talking about character, the P-26 has it, one of my favorites
Boeing P-26 | Aircraft in Focus
Attachment 2262362
Jim
put a Saito in it
Attachment 2262362
Jim
put a Saito in it
Seems like buying Lasers are more miss than hit for quite a while now. Hope they aren't going belly up!
Just put the final metal finish on the 9mm X 10mm 90 degree street elbow. Ready to mail out to git's new home.![](https://cimg2.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/fd040a85_ce82_4b8d_8bab_f75e7b4af1de_d8e9205654ffa05c5be6115c407c246086f2360b.jpeg)
![](https://cimg4.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/a5aeeb5b_0836_4ed8_b91d_10b6187740f4_6b9d748908ca721e3366ce4b48e334192b063d64.jpeg)
Raulph that is the best decoti pic i have ever seen. Cool
so i know i come and go here but work has been fruitful and i have been blessed.
So anyway I managed to get a Saito.65 off eBay a while back and it was missing the intake and carb so I found that i had a spar .80 intake and carb and with a little reaming i now have a Saito.65 that will turn a 13X6 at 11200RPM’s.
I think I might have a race engine for a good 50 size P51.
CR
I was wondering the same thing, but a prop that loads the engine more and brings down the RPM should help if he has a problem, I really would like to see more testing, but that's all about finding the time to do it
Gary, you did a great job on that elbow !!
Jim
Jim
well it idled nice and transitioned good
i will get out and run it again this weekend with a 14-6 and see how it pulls. I will try to put up some numbers but.
Hobbs it way better at that stuff then me so don’t expect that kund of a report
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/saito_65_carb_diameter_early_18c7dd6daa48ce6c2c10c623365333448d52a6d4.jpg)
Early 65 carb barrel ID==7.5 mm++
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/saito_65_carb_diameter_060c93b493b27e0bed31c6cfb0999cbac08c8d60.jpg)
Later 65 carb ID.===7 mm
![](https://cimg0.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/saito_80_carb_diameter_c83f8ffd934588592738e848d9d544a6a4cdcfa9.jpg)
Saito early 80 Carb barrel ID===7.75 mm??
I have two 65's and an 80, so I pulled the carbs and measured the venturi's, it appears that the early 65 and the 80 are the same with the later 65 being slightly smaller.
Fellow comes in to work today an says he has something for me. His divorcee neighbor cleaning out her garage wanted him to dispose of some hazardous material. So he has 12 cases of this for me:
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/1fd52f5a_1b86_41ec_b076_827aa1e21562_b6a9192f0a2bd46aa377cdab5599789f0c727c02.jpeg)
I'll just add somesynthec/castor blend andsome methanol to convert Otver to my personal favorite ![Wink](images/smilies/wink.gif)
And I just ordered a drum of methanol on Wednesday!
Geesh, what luck![Frown](images/smilies/frown.gif)
Geesh, what luck
I just ran the the Saito 82-a for 35 minutes, sure was coold on the fingers setting the LS needle, it could use a little more leaning (LS) as it accelerated some when I pulled the fuel line to shut it down.
Saito 82-a with new Boca Bearings and new lifters.
Fuel====Wildcat 10% with 18% full syn.
Prop ===Graupner 14 x 7 G-Sonic same one as run on the 82-b
Plug====Fox Miracle
Exhaust=Stock muffler
Max RPM=9,150 exactly the same as the 82-b, yep, amazed me too, although they should be the same.
Idle RPM==1,890 slightly faster than the 82-b
Ambien temp 52 f
Plug====Fox Miracle
Ambien temp 52 f
Hi all Saito lovers. I have an older 91 f I was given from one of our club members, but it needs a rebuild. I was looking for rocker cover gaskets and possibly some engine parts. The part numbers and letter designations are kinda confusing for the parts I might need. Are other similar size saito engine parts, such as rocker gaskets be used for my older saito 91 ? I'm a first time saito user and looking forward to this rebuild. Any help would be appreciated. Thanks, John
ICBIMProducts.com - Saito FA-91-505030 A quality gasket set, the engine code for the 91s is K
https://www.horizonhobby.com/SearchDisplay?searchTerm=Saito+K&categoryId=&sourc eDomain=&storeId=10151&catalogId=10051&langId=-1&pageSize=40&beginIndex=0&sType=SimpleSearch&resu ltCatEntryType=2&searchTermScope=2&showResultsPage =true&searchSource=Q&sourceDomain=&pageView=
Better Bearings: https://www.bocabearings.com/product...91S&feature=91
Jesse, where do you get your stock from? I have a lathe and mill sitting with nothing to do. This winter I want to finish up the B-25 and need to make some fittings for the NGH exhausts. Look what I just came across though, https://hobbyking.com/en_us/torqpro-...oke-cycle.html Doesn't give specific dimensions, so no clue if it will fit the P-61, but that would be plenty of power if it does.
Jesse, Look what I just came across though, https://hobbyking.com/en_us/torqpro-...oke-cycle.html Doesn't give specific dimensions, so no clue if it will fit the P-61, but that would be plenty of power if it does.
https://www.planethobby.com/products...asoline-engine
https://www.rcgroups.com/forums/showthread.php?2142884-Gaui-F-50-Four-Stroke-Gas-Engine&nojs=1
click to enlarge
Jim
I don't actually know, I know that I've used them for 20+ years and always the same hard chrome $11.88 and most of the time free shipping. Sadly they call them Econo Bearings and people mistake that for cheap, I have never replaced a set that I installed. I did install a set of their ceramic bearings in a Fox 50 Diesel conversion, I probably wasted the money but I had to try them. I wrecked the Fox 50 and moved them to another Fox 50 without boogering them up, they must be tough.
The 82-a I just ran has a plastic back plate but no issues with that.
what about Gaui engines, or do they cost more than what you want to spend ??
https://www.rcgroups.com/forums/show...-Engine&nojs=1
click to enlarge
Attachment 2262370
Jim
click to enlarge
Attachment 2262370
Jim
- Cubic capacity: 50cc actual 49.87 cc====3.04325 Cubic inches
- Bore: 42mm
- Stroke: 35.5mm
- Weight: 1610g (incl. Ignition), 2060 grams (incl. Electric starter and ignition)
- Speed range: 1200 - 7000 1 / min
- Fuel: mixture of premium petrol / synthetic oil
- Mixing ratio: 1:20
Regarding the plastic back plates:
I don't think anyone is saying they all have issues.Certain;y not right away! If you run them hard and long, you are very likely to see problems . If you service engines for many other folks, even more likely.
Most every 82 where I have seen problems resulting in a plate replacement also had sufficient distortion of that opening to require cleaning up the distortion before the plate would fit. (Always near the right lug) The area near the lug is silly thin and the support from the metal backplate is a welcome improvement from my experience. I have three 72 and four 82. A couple of those I have run very hard and long.
Two of the metal plates were installed on 82s with a "A" on the right lug, one is a "B" lug marked. All of my 72s and one remaining 82 still sport their original plastic backplates.
I often check out scrap metal yards as they wind up with bar-ends and odd pieces and you can often buy it a prices just above scrap , much lower than paying a cutting charge and the going rate for virgin material. Since you are going to be machining it, the at hand condition is not a huge factor. Annealed Allen wrenches are a source of high strength hex stock.
When I need something specific but not real large, it is surprising what you may find with an eBay search. Metric tubing, brass bar etc.
One of my favorite sources, and I think they will ship to you is Factory Steel in Highland Park MI. In fact, the hospital where I was born was about two blocks away and right across the street from the historic Ford plant where the Model T Fords were built. Here is their link:
Factory Steel - 4130 Steel, 4130 Aircraft Steel, 4130 Alloy Tubing, 4130 Steel Tubing, 4130 Steel Sheets, 4130 Steel Plates, 4130 Chromoly, Detroit Michigan Steel-Aluminum Supplier
You can always let me know on smaller stuff as well. The USPS Flat Rate box can haul quite a bit of metal for a reasonable cost as the weight limit is pretty high. I would not mind finding and forwarding, if that helps.
In fact, there are quite a few on-line sources but it is very convenient when these guys are just about 20 miles from here.
By all means. let me know. I do have quite a metal pile in the shed, as you may imagine.
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/500x358/nervous_guy_f9ba369738566979256ecd8a31b3eb494de41131.jpg)
Heli fuel?
hey, maybe Gary has been reworded
Jim
believe it or not, a Saito engine was the only engine to come over on the Mayflower
Jim
Last edited by the Wasp; 10-27-2018 at 06:54 PM. Reason: sorry for the edit, but I had to edit
