine which are the metal ones, the Precision ones are also good.
good luck with it mate.
#371
ORIGINAL: jaws1
cheers
cheers
http://www.brockmodels.com/index.php...8862654ca1e325
#372
cheers rcluke
do you have to pay the custom and handling charge when you get parts from rcmart, if so roughly how much
where would you find this TA-05IFS R in UK
are you saying that the dogbone and cups are plastic in standard car, can you confirm it
#373
ORIGINAL: jaws1
cheers rcluke
cheers rcluke
i havent got a clue about finding one in the UK, you would be better off getting it from asia.
I can't tell you about the drive cups, because i don't have standard ones on mine, they were changed when i got it
#374
ORIGINAL: adrictan
#375
ORIGINAL: rcluke
nope, no customs charges from rcmart ![Smile](images/smilies/smile.gif)
ORIGINAL: jaws1
cheers rcluke
cheers rcluke
cheers
