Nitro models pusher Bobcat?
#3906
RE: Nitro models pusher Bobcat?
I have the Robart Retracts that will fit BobCat 52 as I have and bought two sets fro some reason and I don't see a need to keep both. If anyone is interested in a Brand new set of retracts let me know. I paid $144 plus shipping. Willing to let go for $125 shipped.
http://www3.towerhobbies.com/cgi-bin...?&I=LXJZE2&P=7
#3907
Could only get one of the non-retract ready versions. Anyone have any idea how much work to self mod it to accept retracts? Is it worth it?
#3909
[img]file:///J:/DCIM/100NCD90/DSC_0218.JPG[/img][img]file:///J:/DCIM/100NCD90/DSC_0219.JPG[/img][img]file:///J:/DCIM/100NCD90/DSC_0220.JPG[/img]
[img]file:///J:/DCIM/100NCD90/DSC_0221.JPG[/img]
Image one shows the wing. I haven't cut out the covering to expose the servo mounts, but the area where the retract would go is only a thin opening for the piano wire.
The other images show the interior of the nose that would normally be cut out to accommodate the retract. As you can see there are no blocks on which to mount the cylinders. I also show the underside of the nose. Again, no cutouts.
#3913
Ahhh this is not the one that has been converted to turbine and constitues most of this thread, the one most are converting are the same as the Falcon 120 and is much bigger, perhaps an enquiry in the "Extream Speed" thread may bring some results.
Mike
Mike
#3914
AZ
I have a non retract bobcat also. The landing gear is WEAK. I have a set of retract also. I am considering installing or bending my own wire. At the very least a retract unit for the nose gear. Would not have to retract, but would work waaaay better than stock.
#3916
AZ
I bought it used with an OS on it. It flies well, only problem is hte weak landing gear. Every landing results in a re-bending of the mains. Not hard landings either. Just a long taxi without take-off they are bent back. Very poor design.
#3917
I think you may have better luck with a post on the "Extreme Speed Prop Planes" forum rather than in the "RC Jets" forum, however you can get olio's that grub screw onto piano wire, these may work if you cut your existing wire legs, or bend new ones, lots of people make them including Robart.
Mike
Mike
#3919
ORIGINAL: IMPNZ
Does anyone know what scale the Bobcat is ?, I'm trying to figure out what size pilot will fit this ?, LOL.
Mike
#3920
NJ
ORIGINAL: IMPNZ
Don't know the scale but THAT is NICE!!!!
#3921
My Feedback: (12)
MT
ORIGINAL: IMPNZ
#3924
My Feedback: (12)
MT
That should work out very well, keep us posted how it goes. I had the 50 size Bobcat with similar colors and wanted to do the same to try and get more speed. Should be interesting. What motor/fan combo you using if you don't mind me asking?
Shane
Shane
#3925
I'm building it around a Schubeler DS51 even though there's enough room to get a 100mm fan in there, I may go with an ARC 3675 but haven't really made my mind up on a motor choice at the moment, there's still a fair amount of work to be done before I'm ready for the power system.
I'm not really building it with the intention of being a hot rod, I was just sick of the generic choices of 90mm EDF's on the market so decided to do something a bit different.
