Old 11-27-2018, 08:27 PM
  #38076
Hyjinx
Originally Posted by the Wasp
Super cool!
Low fly bys against the city skyline. Super cool!
Old 11-29-2018, 04:29 AM
  #38077
[email protected]
Default Saito FG-11 Gas Four Stroke
Greetings. I am getting ready to purchase this engine to install in a Tower Super Kaos 60 in order to practice pattern. Does anyone of have any experience with this engine. I have not owned a four stroke or gas r/c engine previously.
I have read many of the posts...appears that I will enjoy the Saito brand. I know I want a four stroke for this plane, just not sure about gas versus glow as well as the size. Thanks in advance!
kgw
Old 11-29-2018, 04:35 AM
  #38078
Hobbsy
Hobbsy's Avatar
I have that engine, it is a slightly stretched Saito 62 making it a 66, it starts easily, runs smoothly, idles slowly. Here is your gasoline to oil ratio: I have to write it out, it won't copy and paste correctly.
20 to 1 ratio===6.4 oz. oil to one gallon or 128 oz of gasoline.
Old 11-29-2018, 12:15 PM
  #38079
the Wasp
kgw
it's nice to see you here on the Saito page !
but before I answer your questions first things first, and I think most Saito owners would agree with me here> you should buy 2 Saitos, ,,, even if the 2nd one is used, you should buy 2 Saitos LOL
as for your question,
A) brake it in on the bench for at-least 1/2 gallon, better yet 1 full gallon,
B) I would run it richer than you would for a glow 2 stroke, for 2 reasons,
1) because gas burns hotter than alcohol,
2) because a 4 stroke's Head can run hotter than a 2 stroke's.
welcome to Club Saito !
Jim
Old 11-29-2018, 01:08 PM
  #38080
Hobbsy
Hobbsy's Avatar
Jim, if he breaks it in for a gallon it will take him a year although he'll get to enjoy the joyful Saito sound for a year and it's the season for joyful sounds, Double good advice.
Old 11-29-2018, 03:28 PM
  #38081
triumphman49
My Feedback: (149)
Hi, was just wondering if the FG11 would be enuf for the 60 sz KAOS? Maybe a FG14? 60sz usually would want a larger 4-stroke and gas is a little less efficient than NITRO . Just wondering what ya'll thought.
Old 11-29-2018, 03:45 PM
  #38082
JimO
My Feedback: (7)
I would you with the 14. The would not have enough power to really pull the Kaos. Bigger is better and you can always throttle back.
Old 11-29-2018, 09:30 PM
  #38083
the Wasp
LOL Dave, I didn't think about that LOL
Jim
Old 11-29-2018, 09:46 PM
  #38084
the Wasp
I agree with JimO, the FG11 will fly it, but it's a 60 size plane, and usually a plane that calls for a 60 size 2 stroke calls for a larger 4 stroke, and remember you will have to pull around the ignition and extra battery and extra on/off switch, so I would buy the FG14c (82), it's only $30 more than the FG11, I think you will get more for the money too
Jim
Old 11-30-2018, 12:19 AM
  #38085
Rudolph Hart
Rudolph Hart's Avatar
kgw
KG as a guide gas saito fourstrokes make about 25% less peak power than their same size nitro brothers do,so a 60 size two stroke kit needs an fa91 or fa100 i use an fa115 on my 60 size midget mustang.Factory needle settings are very close so unless you want to run the engine in with a bigger than benchmark recommended prop i'd leave them alone for now until you start flying it.Gas engines have very fine fuel screen filters in them and it causes long term tuning problems which can be frustrating because they quickly begin to clog up the filter screens if you don't religiously strain your fuel properly.Buy a brand new plastic fuel container and a big packet of coffee filters from the supermarket.Pour 500ml of fresh pump gasoline through the coffee filter if you can and you'll see what i mean.
Most saito's,but not all seem to settle down for max rpm after a gallon or two,as dave said you could go on a long holiday,come back,and it's still running.
ps saito says hello (woof woof) to those fortunate souls who are fa125less
Old 11-30-2018, 03:34 AM
  #38086
Hobbsy
Hobbsy's Avatar
I am not so pessimistic about the four stroke power, with a well matched prop the four strokes have just about the same Flying Power. The exaggerated paper two stroke power doesn't provide much more of that.
Old 11-30-2018, 04:59 AM
  #38087
Jesse Open
Jesse Open's Avatar
The gasoline fuel also makes a bit less power than methanol. IIRC, the gasoline version also sports a reduced compression ratio.
The FG-14 would be my choice, but then again ,I would convert it to run methanol instead of gasoline.
Old 11-30-2018, 02:48 PM
  #38088
triumphman49
My Feedback: (149)
Are you suggesting a FA82 with maybe a CH ignition set up . . . or would you prefer the FG pumped carb ? (glow fuel w\spark plug to run less oil, better idle, and increased top end). With spark ign, some do run stock carb for glow or gas fuel.
Old 12-01-2018, 03:47 AM
  #38089
Rudolph Hart
Dave pessimistic is one of those big words like wheelbarrow,marmalade and rhubarb,i agree with what you are saying re flying power for saito fourstrokes in the air you can see the difference in initial acceleration of the plane.Similar size two stroke power delivery in the air seems quite soft by comparison tho they go like a bat out of hell when you get em wound up.
ps aaagh...ch ignitions and methanol,i can feel a severe case of sr telemaster coming.I hope he's finished his mauser 7x57mm
Old 12-01-2018, 04:07 AM
  #38090
Hobbsy
Hobbsy's Avatar
Some modern day two strokes come with larger prop recommendations, but folks still resist those recommendations.
Old 12-01-2018, 10:49 AM
  #38091
Hyjinx
Originally Posted by rudolph hart
dave pessimistic is one of those big words like wheelbarrow,marmalade and rhubarb,i agree with what you are saying re flying power for saito fourstrokes in the air you can see the difference in initial acceleration of the plane.similar size two stroke power delivery in the air seems quite soft by comparison tho they go like a bat out of hell when you get em wound up.
Ps aaagh...ch ignitions and methanol,i can feel a severe case of sr telemaster coming.i hope he's finished his mauser 7x57mm
Old 12-01-2018, 10:50 AM
  #38092
Hyjinx
Originally Posted by Hyjinx
Best quote ever
Gotta love this stuff!!!!!!
Old 12-01-2018, 12:08 PM
  #38093
Hobbsy
Hobbsy's Avatar
Best quote ever
Jinx, I was very clear in what I said, now, what did you say?
Old 12-01-2018, 01:57 PM
  #38094
the Wasp
hey Dave, I have that Saito 82 (and thank you and Captain again for that),, and you know what else I have, well I have a brand spanking new RcX ignition that came with my Z G20 that I was going to use in my heli,,
any hoo, in my link is a plane (kit) I have been wanting, I would like to round all wings and change the tail to make it look like a early 30s plane,, the 82 would with the ignition would be cool in it..
photo,,
once in this link scroll down to see photos of the plane,,
https://www.radicalrc.com/category/Kits-145
Jim
Old 12-01-2018, 03:15 PM
  #38095
Hyjinx
Your P ess.
Smartist, pragmatic, positive, humorous, spot on comment I have seen on a forum.
I smiled ear to ear as I read it.
And had to agree laughingly whole heartedly👍
Gas to glow to glow to gas and repeat. Forever.😁
Old 12-01-2018, 05:08 PM
  #38096
Hobbsy
Hobbsy's Avatar
BTE Venture 60
I see, I think.
That looks pretty cool Jim, I had a Saito 72 on a BTE Venture 60 a very similar sized plane. It flew like it was on rails.
Old 12-01-2018, 05:20 PM
  #38097
Hobbsy
Hobbsy's Avatar
It would be nice if Dan still hung out here, he has a lot of good numbers and info on the glow to ignition/glow subject. It's appreciated by most.
Old 12-01-2018, 10:29 PM
  #38098
the Wasp
Dave, I like the plane, but I didn't realize how lite that plane is, the 82 with battery, and ignition is too heavy
Jim
the Saito engine, the better chance
Old 12-02-2018, 04:18 AM
  #38099
Rudolph Hart
Not me dave dang it! good numbers or no it's like going back to church and sitting through a whole hour of fire and brimstone preaching...
Old 12-02-2018, 04:20 AM
  #38100
Hobbsy
Hobbsy's Avatar
Here is an interesting option since that plane is very Stick like. With the Eureka kit you need to choose and buy most of your own hardware and get the plans printed some where.. The 82 would be perfect on it though.
Ugly Stick 60
