Pete, I took a good look sat the Cruze's tach yesterday, the redline starts at 6,500, I had misstated it at 6,800, there is no orange zone so I'd say the ECM either retards the timing or alternately shuts down the fuel injectors to limit it at 6,500. I've never had it anywhere near that though, it seldom reaches 4,000 with all that low end torque.
I am going to sell the OS 95-v and maybe the OS 62-v also, I have two Saito 62's and a Saito 100, not much chance I'd use either OS.
Hobbsy: I am going to sell the OS 95-v and maybe the OS 62-v also
Jim
Saito, a real performer
Dave if your gonna thin the herd let's start right here.I've loaded the blunderbuss with a big handful of black powder then a whole shovel load of goat manure.Off to the shed now to tack jims picture to the dart board,cheers mate.
Hey there Pete, top of the mornin to you, yesterday I received two 6" wide x 48" long sheets of .125", millermeters in your lingo, basswood for the Pawnee. My Micro Mark DC powered saw will cut the strips very accurately. It's 39 and pouring rain here, in fact I hear little ice balls hitting my window.
Jim, I'm going to send the extra back plate your way in a day or two, I tried the back plate off of my 82-b and the crank pin touched the aluminum back plate. I'll send two gaskets in case you need them for a little clearance. The gaskets are coming from the new gasket guy in town.
Hi All, New guy here. This looks like a forum I could like, I have read about 40 pages so far, lots of comradery. Having recently retired I am getting back into RC flying after about a 20 year absence. I started out reading as much as I can about the latest stuff. I then bought a copy of Real Flight Simulator and did a little honing of the relexes, it felt good so I bought a EFlite Maule electric (not to crazy about electric) so that I could get some stick time this fall before the Michigan snow flew. Kind of like riding a bike, it all came back and I am excited to get my Ultra Sport 60, Goldberg Chipmunk and a couple others back in shape for spring. Most of my engines, mostly 4-strokes were gummed up. I loosened them up a little with some kerosene so I could partially disassemble them. I then put them in an ultrasonic cleaner with LA's Totally Awesome Cleaner and they came out looking like new. It was fun tearing them down and I got an education on the different brands seeing as I have an Enya 80, a 48 OS Surpass and several Saitos, they all have slightly different variations on the cam timing systems. The David McIntire videos on YouTube were a big help. I have also picked up a couple more used Saitos off Fleabay and I have a couple questions regarding the Saitos.
First off, where is the best place to pick up Saito parts (I have some older ones, FA91, FA80 and FA65) I found a place called McGregor/Hobby Plastic in the UK, are there any others state side?
It looks like Boca is a good place for bearings. How do you determine if bearings need replacing, mine all feel smooth with no bad spots. I have 45 years in the machine tool business so I have some experience with knowing what a bad bearing feels like although these are a little higher RPM than my experiences.
Looks like ICBIMP might be a good place for gaskets.
Thanks for any input as I attempt to read all 1,521 pages on this forum..... Mike in Michigan
https://www.horizonhobby.com/SearchDisplay?searchTerm=Saito+80+parts&categoryId =&sourceDomain=&storeId=10151&catalogId=10051&lang Id=-1&pageSize=40&beginIndex=0&sType=SimpleSearch&resu ltCatEntryType=2&searchTermScope=2&showResultsPage =true&searchSource=Q&sourceDomain=&pageView=
Some 80 parts, the best way to search Horizon for parts is to use the engine codes, the 65 is Saito G, the 80 is Saito I, and the 91 is Saito K, the Golden Knights have their own codes. Welcome and enjoy.
These gaskets are excellent quality, I've already used some of them: http://icbimproducts.com/gaskets/new...php?groupid=80
I have been very happy with sourcing parts from the folks at Mc Gregors. They seen to have a good supply of the older parts that horizon often ignores. Also do well buying parts on eBay as every now and then Saito owners sell off parts they no longer need.
The rings from eBay (and direct) ring maker in England known as "Swarf Monkey" are excellent. Properly made and heat treated, every oneI have purchased has worked perfectly. Failing that, some lathe owners make them at home when needed. (My lathe is one tool that I will not give up
LOL LOL
Jim
Saito Engines: oh yeeaa ba-by
Jim
as for your bearings, if you remove the back plate and you see rust on the bearings>, I say replace them,, yet on some engines you can not see the rear bearing with the back plate removed, so with those type engines you just have to account for how much fuel has been run threw them, and how much after run oil has been used in them, and the feel of the bearings as you turn the crank (without a glow plug in the head), also check to see how loose the bearings are.. cheap bearings can rust in 2, 3 or 4 gallons, < I have seen it (as well as many other Heli pilots have),, good bearings will lest longer, specially if after run oil is used and a spray out is done for the winter's sleep,, here is an example. my OS 61 lived a hard life, it saw little after run oil, it was some 15 years old and had 7 gallons run threw it when I replaced the bearings, the bearings had some rust yet I have seen worse, they turned ok but they felt a bit loose, it was time to replace them, I used quality NTN bearings, and after I replaced them>>> the new front bearing started to leak on the 3rd tank of fuel,, go figure, that's the hobby
good luck, buy more Saitos LOL
Jim
That is sometimes a symptom of too much compression for the amount of nitro. I have seen pylon racing engines start with no power to the glow just flipping the prop.
You would'nt be laughing if you saw the target after.Dried goat manure pellets are way bigger than BB's ![Smile](images/smilies/smile.gif)
Welcome mirion,gary has a good point,buy quality bearings.I prefer ngk's.As to checking your bearings in the saito's you have,i don't just go by feel when you turn the prop over with the plug out,that can feel ok but you need to rock the prop at the tips back and forth at 90 deg to rotation.Gently grip the prop tips and rock back and forth,any play that can be heard by a clicking noise can also be felt.It's flyable if there is a tiny bit of play but the writing is on the wall.Cheers mate
Dave sounds cold/wintery over your way.They could sure use some of your weather in california right now poor buggers.Everything i hear here on the news sounds worse and worse
That reminds me, the 72 on my SSE tends to howl, thinking a bearing may be going bad, though they are smooth with no slop. Guess I need to open it up. Should have checked when I replaced the jug on it.
The bargain bearings work okay, Like I said earlier, for engines I intend to spend some time with; I find it worthwhile to get name brand, graded bearings . Prefer old stock, US or European made or old stock Japanese made "NTN" or "NSK" branded.
Not the end of the world either way but the higher graded bearings are usually worth the effort for engines that will see a lot of use in airplanes![Wink](images/smilies/wink.gif)
![](https://cimg9.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1124/20181117_162538_4f71b11579cf2a460d23c1c56dd2935f31f06170.jpg)
Bruce (acdc) worn bearings in flight don't make a howling noise might be prop and other things you are hearing.
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/1000x1371/saito_fa_82a_page_2_9be77cd9bc64bc3e4cfe36a41571a0904a79c90d.jpg)
Testing to see if we can red this
I find this interesting, peak torque at 6,300, max power at 9,700, look how far the torque falls off at 10,500. My habit of propping in the mid nines seems to be a good thing. Thoughts please.
Sorry, it's a Saito 82-a
