That stuff is great. As you say, the flavor not the hot.
About the only Saito vibes that really bothered me was the 180 in the 1/5 scale WACO. Other than that, I don't run factory fuel loaded with oil. 14% is it.
Pete, my son will laugh when I tell him that name
acdii; hells kitchen hot sauces, I will have to try that some time, I only eat hot sauce for the flavor not the heat
Jesse; "Rocket Radish" I think I have had that once before, but I live in Vt and we are a bit deprived here at times LOL
Jim
Jim
hey guys, I am a bit wary here, should I use it or recycle it ??
I have some 15% Wildcat and it's about 50% full, and it's been setting here 10 years, and I have a few Saitos to brake in, if it was unopened I would just use it, but I'm wary of using it.
so how do you guys feel about a using a half filled bottle of fuel that has been setting 10 years ??
to add, the humidity in my garage can and does rise higher than it does out doors in the summer
Jim
Jim
Check out the guy on the left after trying the Ghost pepper sauce. I LMAO. I tried it, wasn't that bad. My 13 YO daughter tried it and she liked it too.
https://www.youtube.com/watch?v=zP4TiXgh4Dg
Jim
![](https://cimg2.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/450x450/1ca5dc71_9461_4c53_a5ae_4fa083695fe3_1_f0fd8ad874551f80c3ea10d4c88cab41_8a1e5f22053c85c2823b349499b0ee3c71f31a44.jpeg)
I had a batch of 30 plus year old Fox Missile Mist, in the original cans, stored high and dry in my garage. Used them up, save for 1 can. It worked as good as the day it was made
Years ago I had 2 cases of Logghe 10% I left two of the (plastic) jugs sitting in a concrete floor over winter, the rest of the same batch were high and dry on a wood shelf. The stuff on the floor was noticeably degraded, the rest was fine.
Not like your engine will self nuke, try a slug on the ground.
first, the site is acting up again, see my post above, see "videolooks", well if I go to edit it the site shows me the word "it", <that I DID type in, and the 2 words "video" and "looks" are separated... what a crazy site !!
JIm
JIm
yee-up, now it wont let me edit,, if I do edit the site will remove some of what I typed, as I have ranted before, iy must be the site because it did not do this on the RunRyder Heli forum and others
Jim
Jim
Since the fuel is hydroscopic, and water can cause all sorts of issues in an engine, freezing the fuel is the quickest way to spot water contamination. I have some old fuel that I check that way, other than not hitting peak power, it is still good enough to putt around with, but I always freeze a small amount in a glass jar first. Pretty interesting what it looks like once it has been in there for a few days.
guys !!
I have to apologies for my misspelling and editing, I am highly nearsided, I can see close up really well without my glasses, and I can see good to fly and drive with my glasses, so some times,, LOL make that many times, I have problems with sharpness and clarity on the computer. I also need new lenses now.
my eye doctor told me just a couple years ago that I most likely will never go blind, but I may come to the point whereby I will need new lenses yearly, and I feel I am at that point now in my life
Jim
Jim
Gary, disregard the PM I sent you. A 45 would be to much for my little vintage high wing.
Anyone have a good running 30S they would like to unload? Or even a 15-20 2 stroke?
Lonnie
Lonnie
Lonnie, I have a Thunder Tiger 40GP, it's not that powerful, but it's liner and piston are in very good shape, great compression too, if you can't find something and want to check it out I will send it to you
do I need to edit LOL
Jim
Jim
Gary i hope that smelly two stroke engine thing assfixiated really slow once you slipped the bag over it's head,do have a big hammer in the shed?
Jim like they said above put your fuel in the freezer,but that does'nt fix your problem re removing the water so you can use the fuel.To do that you need to borrow your wife's stainless steel fine mesh veggie strainer,whip the bottle out of the freezer and pour thru the strainer in to another fuel bottle,your good to go even if it is a bit FAI fuel like.
ps make sure to buy the wife a big bunch of flowers
pps,you can thank me later
Thanks Jim but even that is too much engine.
Jim
Jim
Should easily make two nice engines, Plenty of stuff left over. I already have a new style 40 and two 45 Specials, one of the new and several 50s Don't really need all that stuff, let alone the 45 basket cases.
Most of that, along with the 45 stuff is headed for the flea market Saturday.
The only 30 that I have left is my first , an open rocker 30. Not ready to let that one go yet. Low compression, thinking about making a ringed piston and fly that engine once again.
No problem, I had to go back up to the storage shed to take a look at what is there. Did that last night. There is the better part of three engines. New bearings (not cheapo, generics) four new rings a couple of new cams/lifters,A new set of cases, rear cover and cam case, along with the original parts.
Come on down!
I had intended to the shed go on Sunday afternoon, but went last night instead. Got to have a better look this morning and, yes a lot of 45 stuff. The swap tomorrow is actually a vintage electronics expo but toyairplane motors are always welcome. (No "Moderators"
Sunday , a ham radio swap . Taking a lot of radio stuff there as I cut way back on the shack size when we moved to the new, bigger house...go figure. I will be taking a lot of Saito stuff there too .
If anyone happens to be going to the Hazel Park ARC Swap in Madison Heights on Sunday......
Monday morning...order some YS
Gary, what do you have for NIB or barely run 2-strokes for sale ( <oops, sorry Pete), from 61 to 120any odd engines, any twins ??
Lonnie, keep an eye on RC Groups classifieds, you can find some good engines there for good prices, some guy just sold a NIB Saito 100 for $170..
Jim
Jim
