the chain is for the dead chevy’s I come across. The dust pan is for work silly. And yes the tail gate needs all the help it can get, the last truck I had, I put three tailgate’s on.
I guess Ford only wanted to get 100,000 miles out of each tailgate. Considering the last truck had 346,000 on it when I finally let her go boo-hoo
My 1995 F 150 tailgate only has 217,000 and is not broken in yet.
I just ran the rebuilt 50 with an APC 12 x 6, someone stated that I'd get 9,500 rpm and they were almost spot on. I did a hurrier job of running it because there is, (as my Dad would say) an ill northeast wind blowing in here and getting colder by the minute. I quickly got red knuckles holding the new tach. My ACE Tachmaster II was off by 350 rpm, I pointed it at the overhead lights and calibrated it to 3,600. It and the new Hangar 9 tach read the same at idle and top rpm. I like the new tach.
Saito 50 GK with new bearings and gaskets
Exhaust==latest revised muffler
Plug=====OS-f
Fuel=====Wildcat 10% with 18% full synthetic
Prop=====APC 12 x 6
Max rpm after 15 minute warm up==9,390
Idle======2,100
No burble, no hesitation, just clean linear acceleration from idle to full blatt. It's a keeper.
Plug=====OS-f
Prop=====APC 12 x 6
Idle======2,100
LOL!!!
You can see all kinds with chains at either end
At least you get to put some miles on them. No shame in wearing out a tailgate, getting some honest work done eh? Is that a Bus alongside your truck?
the tailgate on the 99 and 2001 rust out all in the there own. Wish they would have stayed with the heavy steel tailgate like the old ones. These tin tailgate’s don’t last.so by running a Saito engine on the back once in awhile helps to get them to last a little longer
<div style="text-align:left;"><br /><br />no buss wife’s camper<br />the tailgate on the 99 and 2001 rust out all in the there own. Wish they would have stayed with the heavy steel tailgate like the old ones. These tin tailgate’s don’t last.so by running a Saito engine on the back once in awhile helps to get them to last a little longer</div>
Well jiminy crickets i've got a question for you.How do YOU know you were the only one to get that email? if you can answer that we'll all know what really happened in the mysterious disappearing act Lord Lucan pulled,no,look it up yourself.I too received that email and it shook me to my boots thinking 'the pope' must have had an epiphany of some kind and would now be kind and courteous to all,he was good fun and still looks in here so i'm told.
ps fa115 has open rear main bearing
Jim
Plug=====OS-f
Prop=====APC 12 x 6
Idle======2,100
Plug=====OS-f
Prop=====APC 12 x 6
Idle======2,100
Gary, the muffler and adaptor arrived, thank you good sir. The return address was covered by shipping labels. I tried to peel them back but the paper tore and I can't read the address. Please PM your address so I can refund your shipping cost.
Sbach went splat today. No signs of a stall on landing even after a headwind gust hit it but I was too slow on the throttle stick. Tore off the tail gear and gained a little negative camber on the mains. Heehee
Saito related: Of course it's unscathed, it's a Saito!
Sometimes even a Satio can't overcome it!
Glowgeek,, sorry for your loss, I have been there before
I see these guys out there with their big 100" span planes do these very slow, flat and tight circuits, I thought those are so cool. so I tried it with my son's 73" span Extra, drop the right wing, splat, busted it up good, destroyed it !
bought him a 75" span Cermark Edge 540, it's a very nice plane, well the next year he stopped flying because he found out what girls are for ! so I was out there flying his plane and I tried to do those slow, flat and tight circuits, drop the right wing and splat,,,
I fixed it up really good, went flying the next week.
well I was out there again flying around, I thought what the Hey, I will try to do those slow, flat and tight circuits again, drop the right wing and slat,,
I fixed it up good, again,, next week I went flying,,
I was out there flying around and thinking why, and I can't crash it again, then it came to me why the right wing was dropping. I asked but no one else at the field knew, but I figured it out, the answer was sO simple, it was a "Daa of course thought">>>>
I was turning into a tail wind too slow, lost lift,, never did that again, and never will !!
the edit> the morel to the story, is, it's not fun to lean things the hard way
Jim
Jim
some Saito FA100s F/S, for good prices
for a moment I thought it was brand new, but the P-nut is well used, I think the case is new, I doesn't look to have marks from mounting bolts ???
Saito FA-100 - RCU Forums
this one looks even better, but you never know, but may be sold
Saito FA 100, Like new - RCU Forums
Jim
Jim
I'm chuffed (happy) did my first long trip in the toyota aurion this last week here's a pic of some genuine west aussie bug splatter,twenty bucks to the thread member who correctly names them all.Nearly 300hp on cruise control and 30mpg to boot the only thing it's missing is an ice cube maker,a serious problem.
LOL!!!
Dave a good run on the fa50 and i'm glad you mentioned that long warm up period,usually at the field i find the first flight the engine sounds a little ragged but comes good thereafter.If you hand flicked it i hope you took bruce's advice and lightly sand the edges of the prop.
Thanks Pete, I cheated and used the mid power Sullivan, Hi Tork, I think it's called. My glow igniter was dead when I tried ti flip start it. I had charged it on a fancy Hobbico programmable charger, the problem is that if you don't remove it from charger when it's done it just goes dead again. It takes a 100 ma trickle to maintain it. I used the Sullivan and powered the glow plug with an ancient ACE Power Panel that has two plug capability. If I can play with it today I'm going experiment with a Turbo Header if I have one the correct size.
That Tokyoti is a nice lookin ride, lots of sensors on the front. I love the back on camera on the Cruze and the lights are fully automatic.
Saito 65 with Turbo Header
On a typical installation the Turbo Header gives you an extra 200 to 310 rpm and has really cool sound. http://www.rcspecialties.net/
On a typical installation the Turbo Header gives you an extra 200 to 310 rpm and has really cool sound. RC Specialties - RC Mufflers for Four Stroke Engines
