well guys, if you don't know, sorry to tell you, bad news here,,
I was looking to buy fuel about 3 months ago, I could not find any around here or with-in 150 miles. I was going to buy straight from WildCat, so I called them, but I needed to buy at leased 8 cases to get the better price, but I just didn't want so much setting around here so long, yet even 4 cases would have been more than I needed setting here, so I didn't order it, well go figure, I should have ordered those 4 cases !!!! I just found out the price per gallon has jumped some $12, my God Nitro has jumped high !!.
I guess I will have to start mixing my own, about the only thing I like about that is the better price and the fact that I wont be putting a dye in it, I have no need at all to dye my fuel, I know there is a guy up the road from me, at one time he was selling 30 gallon jugs or Methanol, but again I don't need that much setting around here.
if the guys in club are willing to mix their own we can get together on that ??
Jim Bob Yee Saito Freak
Ps, I think we should rename the club to "the Saito Freak's Saito Club",, that will fit well
Last edited by the Wasp; 01-03-2019 at 12:12 PM. Reason: opps, I forgot the "a" for "a guy", the cat was talking to me again,he can be a jerk at times
I have a case of SIG fuel as well as several half used bottles that are clean, but old, which means low nitro but still usable. If it jumped $12, then it will be $30 a gallon for the Wildcat I use. If it gets that high when ready for more I will just convert everything to gas and be done with it.
This may also mean Saito will be moth balling some more glow engines, likely the larger and multi cylinder.
Could make for some real deals on used engines as the faint of heart, a gasp at the new prices divest themselves of glow. The rest may move over to gasoline but a percentage of even those will give up.
The times are changing but I will never turn away from methanol fuel
Can't blame anyone who does however.
Club Saito Fuel Coop
I'm in, just give me a holler when you all are ready. I'm not really interested in running the coop, just interested in contributing funds and buying the mixed fuel at a reasonable price. I'm not giving up glow anytime soon. I have no gassers and only one 3D electric plane.
I would much rather burn straight Methanol with an ignition than gas, but I do not want the extra bits that come with an ignition
maybe I will change my user name to "Sad about the Nitro Prices"
Jim
Jim
My Feedback: (12)
So far, I’m lucky my LHS sells glow fuel at reasonable prices ($13-25/gal). But I have noticed inventory is much lower lately. I’m not opposed to mixing my own if I had to. Heck, I just bought a quart of Klotz to cut some fuel not long ago. Finding methanol is not hard. Any local speed shop should carry it for $2-3/gal. The problem is the nitro. I found some online but you need to buy a 4 gal case of it for over $200.
My Feedback: (12)
Saito 100
Update on my 100. It’s a little worse than expected. The intake valve and intake tappet has rust on it. I think it was the victim of prolonged storage. I noticed when I first took it apart the top end was just flooded with oil. Now I know why.
Anyways, I realize the proper thing to do is to order replacement parts for the tappet, valves and maybe even springs since one was compressed for so long. The question is if I cleaned it up and removed the rust would that be good enough? For the valves I used 0000 steel wool and feels very smooth now. The tappets may need a bath in evap-o-rust.
There's some clever thieving blokes out there quicky when it comes to disguising engines that have been left to rot so to speak.Rust is easy to see and clean off,before cleaning it's easy to feel because some of the corrosion is above the valve stem surface and feels rough.Once you polish it only the pitting remains and this you will not feel,it needs a good visual.I'd ignore pitting on the valve stem as long as the valve head and seat faces are ok.Might as well do valve springs,cheap as chips which reminds me...here in aussie we work metric and our aussie dollar is about 75c US so i converted the price we pay per 5ltr bottle of 10% to your figures.We pay well over forty bucks a gallon here,not much cheaper to mix my own but...i get to add my own,first press,degummed virgin castor oil,tastes pretty good too
ps 'sad about nitro prices jim' i gave up waiting to hear about your calculater so i grabbed an old one of mine out of the desk draw and gave it a good thrashing on the desk top
The springs that rust while compressed often do lose their tension to some degree and in full size engines are more prone to breakage. Little risk in replacing them.
I have salvaged many engines similar to yours and had fine service from them.
Hope this helps
Gary
That engine appears to have had a lot of moisture in it judging by the stains on the steel parts. And had not been run much either.
My 82 parts looked similar and most cleaned up good. I would only replace the valves if there is pitting on the valve face. Same with the lifter faces and cam ramps. Small pits in the valve stems and lifter bodies won't cause issues. Check the cam lobe ramps carefully, especially the acsending side and top of the lobe, for rust pits or lifter dents and replace the cam if any are found in the shiny zone. The descending side can have very small pits and still work fine for years. Use a fine abrasive, no more course than 0000 steel wool for cleaning up the lifter faces and cam lobes.
I would replace the bearings for sure, as a cheap insurance measure. If rust pitting is found anywhere in an engine it can be found everywhere in an engine! At least to some degree.
In my case the cam had small lifter dents on the ascending faces of both lobes from improper lash adjustments and small pits as well. The lifters had uneven bevel wear at the bottom as well. Hopefully your parts list will be shorter than mine. Good luck friend
Jim, the first 5% nitromethane has the biggest payoff with most engines. You do get a better, steady idle and transition in most cases from a little nitro. The older HC versions of the 150, 80m and perhaps 65 are least affected.
In the early 80s I ran homebrew zero nitro only in all of my engines, Saitos, OS, Enya and Super Tigre. I bought Castor in five gallon cans from American Shortening and Oil Company in Livonia MI. They were right next door to Sun Electric where I worked at the time. $20 to $25 bought 5 gallons!..
On the way home I picked up Methanol at the Gage Products railhead in Ferndale. Depending on the clerks mood it was fifty cents to a buck per gallon.
Made for a lot of cheap flying. Fuel under $2/gallon. I didn't start shimming the HC engines until I started using nitro again a few years later. Logghe Brother started selling nitro ( They built drag cars for many of the big names and stocked nitro and model engine glow fuel too) Still prefer with nitro over without! I use one blend for all of my engines, including the YS which are often rumored to need massive doses of nitro. (Don't believe that) 14% nitro and 14% oil with 2% of that oil being castor. No "gumming", ever. Clean running , very happy with that mix overall. Fuel is fuel, nothing magic or mandatory about store bought.I havent had to buy a jug of "Who Knows Whats In It" store bought in years. Shop around, it doesn't cost much to go first class!
Please don't fret Jim, Saitos run perfectly well sans nitro methane, our friends in Europe and other countries have Saitos that have never seen a drop of it.
Not like the sky is crashing down. "Alkydiggers" in Nashville TN will ship,for example a single gallon of 100% Nitromethane to Detroit area for$73.10. At 5% that gallon will make about 21 gallons of fuel. Cost of nitromethane, if my math works is a whopping $3.48/gallon. Buy the 4 gallon case and save even more.
But better order now, just in case it goes up again.
You can buy nitromethane here for 58.40/ Gallon in 5 gallon pails, delivered.
https://www.ebay.com/itm/Torco-Fuel-...v18:rk:31:pf:0
That comes out to about $2.78/ Gallon to treat yourself to 5% nitromethane or a whopping $5.56 for 10% .
Just hope the oil doesn't go up too!
My Feedback: (12)
For the sake of expediency, last night I cleaned the tappets and valves and reassembled the engine. After cleaning I gently went over the surfaces with the edge of a razor blade and can feel no pitting or anything. The engine is indeed very low time. Bearings are silky smooth, cam has no pitting, valve springs have no rust. Both push rods are straight and the same size. However, with proper adjustment the difference between valves remains. One more thing I found was a stuck piston ring which I freed up. Now the the compression is excellent and my 100 is ready for service.
Thanks to to everyone for their input. I will say these Saitos easily rust if not stored correctly.
Come to think of it, one of the 100's I have is the same way with the oddball adjusters. It could very well be a slight mistake on the drilling of the pivot point in the rocker tower where one sits slightly lower or higher than the other.
Quikturn; However, with proper adjustment the difference between valves remains.
Pete; jim' i gave up waiting to hear about your calculater so i grabbed an old one of mine out of the desk draw and gave it a good thrashing on the desk top
Gary, 8X16==128, I like those numbers, that's 2 years flying for me, maybe more, most likely more
Jim
My Feedback: (12)
Cam Grinds,
here you go, scroll down to Post #13
edit ,oops, see also post #16
http://www.rcuniverse.com/forum/glow...l-robison.html
Jim
Jim
When get my new cam for my 82 I'll compare it to my old one. My 82 is the A model (plastic back plate) so it may have the older cam. The new cam from Horizon should be the new hotter cam with the quieting ramps. Specifically, I'll check the diameters of the base circles as that's the only part of the cam that could cause a mismatch in lash adjusters.
120-S DP
This is an excerpt from Way Out Willie's, our nickname for him, cam discussion, he describes a 120-S like mine with curved pipe that inserts into the head with two O-rings.
This composite shows all the external differences between the old style big block engines and the "High Cam" versions. Also shown is the original "S" cam, just used for a short time in the original FA-120S. If you see a 120 with a curved intake pipe instead of the cast pipe it's an "S" model, the hot one. The later "S" 120s had the cast pipe and a normal cam, but still with the wide headed tappets so they were still a bit hotter than the early ones. No composite available.
I don't think that you'll find a difference in the 82 cams.
Saito break in?
Dave, still breaking in Saitos per this post?
"First, take it out of the plane as Jim suggested,
The first 10 minutes is at 4,000 rpm or less with the throttle at 1/4 to 1/3rd open not full throttle.
Then, 10 minutes at 5,000 rpm, with HS needle at 3 turns open
10 minutes at 6,000 rpm
Peak HS needle temporarily,
Set LS needle for decent Idle and transition
Richen HS needle 300 rpm below peak
Now, 10 minutes at 7,000
Tweak LS needle for best idle and transition, go fly at slightly rich setting.
Running it at full throttle very rich will not contribute to the break in but will make it run stone cold and accomplish nothing."
